Second attempt at buying a used 4Runner. Any help appreciated.
Discussion in '5th Gen 4Runners (2010-2024)' started by stezly, Nov 14, 2024.
  1. Nov 20, 2024 at 9:24 PM
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    Patience Grasshopper
  2. Nov 21, 2024 at 7:48 AM
    Ouch! Called it. I wouldn’t trust the work of a dealer charging that much for spacers. Thieves looking for suckers can’t be relied on to do things right.
    Depending on how the vehicle was used by the previous owner/s, especially if it was used for off-roading/rock crawling, spacers may cause problems and accelerated wear with control arm ball joints, and CV joints. This is because 2 in spacers make the suspension droop 2 in more that it does stock. At full droop, the upper control arm ball joint might be near max, causing accelerated wear. If it goes beyond max , the ball joint separates, and the wheel falls off. Well, not really…it halfway falls off and tears up the rest of the suspension, axle, steering, and body work. Assuming it doesnt cause an accident.
  3. Nov 22, 2024 at 7:57 AM
    Jcberb
    Jcberb New Member
    Joel
    Just walk away. There shouldn't be any thought put into this.
    stezly[OP] and NeverTooLate71 like this.
  4. Nov 23, 2024 at 5:03 PM
    2" lift isn't going to damage anything. Take a look at the inboard CV boots. If they aren't leaking, you're good.
  5. Nov 23, 2024 at 5:07 PM
    TrailSpecial22 New Member
    PA
    walk away and never ever go back
