Scotty is Smarter then Toyota!
Discussion in '5th Gen 4Runners (2010-2024)' started by AE1M, Jan 10, 2025 at 6:56 AM.
  1. Jan 10, 2025 at 1:51 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Cant stand that guy, his videos rarely if ever fit the thumb nail and he's wrong half the time.
    Now his crap videos are going to pop up in my feed.
    RUNNER4DAN, Lc200 and icebear like this.
  2. Jan 10, 2025 at 2:05 PM
  3. Jan 10, 2025 at 2:35 PM
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    So none of you guys appreciate his editing skills? Like the pop up horse face everytime he laughs???
  4. Jan 10, 2025 at 3:40 PM
    coachhomer
    coachhomer New Member
    He's in the entertainment business and admittedly so. Take it for what it is.
  5. Jan 10, 2025 at 3:51 PM
    Irving Zisman
    Irving Zisman New Member
    Vegas
    2008 V8 4Runner
    Exactly! He says what he thinks and what his 50+ years of experience has taught him. Listen to him if you want, or not. No one cares.
    LetsTacoboutit likes this.
  6. Jan 10, 2025 at 3:56 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    When he showed how shoddy the late model Chargers were when the laminated glass door lite had a crack in it, that was it fir me. In my years of doing auto glass, I never saw laminated glas in any curved door light. Federal law mandates tempered glass everywhere but in windshields.
    That right there showed me how full of $hit he is.
  7. Jan 10, 2025 at 4:28 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I think his head is stuck in 80s/90s turbo technology in regards to torque curves. He said the 2.4T 4-banger only puts out more torque than the outgoing V6 at high RPMs. It's just the opposite.
  8. Jan 10, 2025 at 4:54 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Saw that one as well and laughed. He has other videos mentioning 4runner rust issues. I also file it under "click bait". How many "I'm Done" "Shutting Down" videos has he done lately.
  9. Jan 10, 2025 at 5:02 PM
    TheGreekFreak
    TheGreekFreak New Member
    He’s a hack mechanic that happens to be right about old Toyota’s being reliable…..beyond the obvious about Toyotas, don’t take what he says at face value.
    Why people bring him their cars to review is beyond me. I cringe when he knocks body panels with his knuckles and leans on the car with his keys dangling from his belt loop.
    Thatbassguy and icebear like this.
  10. Jan 10, 2025 at 5:52 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I totally agree with you.
    I find he’s so cooky it’s funny for me. I take a lot of things pretty lightly so he doesn’t bug me necessarily
    *edit: your user name is so good
  11. Jan 10, 2025 at 6:46 PM
    The guy should teach a class on clickbait because he is the king of it. It certainly works for him with 6.44 million subscribers. WTF!!!
  12. Jan 10, 2025 at 7:05 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    He's become very formulaic and extra click-baity over the years. He almost never provides repair instruction any longer. It's just the the same old overview of a 20 year old customer car, boring trip through the ODB scan and a test drive.
  13. Jan 10, 2025 at 8:10 PM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Interesting. So many post about maintenance cost overheads on Turbo engine. Reliability of Turbo engines in Mercedes vehicles. Low resale value of Turbo powered engine vehicle. Replacing Vacuum pumps etc.
    Do you work for Toyota by any chance :)
    V6 Twin Turbo would be more suitable in the 2025 T4R. Just my 2cs.
    Toy4X4 likes this.
  14. Jan 10, 2025 at 9:54 PM
    PointmanUSMC
    PointmanUSMC New Member
    Illinois
    2023 Black TRD ORP 4 Runner Bronze Rims
    i find him entertaining. Again pay attention to the subject and his dialogue. None of us are perfect. Possible he has moved away from some of the maintenance stuff because of age. Can’t crawl under cars forever. As much as I enjoy working on my own cars. I also enjoy paying a younger pro to take care of the problems. Save time and effort.
    Toy4X4, coachhomer and djwantke like this.
  15. Jan 10, 2025 at 10:42 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    I agree, no one is forced to watch his stuff so I don't see the value of everyone ripping on him.
    If Toyota listened to people like him and ADM, Tinkeradvanture, etc more, they would be in a better place today. Not everything automotive is about new tech and gadgets and computer modules replacing every basic mechanical function.
    Spare Parts, Irving Zisman and LuLu like this.
  16. Jan 11, 2025 at 5:32 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    No, i just don't like spam.
    That motor (Tundra) has more problems than the 2.4 so far, are you sure you want that?
    Otherwise, I'd say buy a Bronco if power is your main concern (in this segment). I've steered away from them for reliability, but as many have said, the gap is closing (or has already closed).
    I do know that Ford has been making turbo'd trucks for a long time now, so they probably know what they're doing at this point. If I had to buy a new full-size truck today, I'd be looking at Ford first (assuming I need a real truck, otherwise a Ridgeline is top on my list for vehicles with a truck bed).
    icebear and Thatbassguy like this.
  17. Jan 11, 2025 at 6:11 AM
    I'm not a fan of scotty Kilmer at all. I'll just leave it at that.
    Toy4X4 likes this.
  18. Jan 11, 2025 at 6:18 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    As annoying as he is, his YT channel isn't much different than most automotive forum members. Lots of opinion without much substance.....
  19. Jan 11, 2025 at 7:15 AM
    #49
    How Ridgeline owners like to eat their corn:
  20. Jan 11, 2025 at 11:52 AM
    #50
    FourBelugas
    23 white ORP
    Then just hit "don't recommend this channel" and move on. Y'all are doing some out standing free PR for Scotty Pro Bono here.
    Toy4X4 and Steely123 like this.
  21. Jan 11, 2025 at 12:02 PM
    #51
    What if i don't have a Honda? Can i still do that?
    Toy4X4, Mass4runner, icebear and 2 others like this.
  22. Jan 11, 2025 at 12:03 PM
    #52
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    Eating corn this way may be illegal in some states, and if it isn't it should be.
  23. Jan 11, 2025 at 12:43 PM
    #53
    LetsTacoboutit
    Adobe
    "The YouTube star has nearly 6 million subscribers and his posts have garnered billions of views. The channel has brought in nearly $24 million, according to Kilmer." - Fox News, Nov. 12, 2023
    Irving Zisman likes this.
  24. Jan 11, 2025 at 1:08 PM
    #54
    MI-FL off roader
    Brett
    Merritt Island, FL
    A true indictment of the ignorance that has inundated modern society. "The Car Care Nut" has a much more informative channel, but true knowledge and substance is boring. Scotty used to do informative videos years ago, but he has been mostly a clickbait channel for the last few years.
  25. Jan 11, 2025 at 1:26 PM
    #55
    FourBelugas
    23 white ORP
    And you guys keeping talking about him is all he asks of you.
  26. Jan 11, 2025 at 1:56 PM
    #56
    LetsTacoboutit
    Adobe
    Nothing wrong with good business. Haters gonna hate.
  27. Jan 11, 2025 at 1:57 PM
    #57
    Any press is good press.
    There's a lot of great stuff on YouTube. But, there's also a lot of BS. And, if you get enough viewers/followers, people start to believe everything you say (hell, the mainstream media isn't much different).
    Toy4X4 and FourBelugas[QUOTED] like this.
  28. Jan 11, 2025 at 2:00 PM
    #58
    FourBelugas
    23 white ORP
    He is definitely a particular type of presenter. But for people like me who are die hard old school Toyota fans, he's alright. I suspect he caters toward people like me and that's okay. He is a huge fan of the late Ford Panther Platforms and GMT800 trucks so he is no dummy or fanboy of any particular brand.
    If one is all about tech and gizmos then there are no shortage of other Social Media personalities to follow.
  29. Jan 11, 2025 at 2:37 PM
    #59
    I don't really care about tech stuff. Power windows are about as fancy as I need to get.
    I just can't stand the click-bait video titles and phony drama.
    I do like Tinkerer. He's the only Youtuber I seem to really enjoy, regarding Toyota truck stuff. I like a few bass players on there as well.
    MI-FL off roader likes this.
  30. Jan 11, 2025 at 3:13 PM
    #60
    2016Pro
    Him and the other u tube clown are worthless
