Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. Apr 15, 2025 at 6:35 PM
    #151
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    first time I’ve seen a bumper look like it’s been cut with large “pinking shears”
  2. Apr 15, 2025 at 7:34 PM
    #152
    cuse93
    cuse93 Ice Station Zebra
    Any guesses?
  3. Apr 15, 2025 at 7:37 PM
    #153
    mac1usa
    mac1usa New Member
    What is that paint coming off? Or just not finished properly?
  4. Apr 15, 2025 at 7:41 PM
    #154
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Looks like the panel pacing the rear is vertically ribbed and that could be the reflection of the sun hitting that surface, another reflection of the sun can be seen to the right of it on the right edge of the tailgate. Probably done to avoid blinding drivers behind the vehicle.
  5. Apr 15, 2025 at 7:51 PM
    #155
    mac1usa
    mac1usa New Member
    Sure looks odd whatever it is. I am not sure why that area would reflect more than metal panel itself. Maybe I will check one out if they are still in stock over the weekend.
  6. Apr 15, 2025 at 8:24 PM
    #156
    icebear New Member
  7. Apr 15, 2025 at 8:25 PM
    #157
    Looks like paint over that rough textured plastic
  8. Apr 15, 2025 at 9:58 PM
    #158
    FourBelugas
    23 white ORP
    The metal areas on the tailgate and the center of that phone handset shaped trim piece all have at least a slight convexity to them, that area being flat makes any reflection more of a glare. It does stand out to have those two small areas being corrugated.
    The whole back end would look more coherent if the bumper was body colored too but alas.
  9. Apr 16, 2025 at 9:05 AM
    #159
    Yuck I really don't like also how the front fender is basically hollow and I get it for airflow.. but it's a fkn box. It just looks like they ran out of ideas and are like oh let's Tacoma it up a bit
  10. Apr 16, 2025 at 9:17 AM
    #160
    FourBelugas
    23 white ORP
    One in brownish color stopped in front of my house last evening, I guess one of the neighbor kids' friends got one from their parents. From the rear right view there are so many lines it's a busy look at dusk light.
  11. Apr 16, 2025 at 9:20 AM
    #161
    I think the idea was to make them more similar, like the original 4Runner and Hilux/Pickup. Whether or not that's a good thing is up for debate.
    roooo[QUOTED] likes this.
  12. Apr 19, 2025 at 3:02 PM
    #162
    Personally I like the idea of commonality. Theoretically, it makes it easier to get parts far off in the future.
  13. Apr 19, 2025 at 4:47 PM
    #163
    FourBelugas
    23 white ORP
    I doubt any exterior parts from between the Taco and 4R will swap without doing a full grill swap type operation. Do they share any panels/doors/hood etc at all?
    The commonality between vehicles would also bring down costs with same design, tooling and material procurement costs spread across more units, but that has certainly not helped with TSRP with the two models.
  14. Apr 19, 2025 at 5:33 PM
    #164
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Totaled - RIP 4RORP!
    The trucks are plentiful, aren't they?
    Strange that I saw that there's market adjustments being charged on these things in another post. At my local dealers, they are discounting all the trucks and the 4Runner. In fact, they have a common practice to do paint protection and none of the trucks had any paint protection at either dealership. No extra markups except for floor mats and other Port installed options.
    kmeeg[QUOTED] likes this.
  15. Apr 19, 2025 at 7:57 PM
    #165
    crob42
    crob42 New Member
    Los Angeles
    21 Limited
    Xreas delete. Bilstein 5160/6112 285 Toyos. BMC. Prinsu
    Saw 4 on the local lot here in socal waiting for my service to complete. to the best of my knowledge they were not pre-sold.. no markups. Looks like plenty around. Of course they offered to buy my 5th gen .. lol. No dice.
  16. Apr 20, 2025 at 7:03 PM
    #166
    cuse93
    They are still marking up the sport/OR/limited trim levels in my area by 1-3k, or adding a bunch of dealer crap like ceramic coating and nitrogen filled tires. I haven't seen a Pro advertised for less than a $5k markup. I haven't seen a Trailhunter. I can't imagine that these markups could be sustained much longer.
  17. Apr 20, 2025 at 7:06 PM
    #167
    Southern California
    Are you in a high salt area? If you were in a place like Chicago or New York, where cars don't last half as long, I could see that maybe there's still a demand.
    I watch Eric on the South Main YouTube channel and Toyota is the only brand that doesn't rust all the way through in a couple of years, hahaha.
  18. Apr 20, 2025 at 7:09 PM
    #168
    cuse93
    Hudson Valley NY. Tons of salt on the roads. Weekly undercarriage rinses between December-March are my household rule.
  19. Apr 21, 2025 at 4:13 AM
    #169
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I saw my 1st 6th Gen Saturday in WV. We were behind it and my wife says look at the Sequoia in front of us. I said that's no Sequoia, that's a new 4Runner. I thought it looked OK, but like with anything new it takes time to get used to. We only saw it from behind and some side boob when it turned.
  20. Apr 21, 2025 at 7:27 AM
    #170
    brownersd
    Sean
    Humble / Kingwood, Texas
    I've had the opportunity to look at them while at my dealership last week for service as well. I agree that the outside seems bigger, and the inside, smaller. My dealership had both an SR5 and TRD Off Road, and they were both marked up about $3,000 with bogus nonsense like nitrogen filled tyres. I am just having a hard time relating to paying $68K for a vehicle that has cloth seats.
    Cheers,
    Sean
  21. Apr 21, 2025 at 10:40 AM
    #171
    FourBelugas
    23 white ORP
    The OR prices have really gone off the deep end, considering barely a year ago an equivalent OR with more standard equipment was priced at 13-14k less.
  22. Apr 21, 2025 at 7:18 PM
    #172
    I have yet to see a 6th gen on the road, just on car carriers. There can’t be many buyers willing to pay those insane prices for what you get.
    brownersd[QUOTED] likes this.
  23. Apr 21, 2025 at 7:31 PM
    #173
    leftyfire
    leftyfire New Member
    Michael
    Colorado Springs
    2006 Limited V6
    I have seen plenty here in Colorado Springs...no to the rate of 4th or 5th gen. But have seen a fair amount. Oddly
  24. Apr 21, 2025 at 7:44 PM
    #174
    balong48
    balong48 New Member
    2011 Silver 4Runner Limited
    My local dealer has been selling them like hot cakes and can’t get enough of them. Most of the ones they’ve sold don’t even end up on the website. I was driving around the lot and saw a supersonic red 2025 limited out back. It was sold and never even hit the site. They finally have one that’s been on the lot and not sold yet, I think it even has a discount.
    People are still buying them though. But yeah, I’m in agreement with you now that pricing is insane.
  25. Apr 21, 2025 at 8:25 PM
    #175
    As of today here in Denver CO there's a lot of LC250 in stock. Including Mudbath (Or whatever that light brown color is called.)
    There were few 4runners Including the beautiful green color TRD Off-road. Most likely will test drive by my friend tomorrow, I'll just be a passenger. No TRD Pros or Trail Hunters in stock.
    Needless to say insane amount of Tacoma and Tundra in stock. Didn't go inside the showroom to check discount status.
  26. Apr 21, 2025 at 9:34 PM
    #176
    FourBelugas
    23 white ORP
    Yeah in my area(SF Bay Area) 5k off of the base/1958 edition is not moving them, dealers probably need to keep slashing it to under 50k to get people interested, hopefully.
    4 decades of exclusivity down the drain in one fell swoop. Heckuva job boys at Toyota, heckuva job.
  27. Apr 21, 2025 at 10:00 PM
    #177
    Maybe I’ll get one at a fire sale price at the end of year. It’s going to be wacky if you can get an LC for cheaper than a 4Runner.
  28. Apr 21, 2025 at 10:07 PM
    #178
    FourBelugas
    23 white ORP
    If they offered the gas only powertrain in it I would be tempted, shame really, I think they did a great job styling it much better than the 6th4R. I just don't need the extra 1k of weight and powertrain that make it slower than my 5th gen ORP.
    Heck if we can dream maybe they would even throw the 6 speed manual from the Taco into it to make it a FJ Cruiser 2.0, with all that much vaunted and praised "commonality" and such.
  29. Apr 22, 2025 at 5:14 AM
    #179
    cuse93
    Yep, the LC with a gas only option and 3 pedals would be very interesting
  30. Apr 22, 2025 at 8:37 AM
    #180
    I agree. Hopefully they ditch the hybrid in future years. If they don’t cancel the model all together.
