Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. Mar 17, 2025 at 8:35 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Funny how many of the states differ with their plates/sales tax/renewals, etc. In Missouri, if you buy a new vehicle you take the dealer paperwork to one of the local DMV branches. There, you pay the sales tax and receive the new registration. They also hand you the new plates at the same time. They keep the plates at the local branches. (You need two plates in MO). You can keep/transfer your old plates if there is any time left on them (you can get a one or two-year registration in MO). But then they will have to be turned in when they eventually expire.
  2. Mar 17, 2025 at 8:50 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    At least exterior-wise, I think the 2025 looks good. Toyota did a good job with the exterior look considering they had little room for error with their enthusiast following. LOL
    Jomckinley and 2016Pro like this.
  3. Mar 17, 2025 at 2:40 PM
    Yeah cuz we wouldn't want someone to pick and choose the laws they follow like doing 100 and staying in their lanes. Lol
  4. Mar 17, 2025 at 6:16 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Regular plates on CA don't have the state outline hologram and usually follows 1abc234 format for cars and suvs if it is a white plate.
    Those are temp dealer plates, in CA temp plates have the state outline shape with 7 characters with different letter and number placements
    example from image search
  5. Mar 17, 2025 at 6:21 PM
    FourBelugas
    23 white ORP
    They went to red turn signals? That sucks.
  6. Mar 17, 2025 at 7:42 PM
    Lucky9924
    Lucky9924 New Member
    1999 and 2024 TRD ORP
    Our permanent plates do not have the CA outline in the middle. I’m from CA so I had the temp ones too. :)
    Example above, image is temporary plate.
  7. Mar 17, 2025 at 11:18 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I still don’t understand this choice of body line Toyota
  8. Mar 18, 2025 at 3:49 AM
    NoDak
    NoDak New Member
    JR
    North Dakota
    i just thought since the letters being blue and the small lettering above the plate number was red and the whole plate in general, it looked like a perm plate.
  9. Mar 18, 2025 at 6:43 AM
    No one knows what’s going on there. It’s some weird side spoiler thing for the bumper. Someone needs to try cutting it off like a viper cut.
  10. Mar 18, 2025 at 9:59 AM
    T92
    T92 New Member
    2023 Black Tacoma SR5 SX
    For that price you could buy top trim used sequoia with fat V8 in mint condition
    1SilverRunner and kolter45 like this.
  11. Mar 18, 2025 at 12:29 PM
    FourBelugas
    23 white ORP
    I'm sure in some focus group the respondents said it "looks modern" and they just ran with it.
  12. Mar 18, 2025 at 2:06 PM
    NoDak
    NoDak New Member
    JR
    North Dakota
    its just a more pronounced version of the rear lower quarter panel of the 5th gen
    its there on the 5th gen, most people just dont notice it
  13. Mar 18, 2025 at 2:14 PM
    NoDak
    NoDak New Member
    JR
    North Dakota
    this is what i mean, there is a slight upward angle to the 5th gen but they really made it more pronounced on the 6th gen.
    but if you dont look at the extreme up angle, the area covered is about the same as the 5th gen vs the 6th gen if you convert the angles, dips and what not to flat surfaces
  14. Mar 18, 2025 at 2:19 PM
    FourBelugas
    23 white ORP
    The 5th gen version looks like the designers checked their work before releasing the injection mold spec.
    6th gen looks like they threw something together monday morning before the 8AM deadline after a weekend bender.
  15. Mar 18, 2025 at 2:21 PM
    NoDak
    NoDak New Member
    JR
    North Dakota
    if you remove the ridge/cutout and made it a flat surface, it would look exactly the same as the 5th gen
  16. Mar 18, 2025 at 2:21 PM
    Yeah Nah
    djwantke and FourBelugas like this.
  17. Mar 18, 2025 at 2:23 PM
    FourBelugas
    23 white ORP
    Not even close. If you are speaking without sarcasm, please seek care from an ophthalmologist and don't operate motor vehicles before being treated.
  18. Mar 18, 2025 at 3:17 PM
    FourBelugas
    23 white ORP
    Now I want to see the rear bumper area disassembled to see what's under neath those giant codpieces, electronics or just empty puff to look bulgy.
  19. Mar 18, 2025 at 4:19 PM
    #49
    I don’t know where to even begin for clearance cutting the 6th gen bumper covers, honestly. They’re wack
  20. Mar 18, 2025 at 5:31 PM
    #50
    I dunno bout that. The 6th gen angle chunk is on growth hormones. Trimming for steel bumpers will be interesting. Just look at the double moustache in the front corners and think how will that look with a steel bumper that doesn’t have these pronounces contours.
    Huge difference, front and back, to the simple 5th gen:
  21. Mar 18, 2025 at 5:42 PM
    #51
    And if my Aunt had nuts she’d be my Uncle..
    :p I’m biased, but:
    FourBelugas and Turd Ferguson like this.
  22. Mar 18, 2025 at 6:35 PM
    #52
    or 8 1st gen sequoias and play bumper cars
    or 4 2nd gen sequoias and play bumper cars
    kolter45 and T92[QUOTED] like this.
  23. Mar 18, 2025 at 6:46 PM
    #53
    @NoDak Maybe I’m being harsh, and a d*ck.
    It doesn’t look that terrible on the black ones
    NoDak likes this.
  24. Mar 18, 2025 at 7:29 PM
    #54
    FourBelugas
    23 white ORP
    Black is the ultimate cheatcode for all bad designs when you can't see the lines, even the Aztek looks less bad in black
    kolter45, vthoky and djwantke[QUOTED] like this.
  25. Mar 18, 2025 at 9:05 PM
    #55
    Not sure a viper cut is meant to be, on the 2025’s
    Been trying to visualize the best line to cut for steel
    FourBelugas likes this.
  26. Mar 18, 2025 at 10:05 PM
    #56
    FourBelugas
    23 white ORP
    With how busy the front is, I would just bite the bullet and do a Taco grill swap and call it a day
  27. Mar 18, 2025 at 10:08 PM
    #57
  28. Mar 19, 2025 at 3:43 AM
    #58
    NoDak
    NoDak New Member
    JR
    North Dakota
    yeah the black hides it very well, but then you can really see how the rear lower panel in essence looks the same area wise as the 5th gen. especially in your angle of the the pic
  29. Mar 19, 2025 at 3:46 AM
    #59
    NoDak
    NoDak New Member
    JR
    North Dakota
    well i see an advantage on the 6th gen as the body panel crease fits more in line with aftermarket mods. that sharp body panel crease upwards helps vs the 5th gen L shape body panel crease.
    but its subjective on the person and the mod on how it takes advantage of the body panel lines.
  30. Mar 19, 2025 at 4:43 AM
    #60
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
    Weird, in Massachusetts you keep your same plates. Doesn't matter what type of vehicle.
