Sales figures by color
Discussion in '5th Gen 4Runners (2010-2024)' started by qcTRDct, Jun 30, 2024.
  1. Jul 1, 2024 at 3:30 PM
    qcTRDct
    qcTRDct [OP] New Member
    2022 ORP KDSS
    Pretty sure they were only on 06 and 07 FJ's. That means if you do find one, you have the old style V6 with the oil filter mounted on top of the engine. Oh how I miss that. You also would have a weaker rear end that was prone to failure, and the potential for fender bulge. Luckily none of those things happened with mine, just the frame rotted out :annoyed:
  2. Jul 1, 2024 at 3:32 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Totally agree, quicksand looks like someone got sick. :puke:
    qcTRDct[QUOTED][OP] likes this.
  3. Jul 1, 2024 at 3:35 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Voodoo looks like smurfs poop. I'm just being funny.
  4. Jul 1, 2024 at 3:38 PM
    I want to disagree with you and insult you for attempting to slander my beloved Blue Tacoma, but I can't. You're right. That color actually glowed in the dark. No shit, you can tell what color it is at night in the dark.
    hossler1788[QUOTED] likes this.
  5. Jul 1, 2024 at 3:38 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    That's the green they came out with in 2023(?)
  6. Jul 1, 2024 at 3:38 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    :drool:
  7. Jul 8, 2024 at 1:02 PM
    ToyotaKingDave
    ToyotaKingDave New Member
    Dave
    2012 Sport
    I could tell you, but then I would have to .. you know, the thing.... let's just say they are the real numbers... don't ask how for another 2 years when I can retire
  8. Jul 8, 2024 at 1:06 PM
    ToyotaKingDave
    Dave
    2012 Sport
    All my Army and Special Ops guys got quicksand.. unfortunately it is no longer an option
  9. Jul 8, 2024 at 1:16 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    In 2022 I liked Lunar Rock and the wife liked Army Green, we ended up with AG(happy wife thing…). I’ll tell you what, to my amazement we have gotten so many comments on it I can’t believe it, the wife is in pig-poop I-told-you-so heaven. Army Green is a loud color without being loud, it always seems to draw attention. About every fifth time I fuel up or park/loading up at Costco someone asks what the color is called or did I get it painted that color.
    RLTW likes this.
  10. Jul 8, 2024 at 1:17 PM
    ToyotaKingDave
    Dave
    2012 Sport
    This one is incoming and still available...MSRP plus tax and title.. recomend the rust proofing and undercoating.. if you don't think you need it.. you should be buying a Pacifica or a Traverse...:mudding:
    LCfrontb7f72363290d4ba1122c8936fb2259ed22bc05081dbbb8c3c39417c08b5111dc (1).png
  11. Jul 8, 2024 at 2:55 PM
    ToyotaKingDave
    Dave
    2012 Sport
    The last time I was on these boards I was getting a 4Runner "Highlander Edition" from a dealer in Anchorage Alaska for an Insurance Agent in St Louis
  12. Jul 8, 2024 at 3:08 PM
    I appreciate you trying to sell me a Toyota over the internet.
    However..... when I said "FJ" I was referring to the FJ Cruiser's from the mid 2000's. That's the only FJ that comes in VooDoo blue. I don't care for any of those other lesser blues!
  13. Jul 8, 2024 at 3:32 PM
    qcTRDct
    2022 ORP KDSS
    That's Heritage Blue, I think. And interestingly, the LC250's come pretreated inside the frame from Toyota!
  14. Jul 8, 2024 at 3:37 PM
    Lunar Rock #1
  15. Jul 8, 2024 at 4:11 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    it was just the opposite in my world, I wanted AG and she pushed me for the LR.
    2ndGen22re[QUOTED] likes this.
  16. Jul 8, 2024 at 4:32 PM
    2ndGen22re
    CR
    Carson Valley, NV
    AG was my second choice. Momma and I agreed which ever color came in first optioned (KDSS & MTM) with what we wanted we would buy.
  17. Jul 14, 2024 at 1:42 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I finally snagged an opportunity for a surreptitious snap.
    java, Spare Parts and Reldn like this.
  18. Jul 14, 2024 at 3:22 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    You're gonna want that TruCoat.
    That looks better than I expected.
  19. Jul 14, 2024 at 3:39 PM
    #49
    backpacker
    2023 TRD ORP
    He normally parks facing the house. This was a rare exception providing a clear view of the bumper. Note that he replaced the Pro rack with the regular roof rails and aftermarket cross bars.
  20. Jul 14, 2024 at 6:16 PM
    #50
    qcTRDct
    2022 ORP KDSS
    Excellent spy work.. I'm not sold though
  21. Jul 14, 2024 at 6:20 PM
    #51
    backpacker
    2023 TRD ORP
    It's not my favorite bumper, but I thought the color match was good.
  22. Jul 14, 2024 at 10:10 PM
    #52
    qcTRDct
    2022 ORP KDSS
    Oh I agree, the match looks perfect
  23. Jul 15, 2024 at 2:35 PM
    #53
    LastRide
    LastRide New Member
    2024 Limited - Classic Silver
    You are either living right or just downright lucky. That's a great looking 4Runner, and I love that color! Congrats!
  24. Jul 15, 2024 at 3:03 PM
    #54
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    There was no trd pro rack till 2019. So that's the factory rack.
  25. Jul 15, 2024 at 3:21 PM
    #55
    backpacker
    2023 TRD ORP
    Ahh, so that's the deal. I don't recall ever seeing anything mounted on it.
  26. Mar 16, 2025 at 7:20 AM
    #56
    2753
    2753 New Member
    I have a Lime Rush 4Runner. If it were white, I'd be wandering the parking lot forever. I know purists love mud colors but I have received more comments from people that like my color. I walk out the door of a store and immediately say "There it is".
  27. Mar 16, 2025 at 7:51 AM
    #57
    vthoky New Member
    I love my Underground, but I think the Cement is a great color too.
  28. Mar 16, 2025 at 8:13 AM
    #58
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    We love our white ‘22 SR5 Premium 4WD T4R. Wifey’s 2021 RAV4 XLE Hybrid AWD is also white.
    Having two white vehicles wasn’t intentional, but it just worked out that way at the time- I was looking at several clean pre-owned / certified 4Runners, Barcelona red, Black, Dark Blue and my white one which was the best of the bunch that I was looking at at the time- lowest miles, condition, and most importantly, my white one didn’t have the third row seat. I didn’t need or want the third row seat. Plus we figured white would be good for reflecting some of this hot central Texas sun in the summer. No regrets.
  29. Mar 16, 2025 at 8:37 AM
    #59
    STrooper
    STrooper Let’s Go Places!
    At the time of retouching/repaint, you’ll be extremely happy you got a white 4R.
    “The coolest colors” are a complete PITA to match.
  30. Mar 16, 2025 at 1:51 PM
    #60
    Imdav2u
    23 TRD PRO
    Hey................, nothing wrong with Ice Cap (boring ass white). I wanted Terra.
