Saker’s Ebony Build
Discussion in '5th Gen Builds (2010-2024)' started by Saker, Apr 13, 2022.
  1. Apr 13, 2022 at 6:29 PM
    Saker [OP] New Member
    21 Black T4RORP
    September 27, 2021
    Installed USR Black-Out LED Tail Lights
  2. Apr 13, 2022 at 6:30 PM
    21 Black T4RORP
    October 1, 2021
    Side Mirror Turn Signal Black-Out Mod
    End results:
  3. Apr 13, 2022 at 6:31 PM
    21 Black T4RORP
    December 06, 2021
    Installed Cornfed 1" Rear Spacers
    EIBACH Rear Shocks, 0-2" Lift
    2.0 Shocks E60-82-008-02-01
    (Spacer offset the 1/2” of height I lost when I moved my rear tire and installed my [MENTION=602811]ctnewman[/MENTION] rear tire carrier.)
    MTB Chris likes this.
  4. Apr 13, 2022 at 6:32 PM
    21 Black T4RORP
    December 23, 2021
    Installed EIBACH 2.0 Coilovers
    E86-82-071-01-20
  5. Apr 13, 2022 at 6:34 PM
    21 Black T4RORP
  6. Apr 24, 2022 at 4:34 AM
    trktwo
    trktwo New Member
    2019 4runner SR5 4wd
    Nuttin
    tastefully done.
    5six, Saker[OP] and Han4Run like this.
  7. Apr 24, 2022 at 7:17 AM
    Han4Run
    Han4Run New Member
    NY
    2019 4Runner Pro
    Great mods. Very well done.
    Saker[OP] likes this.
  8. May 15, 2022 at 5:49 PM
    21 Black T4RORP
    May 14, 2020
    Hood Bulge Matte Black
  9. Sep 3, 2022 at 2:51 PM
    21 Black T4RORP
    a66 and CraigOutside like this.
  10. Jan 23, 2023 at 6:35 AM
    CraigOutside
    CraigOutside New Member
    Billerica, MA
    2022 Toyota 4Runner TRD Sport
    What exactly are the front and rear valances? Why did you wrap them with xpel? Just curious, I like the detail you used to track your build; nice work!
  11. Jan 23, 2023 at 10:26 AM
    21 Black T4RORP
    Front and rear valances are on TRDORP and TRDP’s. They are the pieces on the front and rear you see in the photos that come silver on TRDORP’s and they come black on TRDP’s. I’m not a favor of the silver so I initially had them wrapped in my opinion with one of the best wraps, Xpel.
    Since then I changed the front and rear valances with black TRDP valances.
  12. Apr 2, 2023 at 10:46 PM
    scfw0x0f
    scfw0x0f New Member
    2021 ORP
    As usual, a great series of posts.
    What fuse tray did you use? It looks smaller than a lot of the ones that require moving other bits around in the engine compartment.
  13. Apr 3, 2023 at 2:28 AM
    21 Black T4RORP
    I fabricated it myself from a raw piece of aluminum.
    T in Texas likes this.
  14. Sep 21, 2023 at 9:15 PM
    Nelson-ohio
    Nelson-ohio New Member
    2023 4Runner Off Road Premium
    Working on it
    Really cool looking truck. The rear tire mount, is that a SSO product? I see there is mentioning of ctnewman, not sure if that's a place you can buy from or not.
  15. Sep 21, 2023 at 10:41 PM
    21 Black T4RORP
    Thanks for the kudos on my truck!
    ctnewman is the brains and mechanical engineer that made 6 carriers counting his. He told me he was only going to make 5 and that was it. I got the 1st one he made in the 5 lot batch.
    SSO talked with him after seeing mine and another gentleman that has an off center carrier and now SSO is making them here in Baton Rouge, LA.
    Check out Southernstyleoffroad to see what they offer.
    By the way, this carrier is built better than any others out there.
    Here is his (CT’s)original thread for the carrier.
  16. Jan 18, 2024 at 11:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Saker
    Big fan of the build, your 12v work, and particularly - this tire carrier!
    Any chance you can provide an update on the creator CT, and where folks could find a similar carrier as impressive as CT's, since I believe SSO switched ownership/management
    Thx
  17. Jan 19, 2024 at 6:26 AM
    21 Black T4RORP
    Thanks you sir.
    I’m a fan of making things under the hood as neat and “OEM looking” as possible. CT is doing his thing of making CNC custom high quality motorcycle parts. ctnewmanengineering.com
    As well as his regular career job.
    I understand that the new owner of SSO is filling all orders SSO had on the books.
    Maybe try to reach out to the current owner.
    djwantke[QUOTED] likes this.
  18. Jan 19, 2024 at 9:04 AM
    I see I see, thanks very much for this info.
    I heard that about SSO as well, but for now the drama has scared me away - I'll let the dust settle and watch for folks reporting that they've finally recieved their orders and such.
    Saker[QUOTED][OP] likes this.
  19. Jan 21, 2024 at 4:00 PM
    #49
    21 Black T4RORP
    January 21, 2024
    Installed Odyssey 34R-PC1500T
  20. Jan 21, 2024 at 4:03 PM
    #50
    21 Black T4RORP
    January 21, 2024
    Installed Voltage Booster PRO "The O.G." (5th Gen 4Runner) - B (2020-2023 4Runner
  21. Jan 21, 2024 at 4:10 PM
    #51
    21 Black T4RORP
    January 21, 2024
    Voltage Reading After Installed Voltage Booster PRO
  22. Feb 11, 2024 at 4:37 PM
    #52
    21 Black T4RORP
    February 7, 2024
    Installed Bilstein 6112’s & 5160’s
    raimieb likes this.
  23. Feb 11, 2024 at 6:21 PM
    #53
    HarrisNC
    HarrisNC New Member
    2022 Limited
    Interested to hear your opinion on the Eibach vs the 6112. I had the Eibach 1.0 on my 2018. No major complaints, just stiffer than I wanted. I’ve been looking at the 6112 to replace the xreas on my 22
  24. Feb 11, 2024 at 8:41 PM
    #54
    21 Black T4RORP
    I had the same set up on my previous T4R and was happy. I prefer the Bilsteins, they offer a different ride.
    That’s just me!
  25. Mar 15, 2024 at 4:44 PM
    #55
    21 Black T4RORP
  26. Mar 16, 2024 at 3:12 AM
    #56
    Dawglover08
    Dawglover08 New Member
    Jordan
    Atlanta
    2020 TRD ORP
    Which valances did you buy?
  27. Mar 16, 2024 at 7:34 AM
    #57
    21 Black T4RORP
    I bought Toyota OEM Black ones that come on the TRDPro’s from my local dealership.
  28. Mar 16, 2024 at 10:10 AM
    #58
    Dawglover08
    Jordan
    Atlanta
    2020 TRD ORP
    You have part numbers?
  29. Mar 16, 2024 at 10:27 AM
    #59
    21 Black T4RORP
    Yep, easily found on the interwebz
    53901-35250
    52169-35120
  30. Mar 31, 2024 at 4:33 PM
    #60
    21 Black T4RORP
    March 31, 2024
    Added a Little Light
    TroutMan and Dawglover08 like this.
