Rusted OEM parts on 2019 4Runner or replacement parts?
Discussion in '5th Gen 4Runners (2010-2024)' started by BeachgirlTX, Aug 29, 2023.
  1. Nov 26, 2023 at 8:05 AM
    #151
    Pavo
    Pavo New Member
    I live in SoCal and I have seen Tacomas and 4Runners that live near the beach in San Diego and Orange County all their lives (original owners never left SoCal) and they were heavily rusted with the rust flaking off of course the owners never treated it assuming they lived in SoCal and didn’t have to
    mrmike7189 likes this.
  2. Nov 26, 2023 at 8:08 AM
    #152
    Oakboro, N.C
    Was hoping to hear that all the parts mysteriously got swapped back onto the Runner.
  3. Nov 26, 2023 at 9:57 AM
    #153
    Very curious that OP has 24 posts, all in this thread, beginning at the end of August, last at the end of October. Nothing else...
    Technologic80 and djwantke like this.
  4. Nov 26, 2023 at 10:10 AM
    #154
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I believe that the OPs account is the daughter of @Sandbuster. He is a stand-up guy and very capable. If I recall correctly, the two of them worked on their trucks together. To me, this looks more like an account hack. That would explain the "trolling" that she is being accused of.
    djwantke and gomiami like this.
  5. Nov 26, 2023 at 10:35 AM
    #155
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    DUDE, you're right about this, I never looked hahah
    That's literally one of the first red flags of unusual behavior when trying to spot a bot or troll.
    Very curious indeed sir
    Technologic80 likes this.
  6. Nov 26, 2023 at 10:40 AM
    #156
    Oakboro, N.C
    May be for a thesis being worked on in regards to social media experiences/reactions. :notsure:
  7. Nov 26, 2023 at 10:50 AM
    #157
    @glwood54
    @gomiami
    @mrmike7189
    I experienced the same frustrations with lack of detail regarding the ban. Pretty sure it's just an auto message we receive. By design, you get no conversing, you don't get the satisfaction, what you do get is vague smugness.
    :p
    Without saying it, gomiami, I'm fairly certain it's from quoting the "G" word indirectly.
  8. Nov 26, 2023 at 11:37 AM
    #158
    2Toys
    Gordon
    2019 4Runner TRDORP
    After looking at OP's account and posts - I am wrong about this being the daughter of @Sandbuster. She had her account long before this person. I retract my statements regarding an account hack.
