Rusted OEM parts on 2019 4Runner or replacement parts?
Discussion in '5th Gen 4Runners (2010-2024)' started by BeachgirlTX, Aug 29, 2023.
  1. Sep 7, 2023 at 5:37 PM
    #61
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Or perhaps scenario "C", actually believes someone replaced everything below the body with someone else's rusty parts?
    Bizarre, but maybe the most entertaining if it is actually pursued.
    Technologic80 and mrmike7189 like this.
  2. Sep 7, 2023 at 6:33 PM
    #62
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    That's literally my scenario B
    5thToy likes this.
  3. Sep 7, 2023 at 6:34 PM
    #63
    True, or possible, that's left to be seen lol
  4. Sep 7, 2023 at 6:36 PM
    #64
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Lets consider what it would require to pull it off:
    1. Having the old replacement parts on hand to swap in
    2. A bunch of complacent employees who wont squeal on you
    3. A fence to sell the slightly newer used parts to, and they'd have to pay more than the cost of the labor and parts you swapped in at least.
    The risk is losing your shop, getting arrested, and losing your livelihood. The cost of shipping the old parts that you'll swap in will cost money, the cost of doing the deed will cost time and money, and then you have to find the perfect buyer whose willing to pay enough money to make it worth your while. Meanwhile your taking a huge risk.
    The risk vs reward is terrible
    Technologic80 likes this.
  5. Sep 7, 2023 at 7:48 PM
    #65
    Indeed it is
  6. Sep 7, 2023 at 7:55 PM
    #66
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    Underrated film
    djwantke[QUOTED] likes this.
  7. Sep 7, 2023 at 7:56 PM
    #67
    Ramrod88
    New Orleans
    22 TRD OFF ROAD
    And I doubt we’ll hear from troll beach TX again
  8. Sep 7, 2023 at 8:01 PM
    #68
    Ramrod88
    New Orleans
    22 TRD OFF ROAD
    Guys, I spent 20 days in the hospital for appendix removal surgery and they swapped out my skeleton with some old arthritic bones but left my young cartilage and tendons in place. How’s that sound?
  9. Sep 7, 2023 at 8:50 PM
    #69
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Sounds legit. I feel that way every morning. It has to be someone's fault.
  10. Sep 7, 2023 at 8:54 PM
    #70
    backpacker
    backpacker New Member
    2023 TRD ORP
    That's what you get for waking up.
  11. Sep 7, 2023 at 9:02 PM
    #71
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    :D
  12. Sep 8, 2023 at 2:00 AM
    #72
    Matt83
    Matt83 New Member
    Northeast
    Fantastic movie. I might have to watch that tonight.
    djwantke likes this.
  13. Sep 8, 2023 at 6:56 AM
    #73
    Texrun50
    Texrun50 New Member
    2023 TRD ORP - Silver, Factory Off-Road Upgrade Package (black TRD wheels,sliders, etc.)
    None
    This thread has been the funniest of any I can recall of late. Please, please, please post the inspection report from the professional. I’m begging…
  14. Sep 8, 2023 at 9:59 AM
    #74
    beedee
    beedee Member
    When is Inspector Gadget going to take a look?
  15. Sep 9, 2023 at 7:11 AM
    #75
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    I would say "Girl...You need to wash your undercarriage. It's crusty down there. You dirty girl":D:nuclear:
  16. Sep 9, 2023 at 9:56 AM
    #76
    joshdub
    joshdub New Member
    2020 TRD ORP
    There is always one that needs to make it weird
  17. Sep 14, 2023 at 7:22 AM
    #77
    3JOH22A Toyota Gigolo
    Dude, your extracted young bones paid for the surgery!
    mrmike7189 likes this.
  18. Sep 30, 2023 at 10:13 AM
    #78
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    so what did the legal auto inspector say?
  19. Sep 30, 2023 at 1:41 PM
    #79
    Oakboro, N.C
    What if the dash with the VIN plate got swapped between two vehicles.. Could that be a viable option to this wild scenario?
    BeachgirlTX[OP] likes this.
  20. Sep 30, 2023 at 3:01 PM
    #80
    TheGreekFreak
    TheGreekFreak New Member
    There is no way a shop took effort to swap in perfectly usable but surface rusted parts, including the frame, for yours that you assume were pristine before the repair lol. The rust level is consistent throughout, no chance you convince anyone of this unless the frame number looks tampered with.
    If a shop pulled off such a conspiracy level operation, it would literally cost them more money than what they’d make on having some slightly nicer used parts to sell in place of the ones they swapped in.
    It’s not pretty but I’ve actually seen worse. Need to invest in some oil based undercoating going forward to stop the rust cancer from spreading.
  21. Oct 14, 2023 at 1:23 PM
    #81
    BeachgirlTX
    BeachgirlTX [OP] New Member
    OEM Rusty Parts?
    2019 4Runner
    Hello fellow critics, I’m so glad I was able to place a “funny troll post “ for some of you guys to acknowledge with your expertise!
    I have since found a few new things never seen on my T4R?
    There is an old sticker on my windshield never had before on drivers side.
    Maybe you can make it out has Toyota car and something else it’s real faded and looks like someone tried to take it off.
    Not my sticker!
    Now the windshield is cracked from top my roof on the connection point of frame of car.
    No big deal but I have before and after pictures windshield doesn’t matchup to all letters on this windshield with old sticker?
    I do have before and after pictures of this sticker not being there by the way!
    Next on all 4 door jams I never noticed there are now orange stickers with NSD tracking numbers for Law Enforcement to track my T4R?
    Maybe you can tell me if this is on all 2019 T4R Maybe never noticed until now?
    I tried calling the number on sticker NSD is In Florida. No answer? FYI looks like a aftermarket company will be contacting dealerships to find out if NSD is a tracking company they use on T4R 2019?
    Next stopped by a car inspector and they inspect certain check off list of mechanical for people buying used cars.
    Inspector does not specialize on the undercarriage, that I need to address.
    Maybe, you can advise what type of inspection or place I can go to to do this type of inspection?
    I did contact Toyota Support to get my engine number on block and am relieved to know
    It is my engine went by a T dealer and he was able to provide on the ground the correct number on my block.
    Lastly on drivers door jam the Vin sticker has been tampered with looks like someone tried to scrape it off with no luck!
    Well I’m contacting back Toyota support as the guy at dealership said something about inside body of doors has ID numbers to matchup and I will see what other parts to my body frame can help to identify if this T4R is all mine or just parts placed back on to help possibly shop guy who by the way is from Florida…
    May have to go to a new body shop get it throughly inspected.
    I hope I’m wrong.. but I’m still paying for this beast and it better be my T4R rust and all!
    Oh yeah thanks for the vin number being on the backside of passenger wheel, I’ll have to check it out!
  22. Oct 14, 2023 at 1:42 PM
    #82
    Ramrod88
    New Orleans
    22 TRD OFF ROAD
    ok I totally believe you now. The last photo of your dash and windshield did it for me. They also swapped your dash out with something from a completely different vehicle. Maybe a Honda???!!!
  23. Oct 14, 2023 at 1:50 PM
    #83
    Dang that's a lot of fishy stuff goin on @BeachgirlTX
    That shop is shady AF
  24. Oct 14, 2023 at 1:52 PM
    #84
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Not only that but that vehicle in the last pic is most likely a 2023 model year. Texas only issues a 2 year sticker for brand new vehicles when the are registered and titled. With an expiration of 3/25, that vehicle in the picture was purchased as a new vehicle in March of 23.
    Even if I renewed my registration today on my 2021, it would expire in Oct 2024.
  25. Oct 14, 2023 at 1:53 PM
    #85
    Ramrod88
    New Orleans
    22 TRD OFF ROAD
    Fishy is inadequate. I may roll the dice and leave mine there for a week and if im really lucky, they'll do an LS swap for free
  26. Oct 14, 2023 at 1:54 PM
    #86
    Ramrod88
    New Orleans
    22 TRD OFF ROAD
    you're right. They changed the dash for the 2023 model
  27. Oct 14, 2023 at 2:16 PM
    #87
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Armchair internet detective here - what I see are pictures of a white vehicle until the last one, where it seems to change to MGM type color hood
    Texrun50 likes this.
  28. Oct 14, 2023 at 2:19 PM
    #88
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
  29. Oct 14, 2023 at 2:22 PM
    #89
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
    Thanks TrueTexas I will go to our DMV where I got my sticker to have them lookup my info
  30. Oct 14, 2023 at 2:43 PM
    #90
    BeachgirlTX
    OEM Rusty Parts?
    2019 4Runner
    What?? Really?
