Rubbing only on one side with larger tires
Discussion in 'Wheels & Tires' started by NewDad, Jan 3, 2023.
  1. Feb 13, 2023 at 11:21 AM
    NewDad
    NewDad [OP] New Member
    2014 4Runner Trail
    King remote reservoir shocks, ultraswing rear tire mount, winch
    I believe they are 8” wide. No trimming necessary or heat gun testament. The 2.5” lift and off-road front bumper took care of that need so I’m no help to you there. Sorry. I did get some positive caster on the front wheels with a recent alignment. Had to talk the shop into doing it. No more rubbing but it does pull a little bit to the left now. Still not super happy about the whole set up but glad not to have the rubbing any longer!
  2. Apr 24, 2023 at 1:21 PM
    stoney69
    stoney69 New Member
    Hi everyone, so glad i found this Thread. I too am experiencing this on an 04 V8 sport with Bilstein lift and Nitto Grappler LT 285/70/r17s. For me it "looks" like it's hitting the right front stabilizer bar but hard to tell. I plan to take to the shop that did the tires, and they did do a full alginement again, but some here are saying the caster should be at 4 degrees? My settings final were Caster 2.8 LF, 3.1 RF Camber .1LF -.1 RF. I'm hoping this can be dealt with with a better alignment? I'm just slightly upset the 4 wheel place did not test this before with a drive in a circle.
  3. Apr 24, 2023 at 2:47 PM
    NewDad
    2014 4Runner Trail
    Well it turns out there were 1” spacers on the rig I bought. The alignment shop did not inform me that they were on there nor did the person I purchased it from. They made it look badass but we’re also the cause of the rubbing. I took it to a wheels and tire place and they let me know they were on there. Once removed (which they did for free! Love those guys now) it solved the rubbing issue and a few others issues also.
    nimby and djwantke like this.
  4. Apr 24, 2023 at 4:48 PM
    stoney69
    stoney69 New Member
    So for me, it turns out since I was being frugal and kept the stock wheels, the nittos ended up being just a hair wider and the wheel offset wasn’t enough so was hitting the sway bar. I just ordered 1.25 in spacers and getting a body chop. Guaranteed to solve the issue from what my shop is saying after doing a ton of these.
    djwantke likes this.
  5. Apr 24, 2023 at 4:59 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
