Roof rack recommendations
Discussion in '5th Gen 4Runners (2010-2024)' started by MontanaMarine, Aug 29, 2023.
  1. Aug 31, 2023 at 10:51 AM
    San Angelo
    San Angelo New Member
    I was wondering something similar. I was thinking of something smaller like some wheel well lights for camping or tailgating and not taking to much of a hit on the battery
  2. Aug 31, 2023 at 10:54 AM
    We get it. Some don't.
  3. Aug 31, 2023 at 11:09 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Nice! I'll surely be interested watching your progress.
    I'm too cheap for overpriced Baja Designs or Doides and such. But I'm in the middle of mounting and wiring roof rack side angle scene lighting, and rear roof rack chase light. Also completed under bumper reverse cree led lights straight to battery w/ dash switch.
  4. Aug 31, 2023 at 11:25 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Expensive, yes, overpriced, not sure. They really support off-road racing (similar to BFG) and I like to support companies that support off-road racing. They have an amazing reputation on warranties too.
  5. Aug 31, 2023 at 11:32 AM
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    You absolutely cannot go wrong with any of WD products as I have several including the low profile roof rack with a 40" Rigid light bar. I do not have any lights running off the side but they are out there of course. The lead times are well worth the wait along with their top notch customer service. They also offer military discount if you are a vet too.
  6. Aug 31, 2023 at 11:37 AM
    Sure yeah I can get behind that. I hear ya. I have a local Canada owned automotive chain where the price is right so they got me. Cheers
  7. Aug 31, 2023 at 11:38 AM
    coryanderson
    Cory
    Teacher, not too many discounts out there for teachers.
    How is the glare on the light bar? I'm thinking of going the 10 - 4" round light cutout version, I've heard too many people complain about the glare.
  8. Aug 31, 2023 at 12:33 PM
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    Well thanks for what you do my friend. I really don't think it's that bad when I'm running it. I saved some money when I bought the lights directly from Rigid and then picked it up at their facility. All I paid was for labor on install.
    I know they did start running black Friday sales and they do run specials on labor every once in awhile too. If I hear anything I will definitely let you know.
  9. Aug 31, 2023 at 4:16 PM
    blksubykid
    blksubykid New Member
    Pics after install...or it never happened! :)
