Roof Line Lights
Discussion in 'Lighting' started by PVT Pablo, Aug 25, 2021.
  1. Jul 6, 2023 at 3:55 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    At night the "spot lights" illuminates blue with the rest of the interior lights. When the roof lights are on the little spot beams also illuminate. The switch is wired into the high beams, so if the button is depressed (on) the roof lights will also come on when the high beam stalk is pulled. Alternatively if you don't want the roof lights with the high beams just turn the spot light switch off. It's pretty slick how the shop did it.
    Thacrow[QUOTED] likes this.
  2. Jul 6, 2023 at 4:06 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    yeah that's pretty clean they did a good job thank you for sharing
    PVT Pablo[OP] likes this.
  3. Jul 17, 2023 at 4:33 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Finally got some action shots
    Picture 1 and 3 are no roof lights. Pictures 2 and 4 are with. The glare off the hood despite what the pictures show is negligable compared to the light down range.
    djwantke and Yossarian like this.
  4. Jul 17, 2023 at 5:40 PM
    Yossarian
    Yossarian New Member
    2014 Forester, 2023 4Runner SR5P
    Forester: Diode Dynamics fogs, light bar, and aux reverse lights 4Runner: DD Fogs
    Man that's some incredible throw on those. If I didn't need my roof rack for transporting kayaks I'd get a setup like yours today.
  5. Jul 17, 2023 at 5:47 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    It definitely turns day to night. I feel ya on the kayak thing, I have to awkwardly put my paddleboards up there and just lay em on the lights. Probably not even an option for a kayak.
    They do however make A pillars mounts. I imagine a 6" round light on a A pillars would be little excessive. A smaller light would work great though.
  6. Jul 17, 2023 at 6:36 PM
    Yossarian
    I've considered it, I've found pictures of people putting 6" Rigids on their A pillars. rigid 6 in light 1.jpg R1000T4RUDIT_Installed_01.jpg
    But what I really want is this custom light mount.
  7. Jul 17, 2023 at 6:49 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    I do like that grill mount a lot. Mounting there is all the upside without any of the downside
  8. Jul 17, 2023 at 7:06 PM
    Yossarian
    Me too, unfortunately it was a one off and I can't get in touch with the guy to find out if he'd be willing to make another or sell the one he has, so I'm in the process of getting quotes from some fab shops.
    PVT Pablo[QUOTED][OP] likes this.
  9. Jul 17, 2023 at 9:17 PM
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Flip the lights over on that grill light rack and it would be awesome! It covers too much of the TOYOTA or sombrero!
  10. Jul 17, 2023 at 10:37 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    A-pillar wire hiders, yeah!
    Super nice 4R dude well done
  11. Jul 17, 2023 at 10:50 PM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Thanks man! Scene lighting is next on the agenda ;)
  12. Jul 18, 2023 at 7:38 AM
    Scene lighting eh? Do explain
  13. Jul 18, 2023 at 8:38 AM
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Sorta the same concept you have with your lights in the corners, pointing 360 degrees. Make it easier to set up camp, etc.
    djwantke[QUOTED] likes this.
