Rock slider recommendations?
Discussion in '5th Gen 4Runners (2010-2024)' started by dethinboots, Mar 26, 2019.
  1. Mar 17, 2024 at 8:10 PM
    #211
    Justkelvin
    Justkelvin New Member
    2023 TRD off road premium
    I purchased skid plates and front bumper from C4 Fabrication. Would recommend anything fabricated by them. Definately top shelf products. Only thing is everything comes raw steel.
    Also got molle panels and shelves from Cali Raised great products also.
    Both companies will answer a phone and talk when you call, very good costumer service.
  2. Mar 19, 2024 at 10:38 AM
    #212
    jake long15
    jake long15 Cali Raised LED
    Thanks for the support we appreciate it! If you need anything please reach out:)
    Justkelvin[QUOTED] likes this.
  3. Mar 29, 2024 at 6:55 AM
    #213
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Just installed RSG sliders. Bought them as raw metal so I also painted them myself.
    advice -
    do not diy this. It was such a pain in the ass. Whatever it costs for the shop to install.. it’s well worth the $$$
  4. Mar 29, 2024 at 7:19 AM
    #214
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Are you saying the install is not DIY or the paint/powder coat? I have the RSG but had them powder coat them. Only drawback of this is sometimes the powder coat can get damaged in shipping. I had no issues with this.
  5. Mar 29, 2024 at 7:20 AM
    #215
    DIY which part? Painting, installing, both?
  6. Mar 29, 2024 at 7:22 AM
    #216
    Yobruhitsme
    Denver
    Ineos Grenadier
    Some unexpected work:
    painting the sliders was more work than I imagined. watching those YouTube videos made it seem like a cake walk… took me two days, applying the coats..
    for installation.. had tap all thread holes in my new frame…
    dealing with the kdss components were a pain in the ass.
    doing all of the above at home, crawling around… my time was worth more than the multiple days I signed myself up for.
    end result is close to zero self satisfaction.. whatever I learned from doing this has no future diy automotive applicability.
    basically an utter waste of time
  7. Mar 29, 2024 at 7:25 AM
    #217
    2021venture
    Todd
    2021 Venture
    Painting I agree it's not worth my time. No experience with KDSS, but mine I bolted up solo in an hour. Only trick was finding something the right height to support them to get couple bolts started.
  8. Mar 29, 2024 at 7:27 AM
    #218
    Yobruhitsme
    Denver
    Ineos Grenadier
    Had to loosen bunch of kdss hardware to fit the slider behind.
    Then also had to cut up a kdss skid cover - this additional labor perhaps limited to rsg’s subpar design.
    I am actually doing another cut today.. the opening I cut last night was a bit too small, to clear the slider tube comfortably… sigh more manual labor
  9. Mar 29, 2024 at 7:32 AM
    #219
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Just going to throw this out there - the Wescott Designs sliders on my truck required no modifications whatsoever on my KDSS equipped T4R.
    RLTW likes this.
  10. Mar 29, 2024 at 7:36 AM
    #220
    Same here - ordered powder coated. One box went astray, got rerouted, and took a few days longer to arrive. One small corner of a mounting bracket got nicked, but some black bedliner paint covered that. It also was on a spot that doesn't show anyway. But a valid point about shipping possibly causing PC issues.
    Sorry for your troubles. I had a friend help, and we knocked out the install on my KDSS OR in just over an hour. No thread chasing/tapping involved. After he left, I trimmed the corner of the KDSS skid, reinstalled, done.
    Yobruhitsme[QUOTED] likes this.
  11. Mar 29, 2024 at 7:41 AM
    #221
    backpacker
    backpacker New Member
    2023 TRD ORP
    I plan to eventually get the RSG sliders and install them myself. I'm definitely going to get them painted, though. I was already expecting to have to chase all the frame holes.
  12. Mar 29, 2024 at 7:41 AM
    #222
    Yobruhitsme
    Denver
    Ineos Grenadier
    Wow no tapping huh?
    On my frame, even the holes that have existing brackets installed, I had to tap them… perhaps Toyota sprayed something by into them, after installation of hardware?
  13. Mar 29, 2024 at 7:47 AM
    #223
    I'd read plenty of suggestions to chase the threads, but when I went to install I checked several threaded holes with the bolts provided by RSG and found no issues with the threads. All 20+ bolts threaded in fine. Maybe Toyota has changed some frame process since 2019.
  14. Mar 29, 2024 at 7:47 AM
    #224
    backpacker
    2023 TRD ORP
    Probably just paint.
  15. Mar 29, 2024 at 7:53 AM
    #225
    2021venture
    Todd
    2021 Venture
    What are you guys using for touch up on powder coating? This would be my only argument to not powder coat knowing it will get damaged with use.
    Both my kick outs have done their job and powder coat removed. Not sure if a truck bed liner or something else will match good enough. Not looking for perfect just adequate match at a glance.
  16. Mar 29, 2024 at 8:21 AM
    #226
    Yobruhitsme
    Denver
    Ineos Grenadier
    Why don’t any of these slider manufacturers provide guidance!?
    There is literally zero info from any of them
  17. Mar 29, 2024 at 8:29 AM
    #227
    backpacker
    2023 TRD ORP
    I've been planning to touch up with Rustoleum. That's what I use on my skids and rooftop basket.
  18. Mar 29, 2024 at 8:32 AM
    #228
    2021venture
    Todd
    2021 Venture
  19. Mar 29, 2024 at 9:04 AM
    #229
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    what size thread chaser are you guys using?
  20. Mar 29, 2024 at 9:12 AM
    #230
    steelevo
    Utah
    I just use rubberized undercoating in a spray can. Just make sure to remove any rust or oxidation prior to coating.
    2021venture[QUOTED] likes this.
  21. Mar 29, 2024 at 9:38 AM
    #231
    Any of the spray can bedliners, i.e. Rustoleum, Duplicolor, etc., would work for touch ups.
    steelevo and 2021venture like this.
  22. Mar 29, 2024 at 9:40 AM
    #232
    Didn't use one, but you could remove a mounting bolt from something on the frame and take it to the hardware store as a guide.
  23. Mar 29, 2024 at 9:42 AM
    #233
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    Some of the best sliders out on the market made by Jeff & his team at Westcott Designs! Same no issues installing with KDSS. Products made in house and will last a lifetime!!
    2Toys[QUOTED] likes this.
  24. Mar 29, 2024 at 10:54 AM
    #234
    DangitDad
    DangitDad New Member
    Ken
    2023 White 4Runner
    3"/2" Ironman lift, Method 703 wheels, K02's, Pedal Commander, more to come
    Having a friend to help install sliders would have made my install much easier. As it was, I'd still have done it myself. The expense of a shop doing it may have doubled the price.
    I need to find a friend...
    seakuv likes this.
  25. Mar 29, 2024 at 11:04 AM
    #235
    Yobruhitsme
    Denver
    Ineos Grenadier
    The thing with those is, if you get a chip that breaks the surface, moisture will start to collect underneath, making the rust situation worse
    same issue with bedliner
  26. Mar 29, 2024 at 11:04 AM
    #236
    Yobruhitsme
    Denver
    Ineos Grenadier
    M8x1.25 for the thread holes on 5g frame
    chasing took forever.. some of the holes to bolt the slider are very close to the body.. so you have to pinch the tap with an adjustable wrench and make 1/4 turns at a time..
  27. Mar 29, 2024 at 1:10 PM
    #237
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    Lol I had the exact opposite experience. Installed it myself at home with hand tools but then again I have Pelfreybilt sliders and no issues with the kdss getting in the way. I even had the discontinued RSG KDSS skid plate on when I installed the sliders. Painting the sliders is easy peasy and yeah it took me 2 days too between painting and drinking beers in-between the easy work.
  28. Mar 29, 2024 at 3:38 PM
    #238
    I just spray a layer of grease to the underside prior to hitting the trails. Truck slides easily over obstacles.
    seakuv likes this.
  29. Apr 2, 2024 at 7:53 AM
    #239
    Rieby
    Rieby New Member
    2023 TRD Pro Solar Octane
    I have the RCI rock sliders, top tread plate, satin black powder coat, 5 degree. No issues. Got them on sale last year.
