RIP 4Runner
Discussion in '6th Gen 4Runners (2025+)' started by Yotaholic, Apr 9, 2024.
  1. Apr 10, 2024 at 7:35 PM
    #61
    The 5th gen has been around for so long that people forget there are 4 generations of 4Runners before this with raked windshields. It's perverse that we have a 40th Anniv. edition and 15 of those years are on the same generation.
    akakaiser, Lc200 and HuskerRunner like this.
  2. Apr 10, 2024 at 7:37 PM
    #62
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Yup
    There's many more, actually
    Yotaholic[QUOTED][OP] likes this.
  3. Apr 10, 2024 at 7:40 PM
    #63
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Stellantis is screwing Jeep, I like to see Jeep under Mercedes again. Or like that English billionaire who showed his middle finger to Land Rover and built his own Grenadier, we need an American billionaire to step in and do something about Jeep.
  4. Apr 10, 2024 at 7:42 PM
    #64
    Yotaholic
    Olympia, WA
    Does anyone own a Ram here? Go on the Ram forums, folks are pretty pissed over there, Hemi is gone.
  5. Apr 10, 2024 at 7:48 PM
    #65
    The Grenadier with the BMW turbo inline-6 shared with the Supra?
    Also Jeep suffered under Mercedes ownership along with the rest of the Chrysler lineup. This was the Cherokee successor under Mercedes:
  6. Apr 10, 2024 at 7:53 PM
    #66
    Yotaholic
    Olympia, WA
    It doesn't have all the greatest parts, but it is a very cool old school vehicle. But I don't think that BMW inline 6 is too bad. I've never owned European cars so I don't know.
    I was talking about the wrangler, Wrangler did better under Damien Chrysler. And it also did really well under FCA. FCA did amazing things for Wrangler
    Curlystooge likes this.
  7. Apr 10, 2024 at 7:56 PM
    #67
    Yotaholic
    Olympia, WA
    Wrangler flourished under them, they introduce that long wheelbase 2 door unlimited tj, that's one of my most favorite
  8. Apr 10, 2024 at 8:08 PM
    #68
    Perry1060
    Perry1060 New Member
    Perry
    Toyota's do not die, they just all merge into the same platform, same engine, same turbo, same transmission, same hybrid motor, same first character 3 in the VIN, and one really really long concatenated badge name encompassing every model...just kidding
    broken-giver and Yotaholic[OP] like this.
  9. Apr 10, 2024 at 8:10 PM
    #69
    Yotaholic
    Olympia, WA
    But yes, they destroyed many Chrysler products. But Wrangler did really well under them, sales like tripled
  10. Apr 10, 2024 at 8:10 PM
    #70
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    It's nice but isnt it a lot slower than most decent aftermarket options?
    If I'm mistaken then yea nice to have!
    Honestly the interior looks pretty decent other than the slight decrease in leg room (I'm never at the back so I don't care all that much) and maybe the screen being a bit too big (but not a deal breaker for me)
    I like the trailhunter the most, color-wise and functionality. I've got a hard time with the exterior look wise and worse approach/departure angles
    I always said I never want to sell mine. If I were to get a new one it would be in addition to what I have. I can't see myself getting a 6th gen. Hopefully the 7th gen will be better like you posted above. Although I doubt it with EPA and all the bs going on. 5th gen will be the true last good 4R IMO
  11. Apr 10, 2024 at 8:13 PM
    #71
    Corolla Cross GR Platinum 1958 First Edition?
  12. Apr 10, 2024 at 8:21 PM
    #72
    broken-giver
    broken-giver BFD
    lol. I feel the same, but it’s sad when after 15 years all they could come up in 6th gen was “it’s not that bad”.
    Yotaholic[OP] and djwantke like this.
  13. Apr 10, 2024 at 8:22 PM
    #73
    broken-giver
    broken-giver BFD
    That is the right answer. Honestly gx looks way better than LC and certainly 6g4r
  14. Apr 10, 2024 at 10:09 PM
    #74
    4runningMan
    4runningMan New Member
    New Mexico
    anybody else or just me?
    mac1usa likes this.
  15. Apr 10, 2024 at 10:21 PM
    #75
    BigB_Money
    BigB_Money New Member
    Brian
    2020 White TRD OffRoad 4Runner
    Led Headlights, Low & Hi Pedal Commander Cooper Discoverer AT3 LT Bilstein 5100’s all around Front @ 1.75”, Rear 1”ish (30mm) Whiteline spacer
    Yep, This is a parts bin vehicle. A reskinned Land Cruiser with a Tacoma interior.
  16. Apr 10, 2024 at 10:25 PM
    #76
    4runningMan
    New Mexico
    Doesn’t the LC have a turbo 6?
  17. Apr 10, 2024 at 10:27 PM
    #77
    Yotaholic
    Olympia, WA
    An extremely awful treatment of a such a legendary nameplate. Not many were waiting for the new Landcruiser. But a lot of people were waiting for the new 4Runner. That new GX should have been the new 4Runner. Toyota screwed the 4Runner big time.
    2Toys and broken-giver like this.
  18. Apr 10, 2024 at 10:28 PM
    #78
    Yotaholic
    Olympia, WA
    No, all trims have the same stinking 2.4 that is in all these trucks except the new GX. Lexus knew their customers are not gonna buy some stupid 2.4 taken out of a Prius
  19. Apr 10, 2024 at 10:33 PM
    #79
    Perry1060
    Perry
    The very very very last 2024 5th gen that rolls out of the Tahara Plant may sell to a collector for a ridiculous price north of ____ ?? fill in the blank...
  20. Apr 10, 2024 at 10:34 PM
    #80
    Yotaholic
    Olympia, WA
    Buy the new GX, put Toyota letters in the front and 4Runner in the back, and show your middle finger to Toyota for being so lame.
    Shredder and Perry1060 like this.
  21. Apr 10, 2024 at 10:48 PM
    #81
    Yotaholic
    Olympia, WA
    2025 Toyota 4Runner TRD Offroad Premium with E-KDSS. Change my mind
    hazards280 likes this.
  22. Apr 10, 2024 at 10:48 PM
    #82
    4R777
    4R777 New Member
    I wonder what the original 6th gen design looked like before they scrapped it and started over.
  23. Apr 11, 2024 at 3:31 AM
    #83
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Yea the lever is manual, it does still directly engage the transfer.
    But that wasn’t my point! The guy I was responding to thought having a manual transfer meant there was nothing electronic to break- forgetting that two things happen when you engage 4H:
    1- shift the transfer case to 4
    2- engage the front end half shafts and diff to the front prop shaft.
    #2 has happened electrically in every Toyota made since the last T100 ditched manual hubs in the 90s I believe. So even with the manual lever ( which I have and like btw) there are still electronics involved.
    Yes, but even the Jeep has electrically disconnecting front axle system. Doesn’t work exactly the same as ADD but is still very much electronic.
    mac1usa[QUOTED] likes this.
  24. Apr 11, 2024 at 3:46 AM
    #84
    NoDak
    NoDak New Member
    JR
    North Dakota
    4th gen was great just for the v8. and personally i thought it looked pretty good compared to the 5th gen before the 2014 refresh.
    had one in silver and that was awesome, but man i would hate to fill that thing now a days with my daily commute, remote starts in -20F temps.
    but it was a hoot in winter time to play around with.
    LastRide likes this.
  25. Apr 11, 2024 at 3:50 AM
    #85
    broken-giver
    broken-giver BFD
    My sentiments, except I am still waiting to see it in person. Maybe it just looks better in person :(
  26. Apr 11, 2024 at 4:23 AM
    #86
    mac1usa
    mac1usa New Member
    Maybe it will grown on us as time goes on. Sort of like drinking on a Saturday and it approaches 2am closing time everything seems to look better. Suddenly that long hood does not look so bad and you sing kumbaya knowing you’re helping the environment.
    The key is to just keep drinking until they take that away from us also.
    Beachguy, 2Toys, LCJ77 and 1 other person like this.
  27. Apr 11, 2024 at 4:30 AM
    #87
    broken-giver
    broken-giver BFD
    lol that was very specific
  28. Apr 11, 2024 at 4:50 AM
    #88
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    You say 2025 Toyota TRD ORP but have a pic of a Lexus?:notsure:
  29. Apr 11, 2024 at 5:56 AM
    #89
    semprenissart
    semprenissart Mèfi
    That’s what he wanted the 6th gen 4R to look like.
    photoshop Toyota instead of Lexus and that’s how he wanted to see the 2025 4R
    Yotaholic[OP] and LCJ77[QUOTED] like this.
  30. Apr 11, 2024 at 6:54 AM
    #90
    Neutered, LOL, like the 4.0 makes any power and doesn't sound like garbage. LMAO!
