RIP 4Runner
Discussion in '6th Gen 4Runners (2025+)' started by Yotaholic, Apr 9, 2024.
  1. May 16, 2024 at 5:00 AM
    #391
    I don't think you can get banned for debating or disagreeing. It's the people that have to take things personally and call each other names that usually get banned.
    Also, if you could get banned for arguing too much, I would have been banned long ago.:anonymous:
    RumHamRunner73 and gomiami like this.
  2. May 16, 2024 at 5:10 AM
    #392
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Dont disagree those things CAN be issues- but the systems and materials used here have vastly improved over the years (that's why I keep posting the Road&Track article over and over). We wont know how reliable this one will be until people get some miles on them.
    The car car nut video on the new Tacoma was enlightening on this point - the turbo they are using has cooling of the bearings from both the forced oil lubrication AND a coolant loop.
    I never owned one but looked it up. Those where head gasket failures. Not the block failing. Probably an under designed head gasket and that can happen in any highly tuned engine regardless of if that power comes from turbos or NA. The other thing that very highly tuned turbo engines can do is throw a rod, and that's likely to happen long before cracking a block. but we are nowhere near those power levels
    Before you add the electric motor the base 2.4L turbo is 278hp. Thats only 115hp/liter. Thats actually pretty weak for a turbo engine.. Honda has built street production engines sold in 30k cars that made more than that naturally aspirated (125/liter in the F20c, 100-110/liter in the K20 series) and people put 200-300k on those without issue. Then they throw massive aftermarket turbos on them and push them over 200hp/liter and they still last for 100s of thousands of miles.
    #1 FOD - solution: don't run without an air filter ;)
    #2 Overspeeding - Not much we can do about this but I would assume that the Toyota ECU programming is designed to avoid this whenever possible by using the wastegate to relieve pressure when off the gas. Also note their reference to Diesel turbos running 30psi boost. I doubt this engine is making more than 5-6psi of boost.
    #3 oiling problems - Again we have to hope Toyota designed the oil system well. I would argue that if any automaker can be trusted to its them. Oh and change your oil. duh.
    #4 seal leaks - see above
    #5 thrust bearing - see above
    #6 surging - the article claims this is due to oversized turbos. We established above this one is downright mild so non issue
    #7 extreme heat - Yeah as even they admit this will damage any engine if things are not designed properly or stuff breaks.
    Pre-ignition and detonation damage doesn't know or care if its coming from a turbo or N/A. If you have an injector fail on a highly tuned N/A engine like the Honda F20c I mentioned above it has just as much potential for damage. But luckily these engines now have knock sensors at every individual cylinder that can detect and cut the fuel or cutoff the coil to that cylinder to compensate. If some idiot drives around with the CEL on that's the drivers fault not Toyotas.
  3. May 16, 2024 at 6:18 AM
    #393
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    ^ I agree with just about all of this.
    These engines are designed to be run under boost. Will they last as long as the old v6's? Time will tell.
    But they Toyota will likely maintain a very similar failure rate within the factory warranty period. Which is the number they need to hit...
  4. May 16, 2024 at 8:26 AM
    #394
    I have a similar vehicle history. I had a WRX and my wife a Forester XT. We traded them both in before high mileage headaches and went with a Tacoma and 4Runner with the plans of running them to high mileage with little maintenance. So far that plan is working well. The Tacoma is at 180K miles and the 4Runner is at 105K. I wouldn’t be comfortable doing the same with the new Tacoma or 4Runner. If we get one it will get traded in early.
    Sin4R and 1SilverRunner[QUOTED] like this.
  5. May 16, 2024 at 8:29 AM
    #395
    Take a look on the Tundra forums or YouTube. There have been a lot of 22 Tundra engine failures and now there have been a couple 24’s with the same oil starved bearing failure.
  6. May 16, 2024 at 8:42 AM
    #396
    I had really only heard about the wastegate issue. I didn't realize that engines were failing. If that's the case, I'll take back what I said.
  7. May 16, 2024 at 8:44 AM
    #397
    It's fine and will sell like crazy.
  8. May 16, 2024 at 10:05 AM
    #398
    2016Pro
    Do you honestly believe that toyota the company that makes the best quality, most over engineered vehicles in the industry is going to put out some shabby 4 cylinder turbo motor? Cmon man that's ridiculous.
  9. May 16, 2024 at 11:18 AM
    #399
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I hear ya lol
    Just pulling your leg
    My problem hasn’t been name calling, but perhaps an inappropriate meme from time to time :anonymous:
  10. May 16, 2024 at 11:31 AM
    #400
    lol
  11. May 16, 2024 at 9:36 PM
    #401
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Toyota is overrated
  12. May 16, 2024 at 9:42 PM
    #402
    Yotaholic
    Olympia, WA
    My friend's Diesel JLUR on 38/13.5/R17s, steel bumpers and stock 3.73 gets 26 mpg on the highway
  13. May 16, 2024 at 9:50 PM
    #403
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    https://youtu.be/ihpX_gZGWXE?si=i33de9vXmnXZGgmB
    Yotaholic[OP] likes this.
  14. May 16, 2024 at 9:51 PM
    #404
    Yotaholic
    Olympia, WA
  15. May 17, 2024 at 3:25 AM
    #405
    broken-giver
    broken-giver BFD
    I can not reconcile your screen name with that statement. :)
  16. May 17, 2024 at 5:17 AM
    #406
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    It was open deck block design that under boost would let go, head gasket failure was a mode of failure and not the cause.
    Disagree. I had a car with straight-6 engine that run lean for years, it was fine other than being down on power. I eventually traced it down to partially failed injector. In a similar circumstances turbocharged engine would have been dead.
    1SilverRunner likes this.
  17. May 17, 2024 at 6:56 AM
    #407
    2016Pro
    It's actually very evident in their products. No surprise
  18. May 17, 2024 at 6:57 AM
    #408
    4R777
    4R777 New Member
    Bullish on 4c turbo engines.
  19. May 17, 2024 at 7:48 AM
    #409
    This is getting ridiculous. These bearing failures seem like a major design problem. What’s going to happen to these when they all start getting up to higher mileage? Will any survive? Are the Lexus motors made here in the US with the Tundra motors or in Japan?
  20. May 17, 2024 at 7:48 AM
    #410
    Good luck.
  21. May 17, 2024 at 7:49 AM
    #411
    1SilverRunner
    Tejas
    Exactly my concern ^
  22. May 17, 2024 at 8:01 AM
    #412
    The bill to repair one of these engines is like $30K. I was planning on getting a Tundra as my next truck but not anymore. I’m not dealing with that potential financial disaster let alone getting stranded somewhere when the engine fails.
  23. May 17, 2024 at 8:36 AM
    #413
    STrooper
    STrooper Let’s Go Places!
    Jack
    I like the double stache!
  24. May 17, 2024 at 9:04 AM
    #414
    1SilverRunner
    Tejas
    I wouldn't worry too much. Just get the extended warranty and enjoy that torque!
    Superdave1.0 likes this.
  25. May 17, 2024 at 9:25 AM
    #415
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    the bill to repair one in warranty is $0.
    after the 6 year / 70k power train warranty expires it would be expensive (and I probably trade the car and not fix), but this is the kind of thing that if it’s gonna happen I think it will have before that point..
    Superdave1.0 and 1SilverRunner like this.
  26. May 17, 2024 at 9:37 AM
    #416
    Power train warranty is 60K. That’s less than three years driving for a lot of people. You can’t trade in a truck with a seized engine.
  27. May 17, 2024 at 10:07 AM
    #417
    Yotaholic
    Olympia, WA
    And Extended Warranty is probably 120k, that's 5 years of driving for some. Might as well get a Ford instead lol
  28. May 17, 2024 at 10:10 AM
    #418
    LJrunner
    LJrunner New Member
    Shredder and Turd Ferguson like this.
  29. May 17, 2024 at 10:19 AM
    #419
    Then you have to shell out even more money for the extended warranty. I have never bought one for any vehicle. Then there’s the expensive of a breakdown far from home. Towing, lodging etc plus a long term car rental while the truck is getting repaired. If the engine blows while on a vacation then it’s even more of a nightmare.
  30. May 17, 2024 at 10:21 AM
    #420
    1SilverRunner
    Tejas
    Well if reliability isn't quite there, and we're talking about $90k... I'd be looking at the Ford Raptor Bronco or the Jeep 392 pretty hard.
