Retrofit OEM Radio from 2020-2024 to 2014-2019!
Discussion in '5th Gen 4Runners (2010-2024)' started by STrooper, Oct 22, 2023.
  1. Nov 20, 2023 at 6:57 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    That's unfortunate. That's my problem with them. They have no clear images of the units they are selling. You just have to make out what they have and hope it's the correct one.
  2. Nov 22, 2023 at 4:40 PM
    STrooper
    STrooper [OP] Let’s Go Places!
    There is a guy selling a radio including the harness on FB at a great price!
  3. Dec 5, 2023 at 1:03 PM
    pumacat24
    pumacat24 New Member
    Cat
    2019 TRD Pro
    Hey! I am about to pull the trigger on this set up on my 2019 Pro. Is it seriously just plug and play and everything works? It makes me nervous spending so much money. Everything works like the OEM microphone, steering controls, backup camera, etc.... Thanks!!!
  4. Dec 5, 2023 at 1:17 PM
    JustATallDude
    JustATallDude New Member+
    2019 Toyota 4Runner TRD Pro
    Gibson Single Exit Exhaust - Magnuson Supercharger - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Big Red's Turn Signal Mod and AMD Mod - R4T Blackout Turn Signals - BlackVue DR590 Dashcam and more to come...
    Yeah everything was pretty much that easy. Don't forget about the amp tho. That was the part that sucked to get to. You may need to get an OEM nav harness that meets from the top part of the headunit to a lower part of it. Yours may come with it though depending on who you're buying from.
  5. Dec 5, 2023 at 1:22 PM
    pumacat24
    Cat
    2019 TRD Pro
    Yeah, there is a guy that has one for sale with radio, amp and adapter harness (with GPS adapter) for $3k. It feels like a lot of money, but the OEM look is what I want, and it's better than paying $15-20k just to upgrade to the 2020+ Pro. Especially since my car is paid off.
    Thanks for answering so fast... so you haven't had any troubles with yours at all since installation? Did you install it yourself?
    JustATallDude[QUOTED] likes this.
  6. Dec 5, 2023 at 1:29 PM
    JustATallDude
    No worries, happy to help! Yeah I did everything myself, the only issue I ran into was the USB harness and Android auto. I just installed a Motorola MA1 wireless adapter and that fixed it up. Was having some issues with it on some longer drives but I had it just behind the radio and I think it was over heating. I have now put that in the dash and that so far seems to have fixed the issue.
  7. Jul 31, 2024 at 9:28 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Is there a way to upgrade navigation on these units?
  8. Jul 31, 2024 at 9:34 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    There are Chinese SD cards available on Amazon that will update the maps and bring it to 2023. The latest version ends with 76.
    There would still be a 1 year delay, as that's the time it takes to populate data and have it available for retail.
  9. Jul 31, 2024 at 9:45 AM
    Emmantik
    Emmantik New Member
    How do you access the SD card on these 2020+ headunits?
  10. Jul 31, 2024 at 9:48 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I would assume you put it in a USb adaptor and connect in to the USB port.
  11. Jul 31, 2024 at 11:02 AM
    STrooper
    If anyone is interested, I'm going to have a 2022 OEM (non-JVL) radio with navigation for sale in the next day, including the harness for the 2014-2019 as well! The radio is in like new condition from a 4runner with no accidents.
  12. Jul 31, 2024 at 11:15 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    What are you replacing it with?
  13. Jul 31, 2024 at 11:41 AM
    LandLover
    LandLover New Member
    Andrew
    Overland Park KS
    What is the biggest benefits to doing this retro?
  14. Jul 31, 2024 at 12:12 PM
    Emmantik
    Emmantik New Member
    Can use Apple Carplay / Android Auto plus the screen is larger than previous model.
  15. Jul 31, 2024 at 12:18 PM
    LandLover
    Andrew
    Overland Park KS
    Does anyone have the list of of compatible units Year and Part#'s for this retrofit?
  16. Jul 31, 2024 at 12:19 PM
    STrooper
    In addition, you keep all the OEM functions that you typically lose on an aftermarket head unit. 8"inch screen, better camera resolution with Android and apple CarPlay, you also have the option of adding a front face camera. This is a plug and play unit that doesn't require any mods and keeps the factory look as well.
  17. Jul 31, 2024 at 8:51 PM
    LandLover
    Andrew
    Overland Park KS
    I might do this at some point here are is the list I have compiled so far -->
    86100-35630 BLK/BLK Menu?
    86100-35631 BLK/BLK Menu in WHT and BLK
    86100-35632 BLK/BLK 2021
    86100-35633 BLK/BLK Menu?
    86100-35634 BLK/BLK Menu? 2022
    86100-35640 SLV/BLK Menu in BLK
    86100-35641 SLV/BLK Menu in WHT
    86100-35642 SLV/BLK Menu 2020 NOT OEM??
    86100-35643 Could not find NOT OEM ??
    86100-35644 SLV/BLK Menu WHT
    86100-35645 Could not find NOT OEM??
  18. Aug 1, 2024 at 8:10 AM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    EDIT: Theres also the issue with the hazard switches being different.
  19. Aug 1, 2024 at 8:26 AM
    #49
    STrooper
    Thats not accurate info. The hazard connector is the same. However, you need to swap the hazard switch button from 14-19 model to the 20+ radio and works perfectly fine.
    In addition, the frame that surrounds the hazard can also be detached from 14-19 radio and reinstall on the 20+ radio to click back in securely.
  20. Aug 1, 2024 at 8:27 AM
    #50
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Doesn’t matter as much as the hazard button not fitting. The 2020+ is a momentary switch whereas the pre 2020 is SPST so you have to swap the buttons
  21. Aug 1, 2024 at 8:31 AM
    #51
    CA4runner
    Nor Cal
    2019SR5
    Is there a tutorial on swapping the switches? b/c it looked like to remove the switches youd break the dash pieces holding um in..
  22. Aug 1, 2024 at 8:32 AM
    #52
    Emmantik
    Emmantik New Member
  23. Aug 1, 2024 at 8:35 AM
    #53
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I made the switch from my 2011 work in the 2022 headunit by swapping the wiring harness and wrapping electrical tape around the old switch.
    The switch that came with my 2022 unit was faulty so had to do the swap .The wiring harness connector is also different for both switches.
  24. Aug 1, 2024 at 8:37 AM
    #54
    STrooper
  25. Aug 31, 2024 at 9:26 PM
    #55
    LandLover
    Andrew
    Overland Park KS
  26. Sep 1, 2024 at 1:54 AM
    #56
    STrooper
    I haven’t as of yet. I’ve been pretty busy at work/family and not much time on my plate to do so.
  27. Sep 3, 2024 at 2:56 PM
    #57
    JustATallDude
    I might be going a different route myself in these next couple of months and may have the whole swap available for sale. The 21 Amp, Headunit, and wiring for 19 with JBL. I'll post more about it when I'm closer to deciding.
  28. Sep 3, 2024 at 3:31 PM
    #58
    LandLover
    Andrew
    Overland Park KS
    So if my current 17' OEM unit has GPS and new OEM unit has GPS I need the addition cable and the usb adapter?
  29. Oct 4, 2024 at 3:41 PM
    #59
    235Axis
    235Axis New Member
    Ken
    2019 Black 4R Nightshade
    I’m interested if you’re looking to unload your setup. My head unit went out and dealer advised me to replace it.
  30. Oct 5, 2024 at 11:11 AM
    #60
    CA4runner
    Nor Cal
    2019SR5
    Yes.
