Resale of modified 5th Gens
Discussion in '5th Gen 4Runners (2010-2024)' started by K-Paul, Sep 13, 2023.
  1. Sep 14, 2023 at 3:03 PM
    K-Paul
    K-Paul [OP] Looking for a water crossing
    Corbin Dallas
    SR5 4WD
    Yeah it makes sense. I sold the old stock parts as I am not into hoarding things. Im planning on keeping it instead and extracting the value from the mods added.
  2. Sep 14, 2023 at 5:50 PM
    BillyE
    BillyE New Member
    I’ve never seen mods add anything to resale
    2016Pro likes this.
  3. Sep 15, 2023 at 4:43 AM
  4. Sep 15, 2023 at 5:04 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I think if you know the owner and the vehicle, I would pay more for some mods done. For example, I. The local 4Runner group, I am very familiar with at least 15 trucks. If, god forbid, something happened to mine and I was looking to buy one, then I would be comfortable paying more over a stock one from one these folks.
    For a stranger’s truck, I might still be depending on the mod. A steel bumper is pretty straightforward, same as a winch. I would probably just ask to check everything over with the front facia off, check torque on bolts, and look for rust or damage. But DIY electrical control panels, or mods more intrusive than a tap-a-fuse I’d avoid. Holes drilled in roof for mods, and any engine mods I would also avoid. There are installs from a couple of local shops I would trust, so if they had receipts for that then I would consider some value. And if the mods were less than 2 yrs old as well. If they’ve been running a 34” tire or bigger for any length of time, I wouldn’t necessarily avoid, but I would offer less than a stock price.
    K-Paul[OP], Steely123 and 2021venture like this.
  5. Sep 15, 2023 at 6:06 AM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    Keeping it stock was part of my rationalization for buying a Pro. I'm not mechanically inclined. I would drive myself nuts trying to determine what mods to install, one change leads to another, who is going to install it, the cost of the mods and install, and ultimately the diminished value, and the added wear and tear of a modified vehicle. No thanks! I will never go rock crawling! A stock 4R with good all terrains with serve 97% of us just fine!
  6. Sep 15, 2023 at 7:14 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    I’m fighting this not to mod my 23 Pro when I get it. Whenever I mod my Pros I’m able to change them back. I like the westcott lift on the Fox suspension and a nice set of door ding preventers I call them. Which they really protect. Not sure this time if I will remove the pro rack and add the westcott lift. The westcott lift helps the suspension handling and also the ride. Just my opinion.
  7. Sep 15, 2023 at 7:19 AM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Buying a truck with mods is not a problem for me.
    My main two things are 1) is the frame intact and rust at a reasonable point for the age and 2) Is the interior clean?
    I dont need it to be pristine just not smell like someone lived in it. Of course I can detail it and clean, I just feel that if the interior was not trashed -- chances are other parts of the truck will be fine.
  8. Sep 15, 2023 at 4:12 PM
    I wouldn’t have a problem buying a modified one either. But I’d want to pay less than market. Sliders, bumpers, etc don’t paint themselves, and chances are they would need it. A lot of mods require additional upkeep and PM, or make general maintainace harder, sometimes a lot harder.
  9. Sep 15, 2023 at 4:30 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Mods that probably add some $$$
    -supercharger
    -regear with lockers
    -quailty mid/long travel setup
    djwantke likes this.
  10. Sep 15, 2023 at 4:38 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I read all of page one but can't even read anymore of you negative Nancy's. Ya'll sound like you love stock 4Runners and mods are evil and nobody wants to buy a Runner with some quality popular mods already done saving them the lead time and cost for these parts new. There absolutely is lots of buyers, buyers who like 4Runners for a reason, who would purchase a 4R with mods at a decently high price.
    F*ck stock 4Runners.
    Hell, I feel this way and I'm not even selling. I paid it off years ago and it's going to my baby boys for a bush truck. But I got low mileage (2016 @ 90,000km), full time garage and underground parking stored, no rust, good maintenance history, one owner since new. Gtfoh I wouldn't get a good dollar for it still. And no I'm not asking for bullshit replies saying I ruined the truck and will.take a big loss. Not in British Columbia I wouldn't.
    Old Tanker likes this.
  11. Sep 15, 2023 at 4:58 PM
    Nah man. Your rig is fine. Like I said, people around here don’t even look at frame rust before paying stupid money. Most people won’t really notice or care about most small mods, so your resale probably wouldn’t drop. The big stuff might be a point of negotiation if they want something different, or don’t want it at all. I think in general, the more expensive and permanent a mod is, more difficult it is to sell to the general public. But even so, there’s a market for everything, you just have to find it.
  12. Sep 15, 2023 at 6:02 PM
    My thoughts exactly McSpaz, you get it. It's like it was contagious on this thread, and the cool kid thing to do, to jump on the bandwagon of stock is amazing - when in realty I cringe seeing my stock 4R photos lol
  13. Sep 16, 2023 at 11:36 AM
    Startrek
    Startrek New Member
    is modified vehicle has healthy transmission or it's lifespan shortened by off-road ? how to figure it out ?
  14. Sep 16, 2023 at 12:21 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Dollar for dollar was never the ask, im curious to see if people have received more than KBB for good mods. Even if 2K over KBB for example with 10K in mods.
    Enthusiasts on the forum seem to widely agree the answer is no with a few believing you can get marginally more.
    2016Pro likes this.
  15. Sep 17, 2023 at 4:48 AM
    I personally feel a modded vehicle would be more than a stock vehicle. But only in the eyes of someone who would do the same mods. So you have to sell it to yourself, lol.
    Kinda like a 68 camaro that’s a resto mod at the mecum auction.
    I feel if you don’t like the mods, just move the fuck along. But if you were going to do the same mods anyways if you bought it stock, then go for it and put that cost in your consideration.
    I don’t think anyone will get more than kbb/blackbook doing anything other than a personal sale.
    of course my opinions only
  16. Sep 17, 2023 at 12:06 PM
    Ya you're probably right. Probably an accurate answer overall. But I think one side gives more weight to the fact that a seller's price can very much be based on circumstance and location, instead of blanket agreeing $10-20k usually gets you zero over asking. Of course if it's starting to rust and clearly not maintained - I agree all mods then are like polishing a turd; it's still a turd!
    K-Paul[QUOTED][OP] and SlvrSlug like this.
