Remote filter relocation...
Discussion in '5th Gen 4Runners (2010-2024)' started by peter2772000, Jun 9, 2020.
  1. Oct 3, 2023 at 4:23 PM
    #61
    Rupp1
    Rupp1 New Member
    NC
    2017 SR5 Premium RWD Starlight Black
    I have the Baxter adapter that goes in the stock location now. I like it but I will eventually get a relocation kit for the 4Runner and also my wife’s GX460. Spoiled with my ‘15 Tacoma right up top in front.
    DrewMan and 2Toys like this.
  2. Oct 4, 2023 at 3:19 AM
    #62
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    How much lower does the Baxter in stock location sit? I heard it interferes with stock skids. Do you know if it interferes with aftermarket, like RCI, C4?
    DrewMan and Rupp1[QUOTED] like this.
  3. Oct 4, 2023 at 3:43 AM
    #63
    rmiked
    rmiked New Member
    Fort Mill, SC
    Which Baxter model number did you get? I don’t see one on their website specifically listed for 4 Runner? Maybe I missed it. I saw one for FJ Cruiser using 4.0 engine up to 2014. Is that it? I would feel more comfortable using this location to minimize oil flow losses due to additional pressure drop added by additional length of oil lines. The alternate locations may be ok but in theory it will reduce oil flow rate. This may be the warranty concern? The Baxter guys argue Toyota Engineers screwed up by not having a backflow preventer in the canister style oil filter. I don’t believe that. Their engines could not last as long as many do if that was a needed design feature. The factory canister is located low in the oil flow path and stays flooded on shutdown as we all know the filter is filled with oil when we remove it. Any components needing immediate oil flooding on startup likely has a check valve in that flow path? If anyone has any more specific info regarding the absence of an oil backflow preventer, please respond. I think these Baxter products are nice for avoiding mess but that’s it.
    DrewMan likes this.
  4. Oct 4, 2023 at 1:57 PM
    #64
    Rupp1
    Rupp1 New Member
    NC
    1 Inch. I don’t run the skid since it’s a highway vehicle, but I did make a plate so it wouldn’t get hit from the front.
    DrewMan and Guppy1301[QUOTED] like this.
  5. Jan 15, 2024 at 9:14 PM
    #65
    kjsouv
    kjsouv New Member
    Ken from YT channel 'Offroad Hub' has a pretty good video showing how he did his oil relocation on his FJ (should be the same as T4R 4.0L). And if you need to eliminate the factory oil filter housing for a Solid axle swap or just to make more room, Instagram user @maxari_co has an oil block-off plate adapter similar to the one in the video
    https://youtu.be/jWTWWHf7_sA?si=tSJprqaYp6Yt_YeI
    Doglover2003 and DrewMan like this.
  6. Jan 15, 2024 at 9:27 PM
    #66
    Keep in mind that without the forward skid and that plastic filler plate that ties the skid to the front bumper, the lower plastic radiator is exposed. All it would take is one small rock bounce to take out the radiator.
    This is why I have shyed away from aftermarket skid plates. All of the ones I’ve seen leave the lower radiator exposed.
    DrewMan likes this.
  7. Jan 16, 2024 at 1:06 AM
    #67
    lyodbraun
    lyodbraun New Member
    Northwest Ohio
    2018 4RUNNER
    While this may be easy those don’t suck all your oil out, next time you use it, go under the truck and open the oil drain plug and just see how much comes out.. you will be surprised..
    DrewMan likes this.
  8. Jan 16, 2024 at 6:13 AM
    #68
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Or a folding chair
    DrewMan and RumHamRunner73 like this.
  9. Jan 16, 2024 at 6:19 AM
    #69
    Sailormilan2
    Sailormilan2 New Member
    Dale
    2020 4Runner TRD Premium
    Realizing that this is an very old thread, my bone stock '06 Tacoma 4.0L V6 has the filter on top, upside down, at the front corner of the engine where it is very easy to access.
    lyodbraun and DrewMan like this.
  10. Jan 16, 2024 at 9:08 AM
    #70
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Heh heh, damn POS Toyota cheaps out so much on these cars.
    First they take away the spin on oil filter, next they allow damage to the engine if you drive on the interstate without coolant. What will they think of next?
    DrewMan and icebear like this.
  11. Jan 16, 2024 at 9:15 AM
    #71
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    lol why go against yota engineers on the filter location
  12. Jan 17, 2024 at 12:04 AM
    #72
    lyodbraun
    Northwest Ohio
    2018 4RUNNER
    Yeah I absolutely loved that spot on my ole 06 taco as well was such a breeze to change the filter and write date on top of it with ease..
    DrewMan likes this.
  13. Jan 17, 2024 at 9:50 AM
    #73
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    if Toyota Engineers had this oil filter located up and above on previous Tacoma & 4Runner models, I wonder why they elected to go back to lower side of engine block? … guess we’ll never know … definitely think this would be easier on maintenance.
