RedRunner's 2016 SR5 Build and Adventure Thread
Discussion in '5th Gen Builds (2010-2024)' started by RedRunner87, Feb 18, 2018.
  1. Jan 11, 2020 at 7:40 AM
    #91
    RedRunner87
    RedRunner87 [OP] Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    Decided to match the roof rails to the badging I did. I went with a two tone color scheme, graphite in the center and black on the end caps.
    How she started.
    [​IMG]Untitled by redrunner87, on Flickr
    The slick top look. I actually kind of liked the slick top look.
    The finished product! I think it looks a lot better now.
    WallyT4R and SlvrSlug like this.
  2. Jan 11, 2020 at 1:36 PM
    #92
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  3. Jan 12, 2020 at 10:48 AM
    #93
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Fixed the rear Passenger side door handle today. Used this video as a reference on how to get the panel off:
    https://www.youtube.com/watch?v=KtYX3PZYdJE&t=103s
    First stop is to pop of the three screw covers and remove the 3 screws:
    Then you just start at the bottom of the panel and pop the door panel off. Once you get the panel separated from door, you lift up and pull it out of the window track. Then you just unplug the power and release the two cables.
    Next up you need a 30mm Torx bit and remove these 3 bolts:
    Once the bolts are out you need to push the locking mechanism and push it down so you can access the bolt for the door handle:
    That is basically how you remove/attach the rear door handle.
    WallyT4R likes this.
  4. Jan 12, 2020 at 10:57 AM
    #94
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    After the door I pulled the front mud flap. I was rubbing on the driver side when at full lock and hit a bump. Hopefully this fully solves the rubbing.
  5. Jan 20, 2020 at 10:50 AM
    #95
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Didn't get any pictures so these are the ones I stole from the group. Went out with a local Tacoma group and hit up Mount Herman Road outside of Colorado Springs. It was a pretty tame trail but a had a good "playground" section. Definitely tested my ATRAC out on the hardcore off camber section.
    DrewMan likes this.
  6. Feb 2, 2020 at 7:54 AM
    #96
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    We had an absolutely gorgeous day for February in Colorado(55 degrees in the mountains). I hit up Longwater Gulch with Colorado Springs Tacomas and it was an absolute blast. Still a good amount of snow, good amount of mud too.
    When we started the trial we saw this 3rd Gen 4Runner stuck on the side of the trail. No owner around so we continued on. When we came back the owner hired a recovery company to get him out. What a shit show that was. Absolutely dangerous, they didn't Stay The Trail and were unprofessional.
    [​IMG] by redrunner87, on Flickr
    Air up time
  7. Feb 8, 2020 at 10:11 AM
    #97
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Got my Ditch Lights and OEM Style Switches wired up.
    Installed the CaliRaisedLED OEM Style Switches:
    Used this diagram to get them wired
    Tapped into he "Green" OEM wire to the "Red 2" switch wire:
    All the switch lights are working:
    ...and we have power!
  8. Feb 9, 2020 at 10:09 AM
    #98
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  9. Feb 16, 2020 at 12:47 PM
    #99
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    DrewMan and WallyT4R like this.
  10. Feb 29, 2020 at 10:01 AM
    #100
    ERMBPA3
    ERMBPA3 New Member
    Scott
    Build is coming along nicely! How's the rubbing after the addition of the spacers, do you notice any more than before or has it helped with the areas you rubbing as you mentioned at full lock
  11. Feb 29, 2020 at 7:04 PM
    #101
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Thanks! So I removed the mud flaps and that ended the rubbing with no spacers. Everything was good until I added the spacers up front. This is the rubbing I am getting now.
  12. Mar 1, 2020 at 3:36 AM
    #102
    ERMBPA3
    ERMBPA3 New Member
    Scott
    Have you installed your cornfed spacers yet? I wonder if that would alleviate the problem?
  13. Mar 1, 2020 at 5:56 AM
    #103
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I have not installed the Cornfed lift yet. Waiting for warmer weather.
  14. Mar 1, 2020 at 8:08 AM
    #104
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  15. Mar 7, 2020 at 4:27 PM
    #105
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Quick update: 6383 miles on the 255/80 Wildpeaks and just got done with the second tire rotation(first one was to get the tires on the same schedule as the maintenance light). Tread Depth is 15/32 with some off-roading.
  16. Mar 15, 2020 at 5:53 PM
    #106
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Ajmogen likes this.
  17. Mar 16, 2020 at 6:05 AM
    #107
    LORDxGORDO
    LORDxGORDO New Member
    Luis
    2016 SR5 midnight black tforce
    TRD Skid Plate Nfab tforce rockslides/sidesteps BDcustomz lower grille Aiden James drl led fog bezels Phillips led fog lights Xenondepot HID low beams Springtail Solutions pet barrier - modified Ellis precision shifter knob
    Can you share the link to the ditch lights and mount? Looks real good!
  18. Mar 16, 2020 at 6:03 PM
    #108
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  19. Mar 22, 2020 at 10:22 AM
    #109
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Social Distancing Trail Run: Old Stage Road
    Air Down:
    Lookout:
    First stuck of the day:
    My turn to send it:
    Second stuck of the day:
    My turn to get stuck:
    Group shot:
    Can't forget about the "Official Jeep Recovery Vehicle" video:
  20. Mar 25, 2020 at 6:43 AM
    #110
    MidMO_Toyotas
    MidMO_Toyotas New Member
    2016 Tundra & 2014 4Runner
    Very nice build, I love the “low center of gravity” builds.
    I have a 2014 4Runner 4x4 SR5 Prem and I’ve done Bilstein 5100 all around with the fronts set on the second clip (~0.85” advertised lift, got a little more than 1”) and the rear is stock coils. I’m wanting to keep the stock SR5 wheels and I’m leaning towards 255/80R17. I’ve read through all 4 pages and I have a question for you about the 255/80’s.
    My question, did you rub at all offroad at full flex with your stock suspension? Before your spacers it looked like you had minor rub or no rub. Trying to decide if I can get away with leaving the Bilstein’s on the second clip, or if I need to go up to 1.75” or 2.5” and buy new rear coils for the 255/80’s.
    Here’s how the 4Runner current sits with stock sized 265/70R17’s:
  21. Mar 25, 2020 at 7:01 AM
    #111
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Your 4Runner is looking good!
    Thanks! I’m trying to keep it as low key as possible. Deciding on a mild lift right now.
    Without spacers I rubbed on the rear mudflap, once I removed it I had no rub. Now that I added spacers I rubbed on the front bumper and body mount.
    MidMO_Toyotas[QUOTED] likes this.
  22. Mar 25, 2020 at 1:48 PM
    #112
    MidMO_Toyotas
    Thanks for the reply, I really appreciate it.
    Maybe I’ll be okay keeping the mud flaps with the 1” lift and no spacers. We drive a lot of gravel and the flaps help keep the rocks from banging the doors
  23. Mar 26, 2020 at 1:44 PM
    #113
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    You could try to heat up the plastic and "flatten" out the little up on the front mud flaps
  24. Mar 29, 2020 at 1:43 PM
    #114
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Time to wash all the mud off and shine her up.
    Products Used:
    How we started:
    Step 1: Touchless Car Wash since I can't wash my 4Runner where I live. Came out OK, but you can see all the residue left behind.
    Step 2: Wash Wax All. Rear Fender has been wiped down with Wash Wax all and the Rear Door has not.
    Step 3: Turtle Wax ICE
    Step 4: Turtle Wax Ceramic Spray Coating
    Before:
    After:
  25. Apr 1, 2020 at 5:59 PM
    #115
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Started the reflective window covers for blacking out the interior when I camp. This was a little bit harder than I thought. 10ft roll only got 3 windows done.
    Messed this window up a little bit:
    ...but because I am stubborn I was able to salvage it. I think I can get it totally fixed tomorrow:
  26. Apr 2, 2020 at 4:08 PM
    #116
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  27. Apr 10, 2020 at 6:53 PM
    #117
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I am a little late with these, this was a couple weeks ago. We went out and explored in the mountains outside of Colorado Springs.
    We tested the first off-shoot off of the main Trail and we didn't make it too far!
    [​IMG]437FD717-EC87-408D-9709-D1A54239109F by redrunner87, on Flickr
    Doing a little bit of digging!
    [​IMG]045595EB-8FF8-4BEB-9D9A-ADB705BB542E by redrunner87, on Flickr
    Now it was time to turn around a narrow trail in the snow. Had to bust out the boards again for the Disco:
    So this section is super off-camber and he took a bad line. Backed up and ended up burying his bumper into the hill:
    [​IMG]D6DF76DC-CAD9-4C74-B3A4-59F93528A918 by redrunner87, on Flickr
    [​IMG]36EE83C6-AB18-4FF3-9C1F-DAE691A7FE59 by redrunner87, on Flickr
    [​IMG]4885C08D-3467-4534-810E-D88A5CDE47EC by redrunner87, on Flickr
    Onto the next obstacle:
    [​IMG]DA119F94-4FA8-4FBA-887A-3E755951357B by redrunner87, on Flickr
    [​IMG]BB681D5C-1EA3-424D-A6D1-9D027E527F86 by redrunner87, on Flickr
    Ended up hitting my tire on that rock:
    Flexing her out. Was really off-camber and with the snow it kept dragging me down the hill
    Made it up to the over look:
    [​IMG]44DFAA9F-E944-4F43-A729-2B3F0361E0AB by redrunner87, on Flickr
  28. Apr 10, 2020 at 6:53 PM
    #118
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    The Flex-Off
    The last little bit:
    The Damage:
    The videos:
    https://www.youtube.com/watch?v=91YPF9T1vic&t=10s
    https://www.youtube.com/watch?v=scnIPin14Jg&t=11s
  29. Apr 12, 2020 at 9:08 AM
    #119
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  30. Apr 19, 2020 at 9:00 AM
    #120
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
