RedRunner's 2016 SR5 Build and Adventure Thread
Discussion in '5th Gen Builds (2010-2024)' started by RedRunner87, Feb 18, 2018.
  1. Nov 8, 2019 at 8:33 PM
    #61
    RedRunner87
    RedRunner87 [OP] Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    Got new shoes put on. I will get better pictures in the morning.
    [​IMG]Untitled by redrunner87, on Flickr
    4runGirl88, SlvrSlug and WallyT4R like this.
  2. Nov 9, 2019 at 9:51 AM
    #62
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken WildPeak AT3W's have been installed. Here are some comparison pictures vs stock size. I am running stock suspension and I do rub a little at full lock and going over bumps.
    255's
    255's
    255's
    255's
    CoffeeJoe, wmdtech, Ajmogen and 2 others like this.
  3. Nov 9, 2019 at 5:39 PM
    #63
    Ajmogen
    Ajmogen Staying Stock
    Aaron
    Wisconsin
    Liscence Plate Surround
    Did you have to do any trimming up front?
    Looks good!
  4. Nov 9, 2019 at 6:19 PM
    #64
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    No. No rubbing on normal driving. It did rub at full lock going over a speed bump. I will post up a couple pictures of how close it is in the fender well.
    Ajmogen[QUOTED] likes this.
  5. Nov 10, 2019 at 7:47 AM
    #65
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    CoffeeJoe likes this.
  6. Nov 11, 2019 at 1:31 PM
    #66
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    travelinscout likes this.
  7. Nov 23, 2019 at 6:50 PM
    #67
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Rainbow Falls/Rampart Rd.
    I went to a local Overland Meet Up and a few of us decided to do a "quick" run through Rainbow Falls. This trail is mostly a fire road but had some decent snowfall on Thursday night.
    The Group(minus the 5 lug Taco):
    For the most part the trail was pretty easy but covered in snow. This was a good test for my new Pizza Cutter Falken Wildpeaks. They performed awesome and I had absolutely zero issues them. I aired them down to 20psi.
    The turn around spot was an old Query
    3 of us decided to continue to Rampart Road instead of taking the highway back into town. The others had to leave early for other obligations. We happened upon a pretty stuck XJ. The tires on this XJ were pretty bald, the winch barely worked and he ended up breaking the winch cable off the spool. I ended up having to get my recovery gear out and we had the guy with the 2nd Gen 4Runner pull him out.
    After we got him unstuck we debating going up the hill. The two XJ's tore it up pretty good and exposed a ton of ice underneath the snow. We decided to let the 2nd Gen up first to gauge how bad the hill was. We all made it up with no issues at all.
    Once we got onto Rampart Road this Ford CUV got stuck in the rut on the side of the road. He also didn't have very good tires either. It took us awhile to get him up and out of the rut on the side of the road. The "quick" run ended up taking 2-2.5 hours longer because of the recoveries.
  8. Nov 24, 2019 at 2:38 PM
    #68
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  9. Nov 26, 2019 at 2:08 PM
    #69
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    travelinscout and WallyT4R like this.
  10. Dec 1, 2019 at 12:24 PM
    #70
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Did an oil change today and forgot to grab a sample for Blackstone Labs. Ran Amsoil again and K&N Oil Filter(it's all Walmart had). I got around to upgrading to the Metal Filter Canister.
  11. Dec 3, 2019 at 7:34 PM
    #71
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    This is from my first majority highway trip with he 255/80's. Mostly two lane mountain roads with speeds varying between 45-70mph. A little bit of snow but didn't use 4WD.
  12. Dec 3, 2019 at 8:00 PM
    #72
    WallyT4R
    WallyT4R New Member
    An this is corrected for your tire size? Asking cuz improving over 5 mpg in one tank seems a little off.
  13. Dec 3, 2019 at 8:03 PM
    #73
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    That is hand calculated. I GPS checked my speedo and it is pretty spot on now. It was reading fast before with the stock tires.
    WallyT4R[QUOTED] likes this.
  14. Dec 3, 2019 at 8:05 PM
    #74
    WallyT4R
    WallyT4R New Member
    Nice! That is weird how it varies from vehicle to vehicle cuz mine checks out via GPS also and I am stock size BFG KO2's.
  15. Dec 3, 2019 at 8:07 PM
    #75
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    It is definitely weird. I have heard from a couple different people that their speedo's were off from the factory. Not sure if there is a rhyme or reason to it.
  16. Dec 6, 2019 at 8:45 PM
    #76
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Black Friday Haul:
    Cornedfed 1" Front Only Spacer Lift(to hold me over till I figure out what I really want)
    CaliRaisedLED Low Profile Ditch Light Brackets
  17. Dec 7, 2019 at 8:00 AM
    #77
    Pschiller86
    Pschiller86 New Member
    Paul
    2016 MGM 4Runner SR5
    Can you send us a link to the metal can? I want to be sure I get the right one
  18. Dec 7, 2019 at 5:47 PM
    #78
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  19. Dec 7, 2019 at 6:38 PM
    #79
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Ran 4 Mile in Buena Vista, CO with a Facebook "Colorado Off-road Crew" today.
    Ran into a couple 5th Gens making the same event:
    [​IMG] by redrunner87, on Flickr
    Meet Up Point:
    Time to Air Down:
    5th Gen couldn't quiet make it to the top:
    Collegiate Peaks
    Saw two Moose:
    We had a truck loose its bead so we hung out while they figured it out:
    Final stop on our way out:
    Was definitely dragging the skids in the deeper snow sections
    Time to Air Up and hit the road
    WallyT4R, Ajmogen and SR5 Limited like this.
  20. Dec 8, 2019 at 7:33 AM
    #80
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    WallyT4R and Ajmogen like this.
  21. Dec 9, 2019 at 2:22 PM
    #81
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    WallyT4R likes this.
  22. Dec 14, 2019 at 9:45 AM
    #82
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Started on the wheels this week while the weather was decent. Eventually going bronze, but I decided to do the center cap in graphite.
    Jimmycue and WallyT4R like this.
  23. Dec 14, 2019 at 1:19 PM
    #83
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  24. Dec 23, 2019 at 11:17 AM
    #84
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I went ahead and "dipped" my stock SR5 wheels bronze. I went with the dipyourcar kit since I had good luck with them the last time. I went with Graphite center caps as well.
    Before:
    Wheels all cleaned, bagged and tapped off:
    Ran the "dip release" around the tire itself:
    I did a last round of cleaning:
    3 Coats in:
    Moved the 4Runner to get better angles at the parts of the rim that were on the bottom:
    I did about 6 coats:
  25. Dec 23, 2019 at 12:36 PM
    #85
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
  26. Dec 23, 2019 at 12:37 PM
    #86
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I relocated the Inverter Switch to the upper Blank spot so I can have my Ditch Light/Light Bar switches in a row.
    DrewMan likes this.
  27. Jan 4, 2020 at 11:35 AM
    #87
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    On New Years Day I ran Schubarth's Trail in-between Colorado Springs and Woodland Park. Ended up being a beautiful day out.
    Pikes Peak
    Time to air down:
    First Stop:
    [​IMG]Untitled by redrunner87, on Flickr[​IMG]Untitled by redrunner87, on Flickr
    Second Stop:
    FJ80 didn't carry enough momentum up the snow/ice hill
    Turn Around Point:
    Sorry for the bad video quality:
    DrewMan and WallyT4R like this.
  28. Jan 4, 2020 at 11:38 AM
    #88
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Pikes Peak
    Time to air down:
    First Stop:
    Second Stop:
    Turn Around Point:
  29. Jan 9, 2020 at 4:22 PM
    #89
    Jimmycue
    Jimmycue New Member
    Jimmy
    I like the painted center caps.
  30. Jan 9, 2020 at 8:42 PM
    #90
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I liked it too. Definitely a little bit different.
