RedRunner's 2016 SR5 Build and Adventure Thread
Discussion in '5th Gen Builds (2010-2024)' started by RedRunner87, Feb 18, 2018.
  1. Jun 5, 2019 at 12:11 PM
    Compromised 4Runner
    Compromised 4Runner New Member
    2018 4Runner SR5
    Perhaps lock the gsheets so only you can edit it and then share the link? That way others can easily click on the links to products.
  2. Jun 8, 2019 at 5:33 AM
    RedRunner87
    RedRunner87 [OP] Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    I'll try that if that doesn't work I will post them in this thread.
  3. Jun 11, 2019 at 4:02 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Mt. Baldy, CO. Went out with a local Tacoma group. This was first trip with the 4Runner. She did pretty well considering I have shitty street tires on her. Used ATRAC once on a super flex part, that I took a bad line on.
    [​IMG] by redrunner87, on Flickr
  4. Jul 25, 2019 at 6:19 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Got the LED Fogs installed. I have the LED Turn signals(Switch Backs), just need to get the Headlights and High Beams/DRL's. Hoping I can do the PRO grill soon.
    [​IMG]Untitled by redrunner87, on Flickr
    Strandskov and WallyT4R like this.
  5. Aug 4, 2019 at 11:44 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Finally after having it for almost a year and half, I have installed the OG Trail Standard Offroad Faux TRD Pro grill. Haven't wired up the lights, because my dummy head ordered full size fuse taps and not the mine. Hopefully I can get that done this week.
    All Stock SR5
    Tapped off the headlights and bumper to protect the paint
    Cleaned the stock grill with dish soap so hopefully the TSO Grill will adhere better and its on!
    Upper grilled installed
    Finished product
  6. Aug 7, 2019 at 2:41 PM
    Compromised 4Runner
    2018 4Runner SR5
    Other than the amsoil engine flush, did you end up doing any other initial maintenance when you initially got it?
    Noticed a lot of people add the small orange lights in the grill. What is the purpose of those? Don't think they add much light at night. Or is it more of a "looks" kind of thing?
    Keep up the build thread. As a fellow Red SR5 owner, I look forward to what you are doing.
  7. Aug 7, 2019 at 7:35 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    It was a CPO vehicle when I bought it and came with a list of all the maintenance items they did at the dealer. So every oil change I run fuel injector cleaner, replaced the cabin air filter once, did the engine flush once and that's about it. So far she has been running good. The dealer did replace the brakes before I bought it.
    They are referred to as "Raptor" lights, based off of the Ford Raptor. They are more for looks and I guess an attention getter. Hopefully they will be wired up by this weekend. Debating Dipping the emblems next.
  8. Aug 8, 2019 at 10:18 AM
    Compromised 4Runner
    2018 4Runner SR5
    Thanks for the info. Plan on doing the above mention maintenance "soon". I suck at pray painting. My plastidip did not turn out so well. Cartrimhome has a set for $35. $35 to have it instantly done right. Or $7 + 3 hours (prep/spray/dry/peel). Wish I'd gone with the caps. Also if you blackout the emblems, you'll have the urge to black out everything else as well. Now my rims and rack no longer match. This bothers me so.
    https://cartrimhome.com/Emblem-Overlay-Kit-Toyota-4Runner
  9. Aug 8, 2019 at 3:16 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I am going to start with the SR5 Emblems and see how it goes. I am trying to get my buddy to sell me the Trail Edition rims that he powder coated bronze, so not too worried about the wheels.
  10. Aug 8, 2019 at 3:18 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Finally got the "Raptor" Lights wired up. I did it a little differently and didn't tap the fuse by the Riverside kick panel, I tapped the fuse in the engine compartment.
    I tapped the "INJ" fuse which is in between the 7.5 and 10 amp fuses
    I then unbolted this bolt and ran the wire through it and re-did the bolt.
    I ran the negative wire to the factory negative cable bolt. Now we have lights
    DrewMan, Strandskov and WallyT4R like this.
  11. Aug 17, 2019 at 12:52 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Got half of the switchbacks done. When I installed the rear LED turn signals, they didn't hyper-flash so I never installed resistors. Apparently with the front LED's installed I needed to put resistors front and rear. So it took longer than I thought it would, so only got it half done today.
    Driver: Switchback Passenger: Stock
  12. Aug 18, 2019 at 6:43 AM
    Pschiller86
    Pschiller86 New Member
    Paul
    2016 MGM 4Runner SR5
    Which lights did you go with?
  13. Aug 18, 2019 at 6:46 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Strandskov likes this.
  14. Aug 21, 2019 at 6:54 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    This will be the last mod for awhile. Finally finished up the switchbacks, so now it is off to saving up for tires. Hoping for 255/80 Falken Wildpeaks AT3W
    DrewMan and Strandskov like this.
  15. Aug 31, 2019 at 2:24 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Oil Change was done today. Going to do my first Blackstone Labs Oil Analysis done. I will post up the results when I get them.
    DrewMan, WallyT4R and Strandskov like this.
  16. Aug 31, 2019 at 2:32 PM
    Compromised 4Runner
    2018 4Runner SR5
    Anything in particular you are hoping to find out from the oil analysis?
  17. Aug 31, 2019 at 3:06 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Just wanted to get a baseline and continue to track throughout the time I have the 4Runner. I ran an engine flush the oil change before(Amsoil Engine flush), kind of interested to see if how the oil analysis comes back(wish I would have done a baseline before the flush to compare the two).
  18. Sep 23, 2019 at 5:37 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    First Blackstone Oil Analysis has been done. The oil used was Amsoil O.E. OW-20 @ 10,995 miles. I did an Amsoil Engine Flush right before this oil change. Here are the results:
    [​IMG]4Runner Oil 1 by redrunner87, on Flickr
  19. Sep 30, 2019 at 5:48 PM
    #49
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    The last parts to finish up Phase 1 of the build. I decided to try Rust-oleum Peel Coat in Graphite instead of Plasti-dip. I guess we will see how it compares. LED Headlights and LED DRL/Highs as well.
  20. Oct 7, 2019 at 3:39 PM
    #50
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Got the OBD Fusion app up and running. I did the user installed PID's for the Transmission and Torque Converter.
    WallyT4R and SlvrSlug like this.
  21. Oct 14, 2019 at 1:45 PM
    #51
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    WallyT4R likes this.
  22. Oct 14, 2019 at 2:39 PM
    #52
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    DrewMan and Bob like this.
  23. Oct 21, 2019 at 6:21 PM
    #53
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    Where did you get the peel coat?
  24. Oct 21, 2019 at 6:23 PM
    #54
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Ordered one can on Amazon, also found another at True Value hardware store. I need to touch up the "R" in the 4Runner on the back hatch, but I will do that when I do the roof rails this weekend. Overall I like it, we will see how it holds up long term. I like the "Graphite" over the black, just a little bit different.
    DrewMan and wmdtech[QUOTED] like this.
  25. Oct 21, 2019 at 8:52 PM
    #55
    wmdtech
    Nate
    Mid TN
    18 TRD ORP
    I did Plasti Dip on mine a year ago and it’s held up well. I kept the grey TRD wheels so I’m thinking of redoing the emblems to match
  26. Oct 22, 2019 at 5:22 PM
    #56
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I think it would match up pretty well with the grey TRD wheels. My plasti-dip on my 3rd Gen held up well too, so I hope these do as well.
  27. Oct 23, 2019 at 3:19 PM
    #57
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    I have those same LED bulbs in my Ford. How do you like them in the 4runner?
  28. Oct 23, 2019 at 3:26 PM
    #58
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    I really like them. The highs are super bright. I had to adjust the lows a little bit to get a good cut off, but they work really well.
  29. Oct 23, 2019 at 3:31 PM
    #59
    4scooter19
    Oregon
    98 and 86 4Runners
    Right on. I like mine as well. I had HIDS before which I feel put out more light but it wasn't as directed as the LEDS. They're hard to beat for the price.
  30. Oct 23, 2019 at 3:35 PM
    #60
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    The price is hard to beat, plus they are easily "clocked" so you can focus the beam. I have been driving a lot on back country roads with no lights at all, they have been a big improvement over the stock bulbs.
    DrewMan likes this.
