Recovery Hooks/Points
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Jun 5, 2023.
  1. Aug 16, 2024 at 2:47 PM
    #91
    backpacker
    backpacker New Member
    2023 TRD ORP
    That's what I do. I'd rather not have them jangling around all the time, and in most cases they'll be easy enough to install as needed, which will hopefully be almost never.
    Scarif_1 and rmiked[QUOTED] like this.
  2. Aug 16, 2024 at 2:49 PM
    #92
    Bend_4R
    Bend_4R New Member
    My exhaust is in the way on the passenger side, but I plan to use the hitch and driver's side recovery point with a bridle if I need to.
  3. Aug 16, 2024 at 3:44 PM
    #93
    I don’t recommend using the rear loop for recovery. It is attached to the frame in a much less robust way than the front loops.
    Bend_4R[QUOTED] likes this.
  4. Aug 16, 2024 at 5:50 PM
    #94
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    This too. It’d likely extend the life of the powdercoat on those new recovery points without the shackles sliding around on them. My recovery instructor also says to be wary of Amazon bought bow shackles. He recommended purchasing from actual rigging companies like ASR or Factor 55. Shackles like Crosby or Van Beest. I stopped carrying around the “value” priced Amazon bought ones I purchased early on and got a few Van Beest Green Pins.
    Trail Runnah likes this.
  5. Sep 8, 2024 at 3:08 PM
    #95
    Bend_4R
    Bend_4R New Member
    I installed the NYTOP front recovery points, and the tie-in seems extremely robust. Extra hardware included, which is always nice. The only variation from the extreme clear instructions was not being able to fit a washer between the frame and the recovery bracket because the fit was too perfect. I imagine that variations from the factory are the issue, but everything torqued down properly with a close fit and no gaps.
    BantamEddy likes this.
  6. Sep 8, 2024 at 5:01 PM
    #96
    This is the first I have seen those, they look kinda close to the bumper.
  7. Sep 8, 2024 at 5:24 PM
    #97
    Bend_4R
    Bend_4R New Member
    I suppose they do sit a little close. My recovery setup uses soft shackles so I don't anticipate an issue. They are also chamfered for that purpose. It looks like it would be a poor choice for regular shackles. It’s kind of hard to photograph them to show the angles, but the bumper rolls up to give plenty of clearance.
    SlvrSlug[QUOTED] likes this.
  8. Sep 8, 2024 at 5:53 PM
    #98
    Good pic. I see what your sayin now. I think i will check them out.
  9. Sep 8, 2024 at 7:23 PM
    #99
    TRDGrey2021
    TRDGrey2021 Guy in a truck
    2021 TRD Venture MGM
    Buncha Stuff
    Those sure our pretty
    Bend_4R likes this.
  10. Sep 8, 2024 at 9:32 PM
    #100
    Lost Woods
    Lost Woods New Member
    Half of me loves this design and the other half of me is afraid I'd hit them on something and bend them... normally they're oriented the other way so an impact is along the wide axis but this orientation is clearly better for a pull.
  11. Sep 9, 2024 at 7:36 AM
    #101
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I think they're kinda hideous. I also don't think they're any better than just using the tie-down points. The bolts up at the crush cans create a pivot point, the side bolt into the crossmember and utilization of the tie-down loop will see all the pulling force.
  12. Sep 9, 2024 at 8:10 AM
    #102
    Plastic bumper cover will flex as needed to accommodate shackles. That is, assuming you haven't torn it off already earlier on the trail.
  13. Sep 9, 2024 at 9:30 AM
    #103
    Bend_4R
    Bend_4R New Member
    You would need to break the bolt at the side of the frame and bend the stock tie down loops before any pivoting would occur, which would be well beyond the 12,000 WLL for these recovery points.
  14. Sep 9, 2024 at 2:59 PM
    #104
    IconicFJ_
    IconicFJ_ New Member
    07 FJ Cruiser
    All of Them
  15. Sep 9, 2024 at 4:41 PM
    #105
    Lost Woods
    I am not a huge fan of recovery points that mount on a single plane... 1/2" plate is great but the frame is probably less than half that. A hitch shackle thing is like $30 and will be way more sturdy.
    Tooly and Captain Spalding like this.
