Recovery Hooks/Points
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Jun 5, 2023.
  1. Jun 28, 2023 at 5:58 PM
    #61
    rmiked
    rmiked New Member
    Fort Mill, SC
    I revised my post above and guessed 1/2” thick looking at the welded loops and comparing. I measure the welded loops on my ORP. That is very impressive! The additional thickness is very beneficial for lateral loads. These guys at Apex did a good job designing these recovery points.
    Burnt Taco likes this.
  2. Jun 28, 2023 at 6:46 PM
    #62
    Thanks for that heroically long and detailed post. As my experience is as a rigger rather than an engineer, some of it was over my head, especially with regard to common design factors. One thing we haven’t discussed is the strength of threads versus welds. A subject about which I am woefully ignorant. My seat-of-the-pants rigger’s spider sense tells me that in the case of the Treaty Oak recovery points and an angled pull, when pulled to the outboard side the threads would fail and the recovery point would pull out. I suspect if it were to be rigged so that the pull was across the front of the truck, inboard, that the Treaty Oak hardware would perform better, as it would be pulled into the frame of the vehicle, instead of away from it. That made me wonder about the benefit of a bridle at all for use in an angled pull. I started to play around with an app called “Rig Rite” and found the following: if the angle of the pull is such that the point where the main strap attaches to the bridle is outside the width of the recovery points, the force on the long leg of the bridle approaches 100% while the force on the short leg approaches zero. That would mean that in many cases the use of a bridle is of no benefit. Thoughts?
    I did some measuring too! The loop diameter is a hair over ⅝ of an inch. That means that each loop is attached to the frame by 8 inches of weld!
  3. Jun 28, 2023 at 7:33 PM
    #63
    rmiked
    rmiked New Member
    Fort Mill, SC
    I would say the main benefit of a bridle is to avoid all the load going to one side. Therefore minimizing the chance of failing one attachment point. If the tow strap is able to slide over the bridle it should naturally avoid loading only one side. If it can’t slide there may be a low likelihood of keeping both sides loaded at all. Of course if when you get stuck the circumstances prevent getting the tow vehicle near centered, all you may have is one side to pull on. Which is why you would want a setup that can take as much load as possible without damaging the vehicle. IMO the Apex type setup gives you that initial condition. You may bend the Apex plate but not damage the vehicle frame. I didn’t put any calipers on those loops; 5/8” is nice size. Again, my impetus for an Apex type recovery point is to get the tow load (including lateral loads) into the frame without permanently bending any parts of the frame. The loads transmitted thru those welds either go all the way to the ground (friction, mechanical interference, rocks, ruts, etc) OR cause movement of the vehicle. The tie-down loop welds may be able to impart more load into the lower radiator support than it can resist without bending, particularly lateral loads. In properly designed welds, the weld metal is as strong as the base metal. The weld material and size of the weld is designed to transmit the design load. What we all wonder is, “what is the design load for these tie-down loops?” Toyota language implies it’s limited to something less than recovery loads. I wonder has anyone on the forum permanently bent any of these tie-down loops when getting their 4 Runner unstuck? Surely someone has some interesting pictures?
    Captain Spalding and Burnt Taco like this.
  4. Jun 28, 2023 at 9:16 PM
    #64
    Interesting question.
  5. Jun 29, 2023 at 6:06 AM
    #65
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    I, most certainly, would like to see pictures of bent/ pulled off/ failed "tie down loops" myself. One of the dedicated recovery point vendors has a picture of one that failed due to rust and are using it as a marketing tool, but that's it for me. I think a first person account might be acceptable, but doubt that anyone has researched a failure with the level of expertise/ experience that this thread has considered.
    Thanks so much Cap and rmiked for your excellent contributions. I'd also like to do a shout out to Cap for creating a dedicated thread on the subject of tie down loops.
    Mully410, Captain Spalding and rmiked like this.
  6. Jun 30, 2023 at 5:42 PM
    #66
    A fellow on another forum hit a hit a hidden stump and dented the front crossmember. He decided to fabricate a new one, and decided to re-use the loops. So he cut them out of the damaged crossmember. I found it interesting that the loops are so well reinforced inside the crossmember.
  7. Jun 30, 2023 at 6:35 PM
    #67
    Burnt Taco
    Tucson, AZ
    Look pretty darn stout to me. I am not an engineer.
  8. Jul 1, 2023 at 4:52 PM
    #68
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I wouldn't be afraid of using the tie downs for recovery. Just don't be stupid. Don't stand near any strap or winch cable when doing a recovery. Use common sense if you lack common sense, search youtube.
    LCJ77 likes this.
  9. Jul 1, 2023 at 5:04 PM
    #69
    This reminds me of two old adages that seem to dovetail together after reading your remark:
    Good judgment comes from experience,
    and experience comes from bad judgment.​
    and
    A smart man learns from his own mistakes.
    A wise man learns from the mistakes of others.​
  10. Dec 2, 2023 at 10:49 AM
    #70
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Captain Spalding @McSpazatron @Thatbassguy
    I'm so close to completion, CAN ANYONE TELL ME WHAT CRUSH BAR BOLT TORQUE IS??
    Thank-you
  11. Dec 2, 2023 at 10:54 AM
    #71
    Hey buddy, any idea what the crush bar bolts are to be torqued at? :p
  12. Dec 2, 2023 at 10:55 AM
    #72
    backpacker
    backpacker New Member
    2023 TRD ORP
    djwantke[QUOTED] likes this.
  13. Dec 2, 2023 at 11:07 AM
    #73
    I love that website. Even though i have no idea hkw they got that info or if it’s all accurate. Let’s hope so because I have suspension bits held up with torque values from that website lol
    djwantke likes this.
  14. Dec 2, 2023 at 12:14 PM
    #74
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
  15. Dec 2, 2023 at 2:03 PM
    #75
    You guys are the best, so fast! This website man.
    I should have reached out last night already :typing:
    McSpazatron likes this.
  16. Aug 14, 2024 at 6:32 AM
    #76
    Ocean_Watcher
    Ocean_Watcher New Member
    2024 4Runner TRD Pro
    None yet
    RE: getting unstuck, I don't have after market recovery hooks/points ... yet, and based on comments i don't think i would ever use the factory installed tow hooks, but would it be possible to attach recovery straps around the frame at the point where the factory tow hooks are attached to the frame (where the after market recovery points would attach to)? Structurally that's the strongest point on the frame so would attaching (wrapping) the recovery line to the frame cause damage? First plan is to get after market recovery points and have professionally installed. Back-up plan until then is to heed sage advice.
  17. Aug 14, 2024 at 7:02 AM
    #77
    scottiezilla
    scottiezilla New Member
  18. Aug 14, 2024 at 8:14 AM
    #78
    rmiked
    rmiked New Member
    Fort Mill, SC
    Ocean_Wartcher, I have not crawled under , with skids removed, to see if you could get straps around the structural member to which the stabilizer bars are attached. If you could , that would be good. I ordered the Apex Overland recovery points (non-KDSS) yesterday and should be installing them within a week. I’ll look under them when installing these, and see if it’s possible. I would point out that if you get stuck and need to pull your 4 Runner from the front, it will be practically no clearance between the ground and the frame. And it will be very muddy likely.
    Old Tanker and Ocean_Watcher like this.
  19. Aug 14, 2024 at 9:42 AM
    #79
    Ocean_Watcher
    None yet
    yes, non-kdss.
  20. Aug 14, 2024 at 10:16 AM
    #80
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Did this to mine. For looks only. Add one to the right side and got them powder coated.
  21. Aug 16, 2024 at 10:07 AM
    #81
    rmiked
    rmiked New Member
    Fort Mill, SC
    I got my Apex Overland recovery points today. Very impressive! 1/2” thick plate at pulling location. All other plate minimum 1/4” thick. Not a scratch. Nice edge distances on bolt holes.
  22. Aug 16, 2024 at 10:44 AM
    #82
    Please let us know how the installation goes.
  23. Aug 16, 2024 at 11:11 AM
    #83
    Bend_4R
    Bend_4R New Member
  24. Aug 16, 2024 at 11:47 AM
    #84
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    I like the eased inside edges on these making them more soft shackle friendly. I have the Apexes also and have yet to recover from them but the one criticism I have off the bat are the inside edges are a bit sharp. I was told to use them with bow shackles in a recovery class. I’ll also add the instructor liked how the Apexes were mounted on the frame.
    rmiked and Bend_4R[QUOTED] like this.
  25. Aug 16, 2024 at 12:06 PM
    #85
    Bend_4R
    Bend_4R New Member
    I ordered the NYTOP front and rear recovery points, which are supposed to ship in the next month or so—just in time for the snow season here in Central Oregon. I also picked up four Maxtrax Lites, a bit shorter than the full-size Maxtrax traction boards but still long enough to be very effective. I also picked up a 10' bridle, a 7/8" x 30' kinetic rope, and soft shackles from Sandy Cats/KineticX. Many hardcore 4x4 drivers love Factor 55, Yankum, etc., but the KineticX setup was far more affordable, and I picked this up for a worst-case scenario. I don't plan to be in situations often where I would be stuck, requiring a kinetic pull. Better safe than sorry.
    I didn't get stuck often in my GMC 2500HD, but when I did, a shovel and some 2x6s under the tires were usually enough to get me going. The Maxtrax should be even better for solo recoveries, even though I doubt it will often be an issue in my 4Runner with much better tires that I ran on my GMC. I did upgrade the wheels and tires on my GMC, along with a 3" lift. On my 2500HD, I am now running Maxxis Razr tires, which look very capable AT tires. All in all, my vehicles have leveled up considerably from years past!
    Scarif_1[QUOTED] likes this.
  26. Aug 16, 2024 at 12:15 PM
    #86
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    Keep us updated should you ever use those recovery points.
    Bend_4R[QUOTED] likes this.
  27. Aug 16, 2024 at 12:41 PM
    #87
    rmiked
    rmiked New Member
    Fort Mill, SC
    It took about 1 hour, no power tools. Just follow the instruction video. You can find it on Utube or scan the QR code they send in box. Very nice.
    backpacker likes this.
  28. Aug 16, 2024 at 2:00 PM
    #88
    Bend_4R
    Bend_4R New Member
    I hope to not need them, but I will post pictures of the install.
  29. Aug 16, 2024 at 2:06 PM
    #89
    rmiked
    rmiked New Member
    Fort Mill, SC
    The Apex recovery point plate edges are cut at 90 degrees. I am using a D-ring shackle which is rubber coated. I’ll probably just keep them in my recovery bag with recovery straps. They may make some noise while driving.
  30. Aug 16, 2024 at 2:42 PM
    #90
    scottiezilla
    Smart move
    I have one made by a member @Inv4drZm (or his brother) from other forum on rear driver
    Wonder if I can squeeze the towpoint on rear passenger
    on the topic, before I finally post some stuff for sale on the correct section
    I do have brand new apex points for KDSS for sale
    Bend_4R likes this.
