Rear Bumper Hitch Cover
Discussion in '5th Gen 4Runners (2010-2024)' started by 19KMW66, Jul 26, 2023.
  1. Jul 30, 2023 at 12:18 PM
    UncleShorty
    UncleShorty New Member
    Just make sure you remove it before you go thru a car wash.
    I'm on my third one...
    djwantke likes this.
  2. Jul 30, 2023 at 12:21 PM
    DirtyHairy
    DirtyHairy Card-holding Member
    Central NY
    2014 FJ Cruiser; 1978 FJ40; 2023 ORP MGM with KDSS
    The hitch can’t be covered without removing the hitch so I really thought he meant the rubber plug to put into the hitch.
    Toy4X4 likes this.
  3. Jul 30, 2023 at 12:56 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  4. Aug 21, 2023 at 2:42 PM
    19KMW66
    19KMW66 [OP] New Member
    2023 4Runner Limited
    Thanks everyone, I agree it protrudes too much for a piece like I have on my Tahoe. I got the rubber insert and put that in, looks ok.
    DirtyHairy likes this.
  5. Aug 21, 2023 at 6:22 PM
    Blu’s Dad
    Blu’s Dad New Member
    Northern Virginia
    2020 Limited
    Information that I now wish I had known before I too lost a cover grrrr
  6. Aug 27, 2023 at 9:30 AM
    Like on the 250-series Land Cruiser?
  7. Aug 27, 2023 at 9:48 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Wow, that appears to add a lot just to cover the hole. Does the receiver extend beyond the bumper, or is that extra length all cover?
  8. Aug 27, 2023 at 10:04 AM
    ^I suspect the receiver extends beyond the bumper cover just like it does on the current 4Runner.
  9. Aug 27, 2023 at 10:17 AM
    4R777
    4R777 New Member
    agreed
  10. Aug 27, 2023 at 1:54 PM
    ^Looks like earlier display models didn't have a tow hitch.
    The picture also shows the source of the LC's low ground clearance - it's the spare tire!
