Raptor Lights
Discussion in '5th Gen 4Runners (2010-2024)' started by AE1M, Dec 29, 2024.
  1. Jan 8, 2025 at 3:35 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I actually don't remember. I can try to take a look today.
  2. Jan 8, 2025 at 3:50 AM
    AE1M
    AE1M [OP] New Member
    Bob
    2024 TRD Off-Raod Premium
    I am still waiting for them to arrive, just did this to test for fuse box clearance. I will find a fuse that’s hot when the ignition is on. It really doesn't matter, since pulling current out of the hot side of the fuse with the add-a-fuse. It does cause the fuse box cover the bulge a bit, may cut a small piece out so no bulge
  3. Jan 8, 2025 at 4:23 AM
    Sippingonlunch
    Sippingonlunch New Member
    Tim
    2024 SR5 premium
    what do you recommend? I’ve been hearing putting the lights fuse into everywhere. Just don’t want the 4Runner to shut down if the fuse blows.
  4. Jan 8, 2025 at 6:20 AM
    I was just messing. I don't really care, or know anything about wiring raptor lights, as I would never put them on my 4R.
    2016Pro and andrewtheadventurer like this.
  5. Jan 8, 2025 at 7:07 PM
    Ryan99Z28
    Ryan99Z28 New Member
    Ryan
    Matthews, NC
    2023 4Runner Off Road Premium
    I put mine on the KDSS fuse since I don’t have KDSS. I notice a lot of people on YouTube are installing the add a fuse on backwards. I took a test light to verify which side has power and install the add a fuse accordingly. If you install it backwards, if there’s a short, it blows both fuses. If added correctly, whatever source has the short will blow that fuse, not both.
    Old Tanker, siblue and Saker like this.
  6. Jan 8, 2025 at 8:28 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    I do like a smart Ryan.
    So many people just need the answer without verifying a wire.
    Can’t believe I commented on a Raptor lights thread. They’re called DOT clearance lights.
  7. Jan 9, 2025 at 4:13 AM
    Sippingonlunch
    Tim
    2024 SR5 premium
    Thank you, appreciate the help!!
  8. Jan 9, 2025 at 4:35 AM
    AE1M
    Bob
    Correct, and you only should put a fuse in the top socket of the Add-a-Fuse in your example. That’s a best case since no other circuit in the truck is involved.
  9. Jan 12, 2025 at 6:00 AM
    Terraizer
    Terraizer New Member
    Trdpro2024
    Lights
    IMO I would pass on the raptor lights.The added wires in the engine bay will evetually result in one or more of the lights going out. The ground wires usually fail where the 4 wires meet into one. If your dead set on getting them run the power to the cabin fuse box the oreintation of the add a fuse in the engine bay fuse panel will be incorrect and having mud and water get int he panel by cutting or squeezing a wire thru the lid isnt good.
  10. Jan 12, 2025 at 6:15 AM
    This. The only reason trucks need them is because of how wide they are. I remember when it was only the Ford/Chevy F-350 or 3500's that got them. Even then...only the dually's and only on the top of the cab.
