Quality Interior LED light upgrades?
Discussion in '5th Gen 4Runners (2010-2024)' started by Skeeterzx195c, Jan 25, 2024.
  1. Jan 30, 2024 at 9:34 AM
    I don't have a good explanation, but I did notice that when I install dome light in my 2018 and 2019 I used 31mm LEDs and they did not fit my 2021. So I used 29mm LED for my 2021. BTW I'm using cheap Amazon bulbs, I bet good companies have bulbs that fit perfectly based on year vs trial and error I had to face.
    Anomaly[QUOTED] likes this.
  2. Jan 30, 2024 at 11:11 AM
    jake long15
    jake long15 Cali Raised LED
    Thanks for choosing us, we appreciate it!
  3. Jan 31, 2024 at 8:03 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2017 SR5
    I've had good luck with Superbrightleds.com. Just recently, I replaced all of the interior bulbs with the ones below. I opted for 4000K color because I wanted brighter, but not necessarily whiter, light. These are a little whiter than the factory bulbs but not obnoxiously so, and a bit brighter but again, not obnoxiously so. I've had meso replacements in my tundra which were great, but they're blindingly bright.
    You'll want three of these, one for the dome and two for the hatch.
    https://www.superbrightleds.com/de3175-led-light-bulb-4-smd-led-festoon-bulb-3022-base
    You'll want eight of these, two for map, two for vanity, four for doors.
    https://www.superbrightleds.com/194...wer-miniature-wedge-retrofit-car-194-xhp5-car
  4. Jan 31, 2024 at 8:32 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
    Stoney Ranger likes this.
  5. Jan 31, 2024 at 1:29 PM
    Photon_Chaser 48576 and counting…
    Roger
    Sierra Nevada Mountains
    Seriously? I just placed my order for these hatch lights yesterday at noon!!
    kolter45, 2016SR5P and wdsteven like this.
  6. Jan 31, 2024 at 2:58 PM
    wdsteven
    wdsteven New Member
    You will find that the MESO Custom LED are better than nearly everything else out there being Pushed.... Yeah sure one can buy cheaper bulb inserts that go in the Bulb socket and what they will find out is with some they are so hot running if you leave them on for too long the plastic around the socket starts turning darker brown and the copper tabs start to loose good connection. I know this because I have repaired one Tacoma map light assembly and a 4Runner rear dome light assembly <---- Replaced entire fixture.
    2016SR5P likes this.
