Putting into 4 Wheel drive
Discussion in '5th Gen 4Runners (2010-2024)' started by kjfswkr, Jan 29, 2024.
  1. Jan 29, 2024 at 10:06 PM
    Apparently, it needed one more whack.
    Stoney Ranger likes this.
  2. Jan 30, 2024 at 3:56 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    There is no issue with shifting into low from natural on the Tcase. If you're experiencing grinding you need to shift faster
  3. Jan 30, 2024 at 4:23 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    then why stop on N at all? That's the point, go directly from 4H to 4Lo, or 4Lo to 4H, and don't stop at N on the transfer case for the purpose of shifting between the two modes.
  4. Jan 30, 2024 at 4:31 PM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    No, you stop and put the transmission in N. Then shift the TC from 4H to 4L (yes, this lever moves past a N position as well).
  5. Jan 30, 2024 at 4:40 PM
    FourBelugas
    23 white ORP
    Read my original post and it will be abundantly clear to you I was referring to N on the transfer case shifter. But if you are just here to argue semantics, have at it.
    Slopemaster likes this.
