problem- in 4 high, a binding in front end when turning, either direction,
Discussion in '5th Gen 4Runners (2010-2024)' started by rockwind1, Nov 12, 2022.
  1. Nov 15, 2022 at 9:56 AM
    I've always used ramps. Seems to me more of the oil is likely to drain out of the oil pan that way.
  2. Nov 15, 2022 at 9:59 AM
    To be fair, overlanders don't really know anything. :bananadead:
    ESCT4R likes this.
  3. Nov 15, 2022 at 10:00 AM
    At the risk of stoking a controversy:
    With the use of ramps, how much oil will remain in the drain pan that wouldn’t otherwise? A shot glass full?
    Shot glass = 1.5 oz.
    4R oil capacity = 6.6 qt. = 211.2 oz.
    1.5 oz. ≈ 0.7% of 6.6 quarts. Less than 1%.
    I think ramps are okay.
  4. Nov 15, 2022 at 11:17 AM
    Only reason I don't use ramps is because I rotate tires same time.
    Gotta jack it up anyways.
    Trail Runnah likes this.
  5. Nov 15, 2022 at 11:58 AM
    Why use ramps when there's plenty of room under the thing in the first place :notsure:
    MeefZah and SlvrSlug like this.
  6. Nov 15, 2022 at 12:30 PM
    Mine is stock height, I can't comfortably get under it. With the RCI skids it has about the same ground clearance as my Volvo wagon.
    Singleminded and nimby[QUOTED] like this.
  7. Nov 15, 2022 at 1:29 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    All this talk about drivetrain binding and slipping ramps, glad I have a Limited…:boink::cool:
    McSpazatron and Captain Spalding like this.
  8. Nov 15, 2022 at 1:38 PM
    Unless you thin as a thooth pick plenty isn't the word I'd use.
  9. Nov 15, 2022 at 2:30 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I wondered the same thing
  10. Nov 15, 2022 at 4:09 PM
    Some of us are more “pleasantly plump” than others. :anonymous:
    Spare Parts and Singleminded like this.
  11. Nov 15, 2022 at 4:10 PM
    Singleminded
    OEM LED foglights
    I used ramps and still hit my head...
    I've done changes with no ramps on cars that had much less ground clearance -- but they had the filter on top of the block. Makes a big difference when the only thing ya gotta do under the car is drain the pan and reinstall the bolt!
    My new car arriving in 2-3 weeks (I hope) has the filter on top of the block. Can't wait!
  12. Nov 15, 2022 at 4:14 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Big boned I thought it was, but I do like pleasantly plump.
  13. Nov 15, 2022 at 4:18 PM
    Fair enough…probably the simplest way to explain to the OP why the postt looked like a troll.
    I’ll take him at his word that it wasnt, because I believe it’s possible to have gaps in knowledge (even if they are glaring, huge, and embarrassing:poking:;)). Also, maybe he hasnt told us he has a Limited, and he was right all along haha
  14. Nov 15, 2022 at 4:20 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    4H is OK on pavement only if you are going straight and or very subtle curves. Otherwise it 4H should only be used on icey and or other surfaces that would allow 'slipping'. When you are on DRY pavement and turning in 4H, it will cause binding as one side is not able to 'slip'. Wheels in 4H want to turn at the same ratio. When turning in 4H, the outer tires don't rotate at the same ratio as the inner tires - that's why you get the binding/tight feeling.
  15. Nov 15, 2022 at 4:23 PM
    Well, as long as nobody is checking the oil level while it’s on the ramp!
    But it’s ok to do the work on the ramp because you can put in almost all the oil and it’s fine to start. Top it off on the ground while it’s level.
    also, when it’s on then ramp, It’s easierto look around and inspect.
  16. Nov 15, 2022 at 4:30 PM
    At the risk of :deadhorse:
    The OP said that he was going slow, implying perhaps that it was less of a concern since he didnt go fast. CV joints and transfer case dont care. Actually slow is worse since it’s turning the tightest and causing maximum binding. It’s like somebody standing with 150lbs on their shoulder. And someone else slowly pushing on your knee joint with more and more pressure. It doesnt matter if it’s slow. When it pops, it pops.
    What a horrible analogy. Im gonna give myself a time out for that visual.
