PRO lift options
Discussion in 'Suspension' started by Jynarik, Jun 13, 2020.
  1. Aug 4, 2020 at 3:52 PM
    #61
    ForRun
    ForRun 4Runner
    2020 orp
    You won't regret it for a second. That other brand is probably fine, bit Eibach has been doing this along time. As long as it took them you know they did the R&D!
    Jynarik[OP] and nimby like this.
  2. Aug 4, 2020 at 6:36 PM
    #62
    Jynarik
    Jynarik [OP] I like boobies
    Austin Texas
    2019 trd pro voodoo
    @Thatbassguy @nimby thoughts on the ratings for the tires? Seeing speed ratings and load ratings as well as light truck vs regular p (for nitto). Both toyo and nitto are pretty close in price
  3. Aug 4, 2020 at 6:48 PM
    #63
    You can get the Toyos in P rated and they're super light. If you don't off-road much, this might be a good option as you won't lose as much fuel economy, and it will accelerate better.
    I'm on the C rated version. I really only notice the difference when I'm heavy on the throttle. It still gets in and out of traffic just fine.
    The load range E version of the Toyos is only 1# heavier than my C's, so probably a good option if you're off-road a lot.
    I don't know much about the Nittos.
    nimby and Jynarik[OP] like this.
  4. Aug 4, 2020 at 6:53 PM
    #64
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    what’s your MPG on those? I think the nitto LT’s are like 7-9lbs heavier per tire
  5. Aug 4, 2020 at 7:07 PM
    #65
    20AGPro
    20AGPro New Member
    2020 Army Green TRD Pro 4Runner
    The Nitto RG is pretty loud and rough too. They’re not the smoothest ride if you’ve never had them. My brother has 285/70/17 and they look great but not a great ride if you drive a lot on road. If y’all know anyone wanting a set of M/T that are great I have a set of 295/70/17 BFG KM3 with only 20 miles on them. Set of 5 I’d give someone a good deal on. Took them off my Jeep when I traded it in for 4Runner and they’re brand new. Basically same height as 285 just a little wider.
  6. Aug 4, 2020 at 7:14 PM
    #66
    eelski
    eelski New Member
    eelski
    2015 4runner TRD Pro
    When in doubt..... call the boyz at TOYTEC......they'll give you plenty of options
  7. Aug 4, 2020 at 7:15 PM
    #67
    I'm getting 15-19 depending on what I'm doing. This is with basically full armor, lift, roof basket, and always lugging extra weight(tools, recovery gear, etc). This is also more accurate than with stock size tires, as the speedo is accurate with 285's. They read high with stock size tires.
    Nice! Those are supposed to be kickass tires!
    nimby likes this.
  8. Aug 4, 2020 at 7:39 PM
    #68
    I concur. If you're frequenting trails with sharp rocks, LT (or C-rated) will be better for your situation.
    If you're doing fire roads, mellow trails, and mostly street driving then you'll be fine with P-rated tires.
  9. Aug 4, 2020 at 7:53 PM
    #69
    20AGPro
    20AGPro New Member
    Yes they’re awesome. The quietest smoothest M/t I’ve ever ran and I’ve ran a lot. They were as smooth as my KO2 I ran and just a little louder. I need to find a Tacoma owner for them probably. Didn’t mean to highjack the thread but someone may want them since we got on tires.
  10. Aug 4, 2020 at 11:40 PM
    #70
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    Well. Screw all you guys. Y'all just make me spend money. Jerks
    A&P, nimby and Thatbassguy like this.
  11. Aug 5, 2020 at 2:54 AM
    #71
    We do what we can.;)
    A&P and nimby like this.
  12. Aug 5, 2020 at 4:17 AM
    #72
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    So you were sitting a little higher than stock before the springs then? Did you have the spacers taken off prior to the install of your new springs?
    Just trying to picture the springs on a stock suspension
  13. Aug 5, 2020 at 5:10 AM
    #73
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    wheel spacers not lift spacers
  14. Aug 5, 2020 at 5:44 AM
    #74
    2A4R
    2A4R New Member
    Northern VA
    19 4R TRD PRO
    Ahh my mistake. Well it looks great. What awning do you have and how do you like it?
  15. Aug 5, 2020 at 6:46 AM
    #75
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    ironman4x4 2.5mx2.5m
    Love it. Comes with led lighting and mounts
    2A4R[QUOTED] and Thatbassguy like this.
  16. Aug 5, 2020 at 7:50 AM
    #76
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Ordered ridge grapplers in 285’s. May have got a little overzealous cuz I’m not sure if they’ll fit without rubbing. Doing bumper chop at end of month
    thirdyota, nimby and Thatbassguy like this.
  17. Aug 5, 2020 at 8:04 AM
    #77
    I was going to ask the same question! I have a little second hand ARB. It's nice, but a little smaller than I'd like.
    Just get them and deal with the rubbing as necessary. When you get your alignment, tell them to give you as much caster as possible while keeping camber and toe in spec. I didn't do that, and had to get it done again later.
  18. Aug 5, 2020 at 8:47 AM
    #78
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Dude cannot wait to see them hope it works out. That’s what I want to do but don’t know if there going to clear with my SCS wheels with being 8.5 inch wheel.
    Jynarik[QUOTED][OP] likes this.
  19. Aug 5, 2020 at 11:16 AM
    #79
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Went ahead and took the mud flaps off and cut some of the fender. Install within the next couple of hours :spending::spending::spending:
  20. Aug 5, 2020 at 11:22 AM
    #80
    RusPro17
    Don
    Pa.
    Dude good one with the charge card!! Lol. If you can post some close pics where you cut if it needed it appreciate it.
  21. Aug 5, 2020 at 11:25 AM
    #81
    Are you doing the standard bumper cuts? I don't think you should need to cut/adjust anything but the mud-flaps and possibly a BMC if the alignment doesn't give you enough clearance
  22. Aug 5, 2020 at 12:55 PM
    #82
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    I cut a piece off the bottom inside bumper. Pics soon. The front plastic rubs like a mofo so I’ll heat gun that some more, and I will need to have some metal cut on full turn reverse cuz it’s about .25 from rubbing on flat ground. I said fuggit and put them on. My tundra rubbed like a bastage compared to this
  23. Aug 5, 2020 at 1:00 PM
    #83
    Jynarik
    Austin Texas
    2019 trd pro voodoo
  24. Aug 5, 2020 at 1:08 PM
    #84
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Getting close!
    Jynarik[OP] likes this.
  25. Aug 5, 2020 at 2:17 PM
    #85
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    No issues on the drive home, so I’m going to wait until the end of the month when I put my bumper on to chopC657038C-EDD3-473C-9CEC-795A40C455CD.jpg2257A311-AD3B-4F34-AAE6-BCEF69DE9BA6.jpg
    2Toys, A&P, tntoverland and 4 others like this.
  26. Aug 5, 2020 at 2:25 PM
    #86
    Looks really nice!
  27. Aug 5, 2020 at 2:43 PM
    #87
    RusPro17
    Don
    Pa.
    Looks awesome!!
  28. Aug 5, 2020 at 2:57 PM
    #88
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Thanks fellers. Winch and bumper and I’m calling it good for now. Hopefully be doing some trips in a couple months if national parks open up0685BF19-0B63-4915-B40B-DAC67E07DCC0.jpg
    2Toys, A&P, nimby and 1 other person like this.
  29. Aug 5, 2020 at 3:13 PM
    #89
    Those Nittos are great looking tires!
    What bumper and winch are you going with?
  30. Aug 5, 2020 at 3:15 PM
    #90
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    I have a c4 slimline that should be done by the 9th. Warn evo 10s sitting in the corner for the last month waiting
