Premium quality KDSS compatible lift kit
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Sep 17, 2023.
  1. Sep 19, 2023 at 2:51 PM
    2023_lunarrock-ORP
    2023_lunarrock-ORP Pistolero
    Brandon
    Pacific Northwest
    2023 lunar rock orp
  2. Sep 19, 2023 at 2:59 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    That dealer quote was a deep pocket quote.
    Spend $3000 on a good set and DIY
    Yotaholic[OP] likes this.
  3. Sep 19, 2023 at 3:10 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Thank god. You could have had a decent actual full lift for that!
    Yotaholic[QUOTED][OP] likes this.
  4. Sep 19, 2023 at 3:12 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Recommend something
    djwantke likes this.
  5. Sep 19, 2023 at 3:17 PM
  6. Sep 19, 2023 at 3:17 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Yotaholic so you're talking about a preload collar lift kit you were interested in right?
    Hopefully I can help and give you a little bit of information to compare pricing.
    First go to a decent off road shop not a stealership.
    Second, I never recommend spacer lifts and any of your 4 corners, especially the front.
    Try to do a suspension lift, upgrade the springs and or shocks, and upgrade UCA's if going up 3".
    My pricing is Canadian, in 2021, but for $3K USD and even a little bit of YouTube and sweat-equity you could prolly avoid spacers all together.
  7. Sep 19, 2023 at 4:36 PM
    Dobinson. Options for different budgets, and everyone seems to love them. Also, we have an expert/dealer who frequents this site.
    Edit: link:
    https://www.4runners.com/threads/dobinsons-5th-gen-4runner-suspension-options.13289/
    Or, Eibach. This seems to be the best entry/mid grade option. Similar in cost to a Bilstein 6112 setup, but people seem more satisfied with the Eibachs.
  8. Sep 19, 2023 at 4:40 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Agree with dobinsons - but I'm biased because that's what I have. I also spent tons of time researching the forums. That was my final answer
  9. Sep 19, 2023 at 4:55 PM
    Crikey Mike! Legend
  10. Sep 19, 2023 at 5:02 PM
    Yotaholic
    Olympia, WA
  11. Sep 19, 2023 at 6:16 PM
    Hyrule_trd
    Hyrule_trd New Member
    Eric
    MD
    2020 Tacoma
    Ironman Foam Cell Pro, MESO stuff, other things I can’t remember
    I don’t know much but a few things about Ironman. I’ve got the Foam Cell Pros on my Tacoma and have been happy with them. I chose them over Billies, fox and saving for kings. One major point was they are “maintenance free,” unlike Fox and King that need to be rebuilt ever so often. The Ironmans also dont have nitrogen in them so even if they did need to be rebuilt, it’s a DIY type of thing.
    My only dislike with IM is their marketing practices, they are always on sale and it can give the appearance of being cheap. I don’t think my kit is cheap. Stiff yes, cheap no.
    Thatbassguy and Yotaholic[OP] like this.
  12. Sep 19, 2023 at 6:18 PM
    Yotaholic
    Olympia, WA
    Called multiple shops, everybody says 8 hours. At the minimum they charge is $175/hour.
  13. Sep 19, 2023 at 6:21 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    8 hours for spacers or full suspension change?
    Swapping my front struts (pre-assembled), UCA's, rear shocks and coils, and mounting 5 new tires (bought a matching spare) only took my shop a day - which I assume was 8 hours
  14. Sep 19, 2023 at 6:54 PM
    Yotaholic
    Olympia, WA
    Well, the stealership said 8 hours for that spacer, off-road shops say 8 hours for the full kit
  15. Sep 19, 2023 at 7:03 PM
    Full kit should take no more than 4 hours if they know what they are doing.
  16. Sep 19, 2023 at 7:09 PM
    Yotaholic
    Olympia, WA
    They know exactly what they're doing, they are making more money.
    Thatbassguy and djwantke like this.
  17. Sep 19, 2023 at 7:33 PM
  18. Sep 19, 2023 at 7:49 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Are you in it just for looks? Go cheap level kit and get a 4x4 shop to do it.
    Any other use, involving off road, the Dobinsons etc. good budget options. You’ll be touching all four corners.
    As noted, don’t go to a dealership. Learn to wrench on it yourself, the money you save can offset buying the tools you’ll need.
    Cheers
  19. Sep 20, 2023 at 2:52 AM
    #49
    True. But, some of them will still bill you for 8.
    Yup.
  20. Sep 20, 2023 at 4:41 AM
    #50
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    ^^^^^ This. If you just want it to look cool, at the walmart parking lot, in your driveway for pics,... then spacers/low budget are totally fine. Do that. Itll drive to mcdonalds just fine.
    If your gonna beat on the thing, then get shit that actually does something. This nova/mike guy gets it.
    Yotaholic[OP] and Thatbassguy like this.
  21. Sep 20, 2023 at 8:48 AM
    #51
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Eibach would probably be the most cost effective other than Bilstein's. Are you a DIY person? That would save a lot of labor.
  22. Sep 20, 2023 at 10:34 AM
    #52
    bigdaddy2021
    bigdaddy2021 New Member
    Brian
    So-Cal
    2019 4runner - TRD Off-Road
    Armored, Dobinson's lift, 33's, MC TacoBox, Frontrunner rack, light overland mods, M8000 winch.
    Hey, yotaholic, my recommendation would be to give @Crikeymike a call.
    He set us up with Dobinson’s springs, shock’s,Treaty Oak KDSS spacers, and Dobinson’s Upper control arms for about a 2.5-2.75” lift. Fits our 33’s (285/70’s) perfectly w/ no rubbing offroad.
    We’ve beat the living sh!t out of our setup running a heavy load-out for the last 15k miles. Amazing articulation offroad in the slow stuff, very good damping doing some Anza-Borrego desert corrugations at about 30-40mph, comfy on the highway doing 80mph.
    Crikeymike and Yotaholic[OP] like this.
  23. Sep 20, 2023 at 12:29 PM
    #53
    Yotaholic
    Olympia, WA
    Hey thanks!
    bigdaddy2021[QUOTED] likes this.
  24. Sep 20, 2023 at 12:30 PM
    #54
    Yotaholic
    Olympia, WA
    Is this the kit you have?
  25. Sep 20, 2023 at 12:50 PM
    #55
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    Yo I just started reading this thread: sensors reprogrammed? Gtfoh
  26. Sep 20, 2023 at 12:58 PM
    #56
    bigdaddy2021
    Brian
    So-Cal
    I think so, yup. Here’s exactly what i ordered from @Crikeymike in 2021, for a heavy overland build with armor/bumpers/winch/cooler, etc.
  27. Sep 20, 2023 at 1:32 PM
    #57
    nova
    nova New Member
    mike
    One more thing to consider. I’m guessing, but I’m not sure you have worked out just what you want from your truck. I sense that questions like ‘tell me what I should buy’ indicate you’re new at this. There is no shame in that, we all here to learn!
    If you want to save time and money, figure out what you want to do with it. And once you do, you should invest the time to learn how IFS works.
    There are many sad stories of people who have been unhappy with costly modifications. Luckily there are many good sources of information. I most benefited from Accutune, Filthy Motor Sports and Kai of Tinkerers Adventures
    I recommend you get your vision and education. Run your questions past the forum, you’ll have an awesome rig!
    Cheers
  28. Sep 20, 2023 at 1:40 PM
    #58
    bigdaddy2021
    Brian
    So-Cal
    Great post, Mike. Good suggestions.
