Portable air compressor
Discussion in 'General 4Runner Talk' started by 5six, Aug 19, 2022.
  1. Jul 14, 2023 at 3:10 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    As a fellow Canadian you can always give Craftsman a look, as mentioned by some folks. I run an affordable 120v Inflator off the rear plug, upgraded battery too but not even needed, and fastened it down in cargo (and yes that's a screwed down garbage can!) Good enough for me, before I invest in hoses like u
  2. Jul 14, 2023 at 3:12 PM
    :spending:
    I would love to try!
  3. Jul 14, 2023 at 3:19 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Milwaukee M18
  4. Jul 14, 2023 at 3:21 PM
    TRDSD
    2019 TRD Off Road Premium
    Viair are pretty bulletproof and come at different price points to fit most budgets. I have the 450p that's 100% duty-cycle (so you don't have to turn it off between fills) and it works great. Paired it with a Speedflate 4-tire inflator/deflator hose system. Couldn't be easier.
  5. Jul 14, 2023 at 3:22 PM
    Just wanted a photo now this is happening
  6. Jul 14, 2023 at 3:30 PM
    For Canadians this is a good value: https://nsor.com/rfx-rfx41000.html
    Made in the same Chinese gulag as the Smittybilt but cheaper, and about as fast as an ARB single.
    Klinsman55 and djwantke like this.
  7. Jul 14, 2023 at 4:12 PM
    I just purchased this one, but will be a few days before i get it.
    Klinsman55 likes this.
  8. Jul 14, 2023 at 8:33 PM
    ^Yep basically the twin-piston version of the Smittybilt, a variation having been available at Summit Off Road for a couple of years: https://sswoffroad.com/collections/misc/products/ssw-dual-air-compressor
    I use a similar one from AliExpress, inflates each of my 35" tire from 15 to 30 psi in 50 sec. It's being throttled by the shrader valve, so you'd need one of those hose kits that inflate all four tires simultaneously to take full advantage of this inflator's flow rate.
  9. Jul 28, 2023 at 3:03 PM
    Weld-everything
    Weld-everything New Member
    Eric
    86 SR5 4runner
    My good ol' Milwaukee 18 volt cordless compressor works great for me. Nice to have something you pull out and carry around easily.
    Also have a Powertank which I mainly use for racers and other big tire buggies in the desert.
    2ndGen22re, Thacrow and djwantke like this.
  10. Jul 28, 2023 at 4:42 PM
    Austin26
    Austin26 New Member
    Austin
    5th gen ORP
    I have a single ARB for my 33" tires. I couldn't be happier. Ran off a switch/fuse kit but relayed with a breaker for the power wires as they need to be protected at 40A and the switches/fuses are a max of 30A. Could have just powered it without a switch but wanted some redundancy.
    So handy, air up people's tires that need it and of course for off roading.
    djwantke likes this.
  11. Aug 2, 2023 at 6:08 PM
    I have the maxi-trac from Napa. It's a twin piston. The things a beast, I had to use it the other day, I came out to find a tire that was completely flat. I set the compressor up to inflate it back up to plug it, I let it run maybe 2 minutes and it had the tire up to 50 PSI. I pulled the nail, plugged it, and still had to let about 10 psi out of it when I was done.
    Austin26 and SlvrSlug like this.
  12. Aug 13, 2023 at 12:04 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
  13. Aug 13, 2023 at 5:20 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
  14. Aug 13, 2023 at 5:32 PM
    I like that it will turn itself off at a pre-set pressure. And that it has a high-volume/low-pressure mode for inflating mattresses and such.
    gomiami and hossler1788[QUOTED] like this.
  15. Aug 14, 2023 at 8:26 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I have the Kobalt 24v compressor mainly because I have a lot of Kobalt tools and batteries.
    It seems quite durable, I have loaned it to buddies and they like it as well.
    The only issue I have had with it is it has trouble with low pressure applications, it over fills ATV tires (4-6psi) to about 9-10psi. At higher pressures it works fine.
    It was only $40 a couple years ago but is $48 now.
  16. Aug 14, 2023 at 8:36 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    That's the one I want. But can it run long enough to refill 4 tires from 15psi to 38psi without giving time to cool off?
  17. Aug 14, 2023 at 7:27 PM
    I believe it can. I watched a couple of videos of the DeWalt filling tires. The tire size wasn’t mentioned, but in each case it was 8 minutes from 0-32 psi. As far as the run time between resting goes, in the manual it says this:
    NOTE: If the pressure rating for the item being inflated
    is above 100 psi, note that the maximum run time is
    10 minutes. Leave to rest for 20 minutes before reusing.
    Ripper238[QUOTED] likes this.
  18. Aug 15, 2023 at 5:20 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I obtained the larger Smittybuilt 2780. I plan to share with my nephew who has a Bronco with 37x12.5 KO2. He airs down from highway 40 to 25-30 for off road. My stock size AT I air down from highway 34 to 25 off road. Air up is fast -about 5 min for the big KO2 and about 2 min for my stock size. I am finishing up the install of the C4 fabrication 2nd battery platform to carry the Smittybuilt when on a trip. Its between the firewall and air box. No plans for hardwiring, just a good spot for carry and use off the ground.IMG_0430.jpg IMG_9520.jpg
    Klinsman55 and ReRunner like this.
  19. Aug 15, 2023 at 5:47 PM
    #49
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    It can do it on a full charge. But it might take a little while. Especially with larger tires.
  20. Aug 26, 2023 at 9:02 PM
    #50
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    I have same works well so far. Was looking at higher end brands that were several $100 more but for my use figured this would be sufficient. Seems to inflate pretty quick.
    bought this digital tire pressure gauge (Jaco) and to release air. Used it twice. Works well and pretty fast. About a minute to get tire from 36 psi to 25 psi
    https://amzn.to/44hnZPq
    Smittybilt. Took a minute to get from 25 psi to 38 psi. Will be posting a YouTube video soon of it in action
    https://amzn.to/3qOfM7t
  21. Sep 4, 2023 at 8:43 AM
    #51
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Can you use this without injecting the slime goo?
    Does your 24v charger work on the 100w inverter? Thanks, not an experienced electricity user:cool: (gonna shop kobalt24v)
    edit thanks, I see now that input wattage is listed on the charger sticker
  22. Sep 4, 2023 at 10:56 AM
    #52
    2ndGen22re
    CR
    Carson Valley, NV
    Just tried an old 45w(left) and the new 85w(right) that came with the current package and no problems at all.
    I know they sell a +120w but I don’t have one. IMHO the slow charger is somewhat responsible for the long battery life I’m getting. We will see what the 85w brings. Hard charging lithium batteries shortens their life.
    The pics leave out the yard tools…weed wacker, blower, hedge trimmer along with 2 other flashlights, drill, impact driver, more batteries and 2nd old 45w charger. I’m going to get the ‘free’ 90 degree drill with another (2)4A batteries /charger package this week as well…..waaaay too good of a deal for 150 bucks for all to pass up!
    I also have had the 80v mower now for 5yrs, love it. I have a lot of gas engines to take care of and one less is welcome, especially a boring lawn mower. It ALWAYS starts up!
    pastoreater[QUOTED] likes this.
  23. Oct 6, 2023 at 11:57 AM
    #53
    weeeniewagon
    weeeniewagon New Member
  24. Oct 6, 2023 at 12:19 PM
    #54
    2ndGen22re
    CR
    Carson Valley, NV
    Do you have any Ryobi batteries now?
  25. Oct 6, 2023 at 12:30 PM
    #55
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
  26. Oct 6, 2023 at 12:59 PM
    #56
    weeeniewagon
    a buddy has a couple extra batteries he doesnt care for. the reviews look pretty decent for what it is
  27. Oct 6, 2023 at 1:10 PM
    #57
    Dabigono
    Dabigono Just Joined
    2020 4Runner
  28. Oct 9, 2023 at 3:10 PM
    #58
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I have a Milwaukie 18V inflator so impact takes same battery. Now I carry a charger to plug and charge driving. It's advertised as Inflating 8- 33:12.50 on one battery. It is pretty impressive compared to the 12V which will still save you just slower and longer. Plug kit, impact, tow strap, toilet paper. Only use Toyota toilet paper. Trimmer, mower and everything takes same battery. They really good tools.
    2ndGen22re likes this.
  29. Oct 9, 2023 at 3:22 PM
    #59
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    The basics just to stay rolling without calling anyone. A spray bottle of soapy water is good. I haven't yet but usually flip spare over. Easier to check pressure for tire light when it gets cold. Not as big a mud scoop or hook.
