Poll do you use Toyota Transfer case fluid or other
Discussion in '5th Gen 4Runners (2010-2024)' started by 2021venture, Aug 18, 2023.
What fluid in transfer case
  1. Toyota fluid
    13 vote(s)
    28.3%
  2. Other
    33 vote(s)
    71.7%
  1. Aug 21, 2023 at 2:23 PM
    2021venture
    2021venture [OP] New Member
    Todd
    2021 Venture
    Man I wish everyone would use the bags. Soooo much easier than a pump. Amsoil and Valvoline are only bags I have seen.
  2. Aug 21, 2023 at 2:24 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    The Toyota fluid is hard to find. If it were important, Toyota would make it readily available. Some dealerships don't use it. So I dont try to find it.
    Any gear oil that has met the API ratings is the same to me when it's going into a TC or a diff. Only manual transmission fluid do I care about the brand.
    I used Lucas in mine. But I don't have any brand loyalty.
  3. Aug 22, 2023 at 8:06 AM
    Totally agree, I’ve started using the Valvoline bags and it’s been life changing.
  4. Aug 22, 2023 at 9:34 AM
    TRDSD
    2019 TRD Off Road Premium
    Redline MT-LV for me. They make great products and it's the closest in spec and formulation to the OEM fluid.
  5. Aug 22, 2023 at 11:16 AM
    Red-line for me. Doing it this weekend actually.
  6. Aug 22, 2023 at 11:21 AM
    2016Pro
    I bought toyota fluid only because I was not clear on what type of fluid was needed. I'll get whatever fluid is cheapest going forward
  7. Aug 22, 2023 at 2:48 PM
    The 3rd gen Taco is spec'd for the LF fluid; some people reported shifting problems in the winter with 75W90. I don't know if the 5th gen 4Runner is similarly susceptible if you have a stick shift T-case.
    6th gen will probably go to WS transmission fluid for the transfer case, like with the 2022+ Tundra.
  8. Aug 22, 2023 at 2:51 PM
    2021venture
    Todd
    2021 Venture
    I saw the same cold weather shift comments on Tacomas. Likely we will hear about it on this forum with majority of poll not using the Toyota fluid. I suspect most people that take to dealer for service are not getting the Toyota fluid even if not aware.
    I think it's the same transfer case shared between taco and 4runner.
  9. Aug 22, 2023 at 2:58 PM
    ^Don't be naive. Most people don't change the transfer case fluid. :laugh:
  10. Aug 22, 2023 at 2:59 PM
    2021venture
    Todd
    2021 Venture
    Your probably right. The masses probably have the lifetime factory fill.
  11. Aug 27, 2023 at 11:12 AM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
    I'm going to save one bag once I do the front diff, and refill it for the ATF and the transfer case. It saves SO much time to do it that way.
    Old Tanker likes this.
  12. Aug 27, 2023 at 6:38 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I most recently used Valvoline (in the bags) for the front and read diffs and Redline for the TC. I did the diffs first and found the Valvoline bags to be so easy to use that I transferred the Redline to one of the empty Valvoline bags to use to fill the TC - made it so easy…
    Cheers,
    Bob
    TrailGuy2016 and Old Tanker like this.
  13. Aug 28, 2023 at 7:51 AM
    I've had good luck with this hand pump, available under various labels at your local auto parts store. Works pretty fast (about 5 strokes per bottle) as long as you trim the hoses to remove any kinks from the packaging:
    https://www.oreillyauto.com/detail/c/performance-tool/performance-tool-transfer-pump/pfm0/w1145
    https://www.amazon.com/LOZAGU-Multi-Use-Siphon-Transfer-Liquids/dp/B0C5DZ29PR/
    Trail Runnah likes this.
  14. Aug 28, 2023 at 8:14 AM
    I replaced the fluid in both diffs and the t-case about 50k ago, I used the same fluid for all 3.
    I'm going to be changing them again soon, doing the same.
    That hand pump above is clutch, pour the new fluid into a clean gallon container and it makes the job SO much easier.
