PLEASE HELP!! Lift kit vs leveling!
Discussion in '5th Gen 4Runners (2010-2024)' started by GEAUX4R, Sep 17, 2022.
  1. Sep 20, 2022 at 9:29 AM
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
    I am running Bilstein 6112 up front, set at the highest clip setting. The rears are Bilstein 5160 with the Bilstein 1.5" springs. The tires are Mickey Thompson Baja Boss AT in 285/70/17. I am also using the SPC upper control arms.
    This gives me about 2.7/3" lift in the front, and 2" in the rear. I off-road often, and this combo works for me. Good luck!
    YetiMtnBkr, 4RunninSH and Steve40th like this.
  2. Sep 22, 2022 at 10:32 PM
    telog
    telog GreenMachine
    TL
    CO
    ArmyGreen
    Method 701, RSG rock sliders, Dobinsons uca, Cali Raised Bumper Warn Evo Winch
    I just picked up a 2020 trd pro off lease. Fox shocks and added the Eibach spring lift 2 day ago. Went from 21.5 center wheel to 23 front and 23.75 rear. Although the slight front slant, visually looks even. Took off the pro roof basked for a Sherpa that my neighbor sold me. Still running 265/70/17 and still looks good. Holding off on tires since there’s a lot of life on the ridge grapplers.
  3. Sep 23, 2022 at 3:25 AM
    hvac guy
    hvac guy New Member
    Looks great! What Eibach spring lift did you go with?
  4. Sep 23, 2022 at 8:46 AM
    telog
    telog GreenMachine
    TL
    CO
    ArmyGreen
  5. Sep 26, 2022 at 1:02 PM
    yotaloma
    yotaloma New Member
    Roland
    Sin City , NV.
    22’ 4Runner TRD ORP Classic Silver Mat
    Upgraded suspension w/ Dobinsons 2” IMS leveling kit. RRW H6 hybrid on 275/70/17 BFG-KO2’s, Sherpa Crestone roof rack.
    I went with Dobinsons IMS as well (“leveling kit”) with option to add springs or utilize OE. I also have 275’s BFG KO2 on 17’s -12 offset. After all that I thought no rubbing issues, slight rubbng on BM.
  6. Oct 28, 2022 at 1:34 PM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    For the kit below that someone listed. If the goal is to get level why would the kit stay at factory level 0 or raise the rear by 1.5" would it not make more rake? Or is this more for when you tow a lot so that the rear does not sag to much? Having said that I towed a trailer with approx. 600lbs tongue weight and it still had a very gentle forward rake.
    Adjustable rear coils:
    LOAD-LEVELING SYSTEM (Rear) (For Zero Added Weight)TOYOTA 4Runner 4WD
    ak31-82-071-01-02
    https://eibach.com/us/2000/ak31-82-071-01-02-TOYOTA-4Runner-load-leveling-system
  7. Oct 28, 2022 at 2:52 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    These are adjustable. See the perches with the screw threads. What this means is that if you have not added any weight to your vehicle (i.e. rear bumper / tire carrier, drawers, roof top tent etc...) this will give you between 0" of lift and 1.5" of lift depending on where you set the spring perch.
    Alternately put, if you have added weight to the rear, these could lift the rear back up a bit to make it level. Too much weight and it will still sag from stock height, even at the highest setting.
  8. Oct 29, 2022 at 5:10 PM
    DUSTYDOGDAN
    DUSTYDOGDAN New Member
    2022 4Runner
    bone stock for now
    Getting rid of the front dive when emergency braking would be a great thing. It happened this summer to me and that feeling of doing a front flip would be nice to get rid of for sure.
    TrueTexas[QUOTED] and 2Toys like this.
  9. Oct 29, 2022 at 10:16 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Yes!! I got rid of it by replacing factory front shocks and springs with Bilstein 6112s (adjustable) with springs from Toytec.
