Photon (The Light Hunter) Build Thread
Discussion in '5th Gen Builds (2010-2024)' started by Photon_Chaser, Feb 11, 2024.
  1. Oct 9, 2024 at 3:16 PM
    #61
    Photon_Chaser [OP] 53,001 and counting…
    Up, down and all around!
    I'm working on a possible solution. :D
    acet7 and Pepper like this.
  2. Oct 10, 2024 at 7:19 PM
    #62
    Knobs and Things...(cont.)
    The 0.2 nozzles came in, gave the tuner knobs another go. Top row finer details! Bottom row, meh...
  3. Oct 10, 2024 at 7:21 PM
    #63
    On-Board Air (cont.)
    Switching gears cause more goodies arrived in the mail...Upgrade completed and saved a bit of room on the Molle Panel to boot.
    Old...
    Upgrade...
    Thacrow, acet7, yentup and 1 other person like this.
  4. Oct 29, 2024 at 12:07 PM
    #64
    After using the new on-board air storage set-up a couple of times I realized that I would like to try and eliminate the velcro tie downs. Result, a cleaner and quite robust clip-in method...clip in one end of the extension hose, wrap a turn and a half and clip in on the opposite side. No more fumbling with velcro and this can be easily used even with gloved hands. :cool:
    ©2024 PhotonChaser
    Saker, MEski4x4, Thacrow and 2 others like this.
  5. Nov 7, 2024 at 6:35 PM
    #65
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That's really cool. You don't mess around. Thank you for sharing your build and all the great info.
    Saker, djwantke and Photon_Chaser[OP] like this.
  6. Nov 7, 2024 at 9:03 PM
    #66
    There's a bunch more stuff in the works...:cool:
    Saker and djwantke like this.
  7. Nov 7, 2024 at 10:15 PM
    #67
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Dude I can't wait. You do good work.
  8. Nov 14, 2024 at 7:26 PM
    #68
    Switching it up over the long weekend with a trial fit of the SS5 Pods behind the grill using the Stealth mounting kit.
    Had a little work to do on the right headlight assembly while the bumper facia was off...
    The Stealth mounting frame attaches with just two of the main crash-bar bolts so it was a very easy install.
    Road test! Just the backlights on, I'll have to take an update photo once I'm in a better location to do so. Even though these are the 'Sport' version they are just too bright to use on-road and the 'Combo' lens pattern is a bit too wide (think flood)...I may get ahold of the 'driving' lens version as those have a more focused beam pattern.
    acet7, dgrenier15 and Thacrow like this.
  9. Nov 14, 2024 at 8:02 PM
    #69
    Next up, Winch Bumper!
    I did a great deal of thinking since the summer of 2023 about which Winch Bumper to go with and the final trigger was a helluva Veterans Day sale on a winch bumper with a free winch!
    The order arrived in three days and all components without a scratch!
    With the help of a good friend it took us the better part of 7 hours to do the full installation as there were a few confusing steps encountered along the way and we took frequent breaks to tend to other projects (we were timing a house painting project and some 3D printing simultaneously over the course of the day.)
    First off we had to remove the SS5 pods, the Stealth mounting frame and the crash bar.
  10. Nov 15, 2024 at 11:41 AM
    #70
    acet7
    acet7 New Member
    2021 Dark Grey TRD Off-Road 4Runner
    That is a sharp looking bumper.
  11. Nov 20, 2024 at 8:41 PM
    #71
    Air Hose Hanger revisited...
    Yeah, I think I'm overthinking this one too much, maybe I should just go back to velcro straps! :D
    Dabigono, acet7 and ThomasL like this.
  12. Nov 26, 2024 at 5:56 PM
    #72
    The factory installation instructions recommended that the winch cradle, winch, winch shell, etc. be all assembled first and installed in one cohesive assembly. With my shoulder acting up I did not feel able to lift up more than 50 lbs so we instead opted to install the cradle first, winch second and then the shell with light bar third.
    Here you can see there was ample room for the winch installation into the cradle. I only needed to slightly push on the AC cooling line about 1/4" to clear any contact with the winch's transmission end and did not need to do anything with the Power Steering line.
    By doing the install in this manner provided a much more accurate means of trimming the plastic bumper cover.
    acet7 likes this.
  13. Nov 26, 2024 at 6:06 PM
    #73
    Once we were satisfied with the fit/finish we then installed the front shell and with three bolts on each side and some elbow grease with the torque wrench...Et Voila!
    Now I eventually hope to re-install the SS5's behind the grill but with the storms happening right now I need the lights so...there happens to be two convenient perch details on the bumper which made a temporary installation possible.
    All in all I am very pleased with the quality of this bumper' construction. The welds are all perfect as is the powder coat finish. The inclusion of very beefy recovery points that are located down low and tied directly to the frame. I was a wee bit concerned about adding an additional 150 ibs up front but the decision last year to go with the Eibach upgrade springset handled the additional weight just fine...I think Photon lost a total of about 1/2" from the +1.4" gained by the springs.
    Pepper, acet7 and yentup like this.
  14. Nov 27, 2024 at 7:48 PM
    #74
    Winch Bumper Finale. Maybe...
    After having watched tons of videos I noticed that the bumper access cutouts could accumulate snow, mud and water intrusion so some quick measurements and a little CAD modeling later...
    I used two methods of attachment, no tool(s) needed. Already tested on a +150 mile drive...and the covers stay put.
    dgrenier15, acet7 and Thacrow like this.
  15. Nov 29, 2024 at 12:59 PM
    #75
    Knobs and things, part Trois....
    Slowly making progress on the proper print settings. I don't think I can get any more improvements to the font appearance but it's looking fairly decent now.
    Need to work on fine tuning of the ring base as it is a very tight snap fit. The design geometries are quite challenging as dimensional tolerances are difficult to match up (but not impossible.). Here is where I am at on the 3D model.
    Saker, Thacrow, Pepper and 2 others like this.
  16. Nov 30, 2024 at 12:08 PM
    #76
    Pepper
    Pepper New Member
    Heath
    East Central Alabama
    2022 ORP Barcelona Red
    Looks awesome
  17. Nov 30, 2024 at 1:46 PM
    #77
    Thanks! I’m fairly happy with the way things are coming along on this project. Printing version four right now, discovered that the Blue and Red ‘squares’ are a bit too thick (not allowing enough light through to see easily)…will know in a little over an hour from now!
    acet7 and JustATallDude like this.
  18. Nov 30, 2024 at 4:31 PM
    #78
    Got the SSC1s installed, I like the small form-factor and these do throw out a ton of light.
    Wiring however will have to wait, USPS failed to deliver this afternoon...
    MEski4x4, acet7 and Thacrow like this.
  19. Dec 6, 2024 at 7:50 AM
    #79
    Shifting gears (again). This time to address this one detail that's been kinda driving me nuts so while I was helping a good buddy with a re-wiring project, got out the calipers and made some measurements...
    The real trick is trying to match as closely as possible the front end grill and bumper color/textures.
    SR5 Limited, Thacrow and acet7 like this.
  20. Dec 8, 2024 at 3:04 PM
    #80
    So....the winch came with a wired/wireless control pendant! I just figured out how to take advantage of the pendant's magnet with a nifty cradle on the molle panel.
    djwantke, acet7 and Thacrow like this.
  21. Dec 9, 2024 at 4:22 PM
    #81
    The Flatlink arrived, finally get to properly stow the winch line. I needed to fabricate some extensions for the license plate frame as the Flatlink is a good 2 1/2" think.
    ChessGuy, acet7 and Thacrow like this.
  22. Dec 11, 2024 at 5:50 PM
    #82
    Headed to the central coast to hopefully get an OTT tune for Photon and an opportunity to test out the newly installed signal booster.
    I went with the Bolton Technical for three reasons:
    1. Comparable Uplink/Downlink signal gain to other popular amplifiers.
    2. I like the antenna design, narrower side profile...no wind noise! And to me isn't much of an eyesore as having a big end-loaded antenna on a mast.
    3. Great Customer Service experience. I ordered the amplifier kit and antenna off Amazon but the company that sold the unit (based somewhere in Texas) short changed me of an important SMA adapter. I emailed Bolton and a rep. responded within an hour. Shipped next day the adapter to me at no cost!
    The 'offroad' kit consisted of a tube mount with double sided ball joint, which I could not use so I opted to make a plate to fit onto my roof rack's rail.
    Routing the cable was actually easier than I expected. I just ran the cable between the rear hatch and body, into the umbilical harness which then fed into the headliner.
    From there it was easy to route over to Photon's opposite side where the amplifier is mounted to the Molle Panel.
    Nice-sleek antenna design.
    Bonus, pre-made antenna storage clip!
    acet7 likes this.
  23. Dec 14, 2024 at 6:37 PM
    #83
    That was a quick two years...Photon got a birthday treat today, OTT Tune!
    December 2022, pre-mods, yucky tires...
    December 2024, almost got her fully kitted out the way I want. Well, maybe just a few more, maybe...
    ChessGuy, yentup and acet7 like this.
  24. Dec 18, 2024 at 9:38 PM
    #84
    Knobs and Things - Finale ?
    Well at least for this goal of the HVAC Control faceplate blackout project. I finally got the last tweaks done for the fitment issues as well as the proper layer heights and print resolution.
    Still waffling over whether to keep the TRD PRO lettering or not.
    Got the alignment with the backlighting all squared up.
    Needless to say that I am quite satisfied with how this project turned out.
    Saker, bridgengineer and acet7 like this.
  25. Dec 18, 2024 at 9:49 PM
    #85
    One last Winch related tidbit...
    The first version of the hand control mount was okay but I felt that it needed just a bit more 'friction' to hold the controller more securely. The detail is hidden from view but is most effective in preventing the hand controller from shifting/slipping out of the holder during hard bumps.
    And that little box thingie below the controller? Well, the winch can be operated via cord or wirelessly and what's inside the little box is a 'dongle' that is plugged into the winch in-lieu of the cord. We all know what happens to little bits over time and I wanted to be sure to not loose this important piece! The lid is held closed by magnets and the dongle is a light friction fit inside so I'll never loose it!
    acet7 likes this.
  26. Dec 23, 2024 at 3:16 PM
    #86
    After a nice 3 hr drive across the state afforded me some driving time to check out how the OTT Tune performs from sea level up to 5,000' ASL. Throttle response is waaay more sensitive, crisp is the word. The tune did leave little 'deadband' around the very bottom, almost feather-touch by comparison to the factory sensitivity. But I can get used to it, just need some time to recalibrate my accelerator foot! Note: Getting up to freeway speed is noticeably improved...adversely so is the fuel consumption. :oops:
    On another front, its been seventeen months to almost the day (7/21/23) since getting the MT Baja Boss ATs shoes put on Photon and in that time shes made a few interstate trips (Wyoming, Montana, Nevada, Oregon) as well as scores of long-distance intrastate journeys...all in all some 14,000 freeway miles and dozens of relatively short class 1 to 3 trails to date. Brand new the tread depth was around 0.5" (16/32") and presently the overall average tread depth comes in at 0.356" (11.4/32") or about 29% tread depth used. I feel the tread depth would be a whole lot more if not for the 1000+ miles driving in summer heat going the speed limit (75-80) through parts of Nevada and Idaho. Still, I'm very satisfied with how these tires are performing, from dry pavement to twisty mud, snow and ice trails and roads. Photons on target to get close to 50,000 miles out of this set and I am quite pleased by this. The only time I got ridiculous mileage out of a set of tires was on my 3rd Gen running Michelin X LT 265/70R16...like well north of 50,000 miles, almost double that. But those were 'street' tires and I already knew that tires designed more for off-pavement driving would already have way less tread life. But if I get 50,000 miles over a couple years or so I'm completely satisfied with that.
    Tread wear across the face is somewhat uneven due to my running pressures upwards of 40 psi due to carrying a LOT of equipment/gear roughly 70% of the time.) I've been running pressures around 36-38 psi on average the past several months now and so far the tires feel just a bit softer going around tight turns but the ride is noticeably smoother.
    acet7 likes this.
  27. Jan 1, 2025 at 5:59 PM
    #87
    More Lighting...
    Just something to preemptively address something we've all had to deal with. I've seen others do something similar and kept putting this simple project off until now.
    It was a fairly straightforward process, the LED puck goes right onto that beveled edge near the front of the hood and angles the puck downward just right (when the hood is open), held in place with a small patch of Scotch Mount Extreme tape. This tape has the holding power equal to VHB series tapes, no joke.
    Wiring was also quite straightforward and I routed the 2-conductor cable behind the hood liner down towards the driver side hood where it met with a 3-conductor cable routed from the on-off switch...which I happened to mount onto the hood release support bracket. This convenient location allows me to simply pop the hood and tap the switch. No fumbling in the dark!
    There isn't any published information as to the puck's lumen output but I'd say its more than sufficient.
    MEski4x4, acet7 and yentup like this.
  28. Jan 26, 2025 at 2:48 PM
    #88
    Haven’t been down this part of the coast in some time, luckily the gate was open due to this rainy season being so poor and the south end wasn’t a muddy mess.
    IMG_3158.jpg IMG_3159.jpg IMG_3161.jpg IMG_3162.jpg IMG_3164.jpg IMG_3165.jpgIMG_3168.png
    Southern_Coyotes and acet7 like this.
  29. Feb 5, 2025 at 1:49 PM
    #89
    Got the last of the parts for this winter' projects all in-house and lined up. Perfect timing as this weekend we are expecting a significant snow/rainstorm beginning tomorrow.
    Renogy had a really nice sale going on so I picked up:
    • Two 100W Monocrystalline Panels
    • 20A MPPT Charge Controller.
    • Mini CORE 100A Lifepo4 battery
    SDHQ Billet Battery Terminals and ABS Sensor Guards
    Ironman Fridge Slide.
    Dissent Offroad Modular Rear Bumper with a single Swingout.
    These additional items will probably max out the spring upgrade load capacity (over stock) and I've put in hundreds of miles with added weight comparable to the total of these items so it should all work out. We'll see.
    ChessGuy and acet7 like this.
  30. Apr 4, 2025 at 11:03 AM
    #90
    It’s been a long time coming for this project update. Finally had some downtime to research deeper into the next project for Photon. All along I knew that she’d rarely, if ever, see some serious bouldering, happy to run desert and forest trails but there may be a class 5-6 in her future.
    That said, I’m going to document this next phase, my reasoning for specific choices and what I’ve come to decide upon for build components.
    It’s been a bit of a can o’ worms, originally thinking that I’ll never put full skid plates nor change out the Predator Tube Steps for some Sliders so for now, weight was the predominant factor. I upgraded her springs with the Eibach Pro Lifts which greatly enhanced her ability to handle the 200-250 lbs of gear that I’ve carried on several trips. But now that I’ve installed a front bumper with a winch, 60 lb rack and three cargo boxes on her roof I’m looking at really pushing the current suspension. For a stocker I feel the suspension was a perfect blend of lift and dampening, with more than 200 lbs it begins to feel under damped and spongy…not what you want when traversing ruts and off camber trail sections.
    So enter the next think, suspension. What are the future goals for Photon. I need to consider her (future) static weight vs fully rigged for a trip. It’s a big question that took some deeper research as there are also considerations about changing out tire size and what that does to suspension response (unsprung weight), and then comes back terrain…
    After becoming numb from all of the readings on here, another forum and pouring over numerous manufacturer websites it was time to make a trip to go see some of the suspension systems in person and to talk to a few specialists and looked at pretty much all of the main gameplayer’s (Eibach, Fox, Dirt King, Ironman, Icon, Bilstein) offerings.
    It became evident that with the combined terrain that I take Photon on, in addition to her being a daily, that I was quickly narrowing the general type of suspension to that of a more specialized approach (sigh). This meant that I was looking at more $$$ so more budget planning (and more beans on toast meals ) were in order.
    Since the current Fox shocks are now above 52K miles with the rear shocks beginning to ‘squeak’ I knew an upgrade would need to happen sooner than later. A somewhat saving grace would be to have the Fox shocks completely rebuilt where I then plan to sell with the Eibach springs, for a reasonable cost, to help offset the new suspension cost.
    All that being said I was glad to narrow down the search to Fox and Dirt King. Primary reason is that both companies offer a very nice solution to my trail type, payload and wheel weight dilemma. Enter dual speed adjustments or DSC (Dual Speed Compensation.) Being able to ‘retune’ the shock response as needed is a far cry from needing to decide upon just one type of shock absorber response. Where I go to do desert runs I’m looking at around 5”-8” typical for suspension travel so I can get away with not needing to go ‘long travel’. And since I’m not planning on bouldering, Photon won’t be needing to flex her travel much thus no SAS is needed. Although these types of suspension swaps look pretty damn cool they are a more specialized setup (and I wouldn’t want to waste it on being a daily)
    BTW, those are 42” tires in the back going in this 5th gen build!
    So, DSC is the way to go and all I need to determine is payload requirement and then select an appropriate spring. Sounds easy enough but I’m not counting my ducks yet…time will tell.
    In the meantime, one last fun trail ride before Photon’s next makeover begins.
    acet7, Thacrow and ChessGuy like this.
