Pennzoil and Toyotas
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Aug 27, 2023.
  1. Aug 28, 2023 at 2:46 PM
    Oakboro, N.C
    I need to get back on youtube as one guy had encountered this and, I believe , found a way to spoof the RFID to fool it into thinking it was new/replaced filter. If I can find it will definitely post it up for the group.
  2. Aug 28, 2023 at 2:54 PM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    The oil companies don't even pick their noses without Klaus Schwab and the WEF approval.
  3. Aug 28, 2023 at 2:55 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Nope - that's for the older generation. It was a small thing about the size of a rice grain that could be transferred to a new label. The new ones have an actual printed circuit board looking thing on the back of the label with a unique ID. If you try to take the old label and put it on a new generic filter, the fridge sees the old filter.
  4. Aug 28, 2023 at 2:56 PM
    Wow. You can’t even get unfiltered water? So basically GE has managed to make refrigerators into a subscription based service. Or, put another way, they want rent on the product you bought from them. I’m sure they’re not the only ones doing this crap. It seems like a lot of manufacturers are attempting to make everything rent-based to maximize profits.
    Good to find that out though, I would have never guessed this was something to look out for.
    Yotaholic[OP] and Thatbassguy like this.
  5. Aug 28, 2023 at 2:58 PM
    Oakboro, N.C
    Yepper, Have a backup Brita filter just for times we reach end of life on the built in filter. It starts giving you a count down, If i remember correctly, about a week before being due.
    Yotaholic[OP] likes this.
  6. Aug 28, 2023 at 2:59 PM
    Oakboro, N.C
    Mine is about 5 years old. Good call.
  7. Aug 28, 2023 at 3:01 PM
    08TXRunner
    '20 SR5P
    Pull your label off and check. If you have the rice grain, you're good. If you have the printed circuit board you're screwed.
  8. Aug 28, 2023 at 3:43 PM
    I use Supertech.
    They are not picky. As mentioned above, use the correct viscosity and change it at the correct interval, and you are good to go. ;)
    Yotaholic[OP] and RumHamRunner73 like this.
  9. Aug 28, 2023 at 3:55 PM
    Oakboro, N.C
    Getting greased up to change oil in the A.M before heading up to PA next week. Just checked the garage and have Costco and Pennzoil lined up to refill with. Also going to rotate and clean/wax the wheels since this is going to be a slow week.
  10. Aug 28, 2023 at 3:58 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Your trucks are cool but KO2s are all what my truck is getting, nothing more. Mods will turn my Yota into a Jeep, not very dependable lol.
  11. Aug 28, 2023 at 3:59 PM
    Yotaholic
    Olympia, WA
    I envy your real key lol. You lifted your truck, any issues in those 100k miles?
  12. Aug 28, 2023 at 4:11 PM
    2016Pro
    Whatever is on sale brand doesn't matter just change every 10k with a synthetic and it will go 500k miles
    2ndGen22re and Yotaholic[OP] like this.
  13. Aug 28, 2023 at 4:45 PM
    Knock on wood, all good so far. I kept it smaller, so that might help.
    Yotaholic[QUOTED][OP] likes this.
  14. Aug 28, 2023 at 4:48 PM
    Yotaholic
    Olympia, WA
    Was it really worth it? Wouldn't KO2s been sufficient for the wheeling that you wanted?
  15. Aug 28, 2023 at 5:07 PM
    Penzoil is great stuff. Watch YouTube Project Farm. Comparing it to 40 years ago isn’t fair. Project Farm did a bracket with major oils. It came in a close second to Amsoil
  16. Aug 28, 2023 at 5:16 PM
    I'm not dissatisfied, so I guess so. You could ask that question about any mods that anyone does.
  17. Aug 28, 2023 at 5:18 PM
    Yotaholic
    Olympia, WA
    That's exactly why I want their top of the line Ultra Platinum. It beats Mobile 1 by far. But the thing is, Pennzoil is pretty good with Chrysler. I'm just not sure how Toyota engines get along with Pennzoil. I've been using Pennzoil Ultra platinum in my Grand Cherokee, and that 3.6 runs great.
  18. Aug 28, 2023 at 5:20 PM
    Yotaholic
    Olympia, WA
    This truck has so many tools, I doubt I need anything more than good tires. I guess time will tell.
    2ndGen22re likes this.
  19. Aug 28, 2023 at 5:22 PM
    #49
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    Toyota oil is Mobil1 with Toyotas additive package added.
    Mojave and Yotaholic[QUOTED][OP] like this.
  20. Aug 28, 2023 at 5:23 PM
    #50
    Yotaholic
    Olympia, WA
    Then it is better than barebone Mob 1
  21. Aug 28, 2023 at 5:25 PM
    #51
    Yotaholic
    Olympia, WA
    I know one thing for sure, Mopar is Pennzoil, but Pennzoil Ultra Platinum is better than Mopar.
  22. Aug 28, 2023 at 6:23 PM
    #52
    Well, It definitely needs armor if you're going to screw around in rocks. A front bumper with recovery points and a winch are super handy. Once you start hauling around an extra couple hundred pounds, you're going to want to upgrade your springs at the very least.
    Also, lift improves approach, break over and departure angles. And, the front skid sits super low with KDSS, so you're going to want a little extra clearance there.
    I had stock size KO2's from 1300 miles until about 2 weeks after I lifted it (29K miles). It looked silly lifted with stock size tires, so I got some 285's. Then, later that year, I found myself with some extra cash and decided to go get another set of wheels and some real mud tires.
    I also used mine stock for a year before I decided to do anything to it. If I went back to the beginning now, I don't think I would do anything differently.
    But, I would agree that better tires are the most important thing right off the bat.
  23. Aug 28, 2023 at 6:24 PM
    #53
    Yotaholic
    Olympia, WA
    You have 33s, right?
  24. Aug 28, 2023 at 6:27 PM
    #54
    The MT 's are 295/70/17, so they're a big 33. When they are ready for replacement, I might just go with a 285. I don't know if the extra .5" is worth the rubbing.
  25. Aug 29, 2023 at 4:57 AM
    #55
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    I've been using Pennz. Platinum 5W-30 in my '06 Tacoma (2TR-FE) for 9 years, no oil related problems.
  26. Aug 31, 2023 at 1:35 AM
    #56
    Dirty Dog
    Dirty Dog New Member
    Bruce
    2015 Magnetic Grey 4Runner Limited
    Amsoil
  27. Aug 31, 2023 at 6:44 AM
    #57
    2016Pro
    I've used whatever is on sale, 300k zero issues
    nimby and Yotaholic[OP] like this.
  28. Aug 31, 2023 at 10:44 AM
    #58
    LA260
    LA260 New Member
    I used Mobil 1, then switched to Penzoil Premium/Ultra. I think the engine runs quieter with the Penzoil but that can just be me.
    Yotaholic[OP] and ecoterragaia like this.
  29. Sep 1, 2023 at 5:35 PM
    #59
    lrizzo
    lrizzo New Member
    Northern New Jersey
    I’ve used Pennzoil Ultra Platinum 0W20 since brand new and no issues whatsoever. It’s constantly on backorder so have a few oil changes worth on hand.
  30. Sep 1, 2023 at 5:46 PM
    #60
    Oakboro, N.C
    When available gotta get get several if you are able to.
