PCS System Malfunction, Dealer says radar needs to be replaced
Discussion in '5th Gen 4Runners (2010-2024)' started by feelingstoned, Oct 13, 2022.
  1. Oct 23, 2022 at 7:32 AM
    #61
    jvinhj240
    jvinhj240 New Member
    Ben
    read #53 and #55
  2. Oct 23, 2022 at 10:26 AM
    #62
    Pavo
    Pavo New Member
    They've been on tacoma since 2018 and other models even longer
  3. Oct 23, 2022 at 12:34 PM
    #63
    They even sell aftermarket relocation brackets for the tss sensors which blows my mind considering how much we freak out about a lift messing up a 4runner.
    Which is why I doubt the lift caused the radar malfunction. My bet is that the sensor is physically broken.
    grizzlypath, Spare Parts and 2Toys like this.
  4. Oct 23, 2022 at 3:18 PM
    #64
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    1 inch or 2 inch lift whatever Tomato Tomoto. I did read the posts. Sarcasm was intended. My point is calibration should work unless Toyota has different brackets for 4Rs Pro of which I do not know. Or the dealer had techs that didn't know what they were doing which is not surprising. Since it seems newer 4R Pro are equipped with these options you would think this shouldn't be an issue. If there was an aftermarket bush bar, grill change or something obstructing the sensor that's different. But a lifted 4R should not be anything new to a competent dealer.
  5. Oct 23, 2022 at 3:52 PM
    #65
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Re-read what he said. He said it was "broken" not misaligned. So by that, every time someone adds a trailer or a boat to their rig, and it squats in the rear, the radar unit becomes useless? Reason #193 I'm not a fan of nanny equipment.
    08TXRunner and McSpazatron like this.
  6. Oct 24, 2022 at 5:44 AM
    #66
    jvinhj240
    Ben
    re-read what i said, its broken from dealer words. But you need re-calibration if not they will say broken , then owner have nothing to back it up. Even a defect radar they will blame YOU for any mods you did.
    who says adding the rear trailers or boat will not work? even will not work, dealer will recommend what you should do and have no reason to make you PAY. MODS are different.
  7. Oct 24, 2022 at 7:41 AM
    #67
    Can someone kindly validate whether adding a 2 inch lift will cause this to happen? I’m about to buy the Eibach lift kit. I’m a new 4Runner owner with a 2022. I don’t want to do all the lift work only to have this happen
  8. Oct 24, 2022 at 8:39 AM
    #68
    Pavo
    Pavo New Member
    You're fine I've lifter 3 5th gens personally with tss and no issues. Not to mention the literal tens of thousands of lifted tss 5th gens out there. Of course if you lift too high (above 3 inches) you'll probably have issues not only with tss but your driveline as well
    grizzlypath likes this.
  9. Oct 24, 2022 at 1:26 PM
    #69
    Overland WT
    Bryan
    West Texas
    2017 TRD Off Road
    Im not gonna argue. "its broken from dealer words." Broken to a dealer and broken to Toyota mean the same thing on paper. Thats what matters. Since it cant be re-calibrated according to the dealer, it is nothing more than a useless paperweight unless you know how to recalibrate it?
    Bottom line it clearly depends on the rig whether you will have a problem or not.
    It clearly depends on the dealer as to how they will handle your vehicle with a lift and a warranty claim.
  10. Oct 24, 2022 at 3:49 PM
    #70
    jvinhj240
    Ben
    Bottom line, re-calibrated it right away if you lift your car. Even best to have the dealer do it.
