Owner Review: "Delivered! 2025 4Runner SR5 w/ 3rd Row Seats - Owner Impressions, Pics, MPG Figures"
Discussion in '6th Gen 4Runners (2025+)' started by jwocky, Feb 2, 2025.
Thread Status:
Not open for further replies.
  1. Feb 5, 2025 at 6:47 PM
    #151
    cuse93
    cuse93 Ice Station Zebra
    $72k..... I almost shat myself until I realized with great relief that the price includes ceramic coating and dent protection.
    donotdisturb likes this.
  2. Feb 5, 2025 at 7:58 PM
    #152
    $15K of dealer accessories? Does it come with a side by side?
  3. Feb 5, 2025 at 9:12 PM
    #153
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    What the hell is going on in this thread? Everyone is fixating on the owners of 6th gens instead of the vehicles, this forum is not going to grow a meaningful 6th gen userbase if we get judgmental about the owners. Don't gatekeep either, it is possible to criticize Toyota for removing things like a full size spare without insulting the people that like it.
    They finally answered a question no review did, the skid plate on the SR5. It looks plastic to me which is a huge downgrade, Toyota has been doing that on the Sequoia and the Tacoma, and I really wish they didn't make that compromise. The blank switches are not a big deal, it gives you a place to put switches for mods. The 3rd gen has only 3 or 4 in logical areas, and typically 2 of them are already used from factory. Having a ton of blanks means you don't have to buy a switch panel if you want to fit more that 4 circuits. It might not look the best, but it's function over form.
    For TFL it's a business decision, getting the 6th gen first means they can start making content with it first, which means they get more views, which means they make more money. The math doesn't make sense for a normal buyer, but TFL isn't a normal buyer.
  4. Feb 6, 2025 at 3:36 AM
    #154
    NoDak
    NoDak New Member
    JR
    North Dakota
    better include a freaking trunk monkey for that addon gouge
    icebear and Sin4R like this.
  5. Feb 6, 2025 at 3:46 AM
    #155
    NoDak
    NoDak New Member
    JR
    North Dakota
    i think they started with the hard felt skid plate idea with the 22 tundra and it just carried over to every bof vehicle since then
    all those blanks are for the higher trims which include a bank of blank switches connected to nothing, they are for the consumer to connect to whatever.
    there is a pic somewhere of those blanks switches included.... here is a pic of a 2024 tacoma
  6. Feb 6, 2025 at 5:50 AM
    #156
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    The only more annoying design trend I could think of is 90s plastic panels on the bottoms of doors.
    If you going to attach a giant tablet in the middle of the dash, at least give me an option to remove or fold it out of sight.
    Jennyjo14 and vthoky like this.
  7. Feb 6, 2025 at 6:05 AM
    #157
    donotdisturb
    donotdisturb New Member
    Then I would tell the dealer to remove the precious and expensive accessories because I would just ruin them on the hunting trails.
  8. Feb 6, 2025 at 11:05 AM
    #158
    Have you seen your own posts in the Food Porn thread?
  9. Feb 6, 2025 at 11:11 AM
    #159
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Right, lol
    Just uncomfortably stuff all the pockets you have available like the rest of us
  10. Feb 6, 2025 at 11:43 AM
    #160
    Phone, keys and wallet. What more do you need?
  11. Feb 6, 2025 at 12:10 PM
    #161
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    Dog poop bags, dog cookies, sunglasses, chapstick, tissues, headlamp, bug dope, etc.
    icebear and Thatbassguy like this.
  12. Feb 6, 2025 at 12:12 PM
    #162
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Re-read my post. I specifically said not that different from Limited or Pro, followed immediately by stock photo of a 5th gen limited.
    If you are confused, feel free to google what a 5th gen SR5 dash looks like on the left side.
  13. Feb 6, 2025 at 12:33 PM
    #163
    You would bring all of that to the car dealership?
  14. Feb 6, 2025 at 12:38 PM
    #164
    FourBelugas
    23 white ORP
    I'm surprised there is no iodine pill in case they need to purify water if they ran out of water, and sunscreen in case they need to be outdoors mid day.
  15. Feb 6, 2025 at 12:40 PM
    #165
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Yeah. I guess I didn’t read it clearly. I know Canadian market TRD off-roads had dual zone climate so I thought it wouldn’t be out of the realm of possibility to find an SR5 somewhere that had it.
    Plus I’ve never had any serious interest in a limited so I didn’t even know it had the same style circular 4WD dial as an SR5, despite it being AWD.
  16. Feb 6, 2025 at 12:42 PM
    #166
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Those are part of “etc”
  17. Feb 6, 2025 at 12:43 PM
    #167
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Probably not. I’d replace the lip balm with bear spray.
  18. Feb 6, 2025 at 12:44 PM
    #168
    FourBelugas
    23 white ORP
    Toyota's option spec'ing never made sense in any case. They also gave Canadian market SR5/OR trims dusk sensing headlights but not the US market. Why? Who knows.
  19. Feb 6, 2025 at 12:46 PM
    #169
    FourBelugas
    23 white ORP
    It all sounded excessive until I see your location is Maine. You guys up there along with Vermont are real EDC aficionados.
    Do you keep walking sticks in the car?
  20. Feb 6, 2025 at 1:12 PM
    #170
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    LOL. No. But maybe I should considering all the rabid fox sightings in my area.
  21. Feb 6, 2025 at 1:34 PM
    #171
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    I think regional managers/VPs get heavy input into what each vehicle trim gets for their jurisdictions. Couple that with those particular areas laws and regulations.
  22. Feb 6, 2025 at 1:44 PM
    #172
    Jimmys
  23. Feb 6, 2025 at 2:54 PM
    #173
    Cigars, cutter, lighter, flashlight, knife, bottle opener...
    :D
  24. Feb 6, 2025 at 3:36 PM
    #174
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I don't think anyone was debating, I could give a shit less what people like. But I WILL poke fun because that's just my personality and I think giving people a good nautured hard time is fun for all. Some people have thin skin and get offended; I am not one of those. That's why there is a "roast me" thread on the site.
    McSpazatron likes this.
  25. Feb 6, 2025 at 3:46 PM
    #175
    vthoky New Member
    For real?
    I'll see you guys in a bit... going exploring. :D
  26. Feb 6, 2025 at 4:39 PM
    #176
    icebear Recovered Kia Owner
    Anyone know if the additional width translates to additional in-cabin width or is it all in the fender flares?
    (and if the width mirror to mirror is any bigger?)
  27. Feb 6, 2025 at 4:56 PM
    #177
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    Asses, glasses, testicles and spectacles?
  28. Feb 6, 2025 at 4:57 PM
    #178
    Jennyjo14
    Jennifer
    None
    Are we switching topics from man bags to hairy palms?
    MI-FL off roader likes this.
  29. Feb 6, 2025 at 4:57 PM
    #179
    vthoky New Member
    No, ma'am.
    MeefZah and Jennyjo14[QUOTED] like this.
  30. Feb 6, 2025 at 5:15 PM
    #180
    There is? You've been holding out on me! Link me, brother. Right meow.
Thread Status:
