Overland Torque Tune (OTT) by Overland Tailor
Discussion in '5th Gen 4Runners (2010-2024)' started by JustDSM, Sep 23, 2022.
  1. Jul 13, 2024 at 2:59 PM
    #181
    FancyLimited
    FancyLimited New Member
    2024 Silver Limited
    I got mine done with a mild tune from Quoc today. The throttle response is nearly 1:1 now and feels so much better. I noticed the additional power merging on the freeway.
    Where I noticed the most was around a freeway intersection where before it was sketchy to try to accelerate through the loop, now you can easily control the throttle and merge easily on the other end.
  2. Jul 13, 2024 at 3:35 PM
    #182
    I finally caved in today. Got the tune on both the taco and the 4R. It is different....for the better of course. Thanks to Kaleb from OTT for coming down to Houston.
    JustDSM[OP] and BortisYeltzen like this.
  3. Aug 16, 2024 at 7:27 AM
    #183
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    This tune impressed me so much and Alex in Dallas is the man!
    Finally pulled the trigger and I am absolutely blown away. The extra low end torque helps a ton! Updated shift logic means gear hunting is gone and driving around town is so much better. Hell even cruising at HWY speeds (65-85mph) it hardly ever needs to shift down to fourth gear and when it does its smooth and stays in fourth until I return to level ground or return to a constant speed. No more hunting between gears! Even radar cruise control is usable again due to the increase in torque which surprised me the most. I also picked up some fuel economy which was another pleasant surprise.
    For reference I'm on heavy 34's (285/75/17 Falken A/T4W) with about 450 lbs of armor, winch, and bumpers added. Edit: stock gears.
    If you guys on on the fence about this tune just do it. OTT is the way.
  4. Aug 16, 2024 at 8:46 AM
    #184
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Thanks for posting this. Maybe this has been answered before, but did "we" ever get a definitive answer on whether or not a tune like this will void the factory warranty? I've got just under 3k on my '24 Limited and while I'm digging these improvements you're seeing, the last thing I want is to find myself voiding the warranty I effectively paid very dearly for.
    Thanks,
    TimG
  5. Aug 16, 2024 at 9:00 AM
    #185
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    Very frequently asked question. Here is what I tell my customers:
    “If the warranty issue in question is caused directly by the tune, you could potentially have your warranty voided on that item. Much like a lift and larger tires can void your powertrain warranty, so can a tune if it is found to be the cause of an issue. These tunes however are nearly undetectable by the dealership, but if they dig into it they can find the tune. No guarantees or promises are made that tuning will uphold your vehicle's warranty, HOWEVER many customers have had warranty work completed after receiving a tune without an issues. Please use your best discretion when considering tuning your vehicle.”
    In short, if your warranty is your #1 priority, keep your vehicle 100% stock and get all your maintenance done on time at the dealership. Anything you do outside of that can put your warranty at risk the same as a tune.
  6. Sep 5, 2024 at 9:44 PM
    #186
    as21
    as21 New Member
    2015 you say? FULL treatment you say??:spending:
    What's the up to date on this?
  7. Sep 6, 2024 at 8:14 AM
    #187
    JustDSM
    JustDSM [OP] New Member
    Justin
    2023 Ford Raptor
    We’re a little closer, but the crux is what we’re up against now. We have everything we need to actually complete the process. One hurdle left, but it’s the tricky part, so it’s not going to be tomorrow or anything like that.
    Promise we’ll have this updated when we have it licked!
  8. Sep 6, 2024 at 8:50 AM
    #188
    as21
    as21 New Member
    godspeed my brother. cant wait to see its completion, although im sure you feel that even more than I
    JustDSM[QUOTED][OP] likes this.
  9. Sep 6, 2024 at 8:58 AM
    #189
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Even the engine only OTT tune is a massive improvement over stock. Why wait? You can always get the TCU update later when released.
    FancyLimited and JustDSM[OP] like this.
  10. Sep 6, 2024 at 9:27 AM
    #190
    as21
    as21 New Member
    agreed the ecu only tune looks great and for many applications it is a massive improvement.
    for me the money is better spent on other mods atm since i primarily drive in S mode and believe i wont gain much from shift points and throttle mapping (already have a pedal commander installed). the tcu tune is interesting to me for gearlock / rpm based locker mapping as well as shift speeds. i plan on adding paddle shifters in the near future to gain more control and am looking forwards to being able to tweak the parameters to match my needs.
  11. Sep 6, 2024 at 11:18 AM
    #191
    CoastPro4
    CoastPro4 New Member
    21 Pro LR
    I am currently running the OTT tune for my 21’ and am blown away how much more responsive the truck has been since… I settled on the “Spicy” tune in anticipation of moving up to 285/70 r17’s due to the heavier tires compared to the stock 32” Nittos. Do you think I would feel much of a difference when I move up in tire size? I mean, the way it sits with stock oem tire size…with the Spicy tune it almost, dare I say, feels “too” responsive :D. I actually am hoping the increased tire size slows her down a little. Thx!
    JustDSM[OP] likes this.
  12. Sep 6, 2024 at 11:53 AM
    #192
    Henry J
    Sacramento Ca
    Got mine a week ago from Area51. Love it!
  13. Sep 6, 2024 at 4:05 PM
    #193
    Number16
    Number16 New Member
    2021 4runner
    I am curious as to what people are paying for a tune. I reached out to one of two tuners here in Georgia and I was quoted $600.
  14. Sep 6, 2024 at 4:58 PM
    #194
    Nubes
    Nubes Toyota Addict
    Paid $500 in TX but it will vary by region from what I've seen.
    Number16[QUOTED] likes this.
  15. Sep 6, 2024 at 10:48 PM
    #195
    JustDSM
    Justin
    2023 Ford Raptor
    Just be aware that 2020+ MY vehicles will be a fair bit more expensive, due to the 2.5x higher licensing costs.
    Nubes likes this.
  16. Sep 7, 2024 at 7:18 AM
    #196
    1SilverRunner
    Tejas
    You’ll feel the larger tire but it’s not bad. I went with mild on the throttle setting since I wanted more control when off roading.
  17. Sep 7, 2024 at 6:57 PM
    #197
    Papa G
    Papa G New Member
    2024 TRD ORP Classic Silver
    I came from a 2021 Taco TRD OR. The OTT tune woke that truck up. I'm considering an OTT tune again even though I find the 4Runner to be "adequate" for my driving style. Do you see a time when OTT will pursue CARB certification for the 5th Gen 4Runner like the 3rd Gen Taco? I'm a CA resident and thinking this will be my forever vehicle I don't want to mess with flashing back to stock when I have to smog it down the line.
  18. Sep 8, 2024 at 12:07 PM
    #198
    JustDSM
    Justin
    2023 Ford Raptor
    This is what I can say: It’s not at all off the table and has been discussed, but it is also not our primary focus at this moment.
  19. Sep 8, 2024 at 1:19 PM
    #199
    Henry J
    Sacramento Ca
    I got 2 years to figure it out, just smogged 4 days before my tune ;)
  20. Sep 9, 2024 at 9:44 AM
    #200
    Bend_4R
    Bend_4R New Member
    Does an OTT affect crawl control or A-Trac negatively?
  21. Sep 9, 2024 at 12:30 PM
    #201
    JustDSM
    Justin
    2023 Ford Raptor
    It would not adversely affect those systems or their functionality.
    Bend_4R likes this.
  22. Sep 9, 2024 at 2:44 PM
    #202
    Central Mississippi, it appears that you or Jeff are the closest to me, correct?
    Seems like on your map, Yota Performance covers Mississippi but they are in Miami?
  23. Sep 23, 2024 at 10:49 AM
    #203
    JustDSM
    Justin
    2023 Ford Raptor
    Tom, is one of our traveling tuners. He's based out of FL, servicing the panhandle and MS and Southern LA. He's very active and has a wealth of knowledge. He'll certainly take care of you.
    Jeff covers AL and is also a great resource.
    John, OTT's Owner, is based in Birmingham. I'm Justin, OTT's Lead Calibrator, and I'm based in Utah.
  24. Sep 23, 2024 at 11:02 AM
    #204
    Talked to Tom he’s coming my direction in November so I’m gonna get it lined out to meet him.
  25. Oct 26, 2024 at 8:40 AM
    #205
    rproc
    rproc New Member
    Richard
    Calgary
    21 Black 4Runner ORP
    Sorry for digging this thread up from the dead.
    Help me understand the benefits of tuning this platform.
    My last few vehicles were turbocharged, and an aftermarket tune netted a substantial difference.
    I think we all know this platform is slow, nobody bought one of these trucks expecting to light the tires up.
    What are the benefits of spending $700 cdn to net 10hp? I doubt that would even be noticeable.
    I'm not bashing this tune, since it seems to be very popular, I'm just having a hard time understanding the benefits of it.
    Is the driveability really that much better?
  26. Oct 26, 2024 at 9:29 AM
    #206
    Look at the dyno charts. Sure if you’re looking at Hp it’s not the biggest gain in the world. But if you look at torque and where it’s gained, that’s the big ticket. It’s gaining almost 30ft/lbs of torque and it’s gaining it at like 2200rpm which is where you’re at when driving. So the “punch” you feel when tipping into the throttle from 11% to 16% feels substantial. That’s why, and where you get the feel.
  27. Oct 26, 2024 at 9:36 AM
    #207
    Number16
    Number16 New Member
    2021 4runner
    I am looking to do this shortly. I believe it also helps with transmission tuning as well.
  28. Oct 26, 2024 at 9:42 AM
    #208
    JustDSM
    Justin
    2023 Ford Raptor
    For your '21, it will remap the transmission as well!
  29. Oct 26, 2024 at 9:47 AM
    #209
    rproc
    rproc New Member
    Richard
    Calgary
    I overlooked the torque numbers, that makes sense.
    I'll have to put this tune on my radar.
    CoastPro4 likes this.
  30. Oct 26, 2024 at 10:00 AM
    #210
    CoastPro4
    21 Pro LR
    Definitely keep it on your radar, it transformed the driving experience for me. I anticipated going up in tire size to 285/70-17’s and didn’t not want the truck to feel bogged down as it already felt so stock…I went with the Spicy tune setting (near the top) and wow did it transform it. It almost feels too snappy from a stop, but passing and gear holding has been phenomenal. But now, not sure if going to 285’s is worth the extra wear on driveline, joints, brakes and bearings over the long haul…thinking of keeping stock tire size…and maybe dropping my tune back down to Medium setting. The power advantage is there no matter the “setting”…the torque curve feels much more linear…really happy I did it.
