Overland Torque Tune (OTT) by Overland Tailor
Discussion in '5th Gen 4Runners (2010-2024)' started by JustDSM, Sep 23, 2022.
  1. Apr 12, 2023 at 11:08 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Where would someone living in San Diego get this tune?
    JustDSM[OP] likes this.
  2. Apr 12, 2023 at 11:41 AM
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    Hit up Quoc at TK421 Tuning. He covers San Diego.
    https://tk421tuning.com/
  3. Apr 12, 2023 at 11:51 AM
    coryanderson
    Cory
    I have to go to LA?? San Diegans don't know how to associate with those from the north.
  4. Apr 12, 2023 at 1:25 PM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    No, he goes to SD a few times a month.
  5. Apr 12, 2023 at 4:09 PM
    soze
    soze Tiny Trucker
    Orange County, CA
    2022 MG TRD ORP
    Bone Stock
    Last car I had any ECU/TCU tuning on was a VW GTI. With that car, tunes usually came with a OBD dongle that allowed you to switch between various modes like stock, tuned, and valet mode. I liked having the ability to flip it to stock mappings before bringing my car to the dealer, or valet mode which had a "detuned" mapping when I needed to hand the car over to a valet.
    Do any of the Toyota tunes have that ability to just plug in a dongle and switch between mappings?
  6. Apr 12, 2023 at 4:39 PM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    You can buy the hardware and apply the tune yourself, and flash back to stock. But it is not a self contained handheld device like some other options you are describing. For a 2022, there is only one software able to access your vehicle and tune it, VF Tuner. You can buy the hardware and load the software to your PC, then buy tune files from Overland Tailor and apply the tune yourself. It’s more expensive but gives you flexibility if that’s important.
    it’s not something you’d want to do before you hand off the car at the valet though. Busting out a laptop and then powering it up, loading software, flashing the tune, 10 min later you’re off to dinner…
    hossler1788 likes this.
  7. Apr 13, 2023 at 2:54 AM
    2016Pro
    I live in Florida, I would have to bring my 4runner to you for the tune?
  8. Apr 13, 2023 at 3:21 AM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Nope, we have several locations in Florida. See the map below and contact the nearest tuner.
    https://overlandtailor.com/retailer-locations
    BantamEddy and hossler1788 like this.
  9. Apr 13, 2023 at 6:46 PM
    mmike87
    mmike87 New Member
    I had this tune loaded a few weeks ago ... Very pleased with it. All but eliminated gear hunting in my 21 Pro. One observation, under uncommon circumstances, and when using cruise control, the torque converter locked and unlocked repeatedly, seemingly doing that instead of gear hunting. Doesn't happen often, only when using CC, and much less annoying than shifting between 4th and 5th repeatedly.
    I went with a mild throttle map which seems only slightly more sensitive than stock, but in my opinion it's perfectly suited to the truck.
  10. Apr 14, 2023 at 5:31 AM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Do you recall the speed and load conditions (going up a small hill, head wind, etc…) where the TC Lock/unlock was occurring in CC? I run CC a lot on my 2021 ORP and haven’t experienced this, but when I use CC out here it’s usually set between 75-85 mph. I’d like to test it and see if I can recreate your behavior to see if we can dial that out. I noticed even stock that Toyota tends to use the TC lock/unlock as another gear in some circumstances.
    I also run the mild throttle and like it. It’s still smooth, more linear, and a nice bump from stock.
    mmike87[QUOTED] likes this.
  11. Apr 14, 2023 at 5:58 AM
    mmike87
    mmike87 New Member
    Yeah, the few times it's occurred, it's been on mildly-sloped terrain, with cruise control set on about 60mph. When it happened, it just started cycling between locked/unlocked repeatedly for about 15 or 20 seconds. It's only happened a couple of times, under pretty specific circumstances, so it's not been a big deal.
  12. Apr 14, 2023 at 7:03 AM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Thanks for the info. I’ll see if I can recreate the behavior on mine to see if there is a way to change it. Could be the a TC lock setting is exactly 60 mph, so may change it to 61 or 62 as people tend to set CC to whole numbers. If you can test it again at CC set to 61 or something would be interesting to see if it doesn’t happen.
  13. Apr 14, 2023 at 8:49 AM
    mmike87
    mmike87 New Member
    Sure, I can give it a shot next time I am out. The road where it's happened is on the way to my house from town, so I travel it often. I'll post back here with the results.
  14. Apr 14, 2023 at 10:25 AM
    soze
    soze Tiny Trucker
    Orange County, CA
    2022 MG TRD ORP
    Bone Stock
    Interesting, good to know. Just curious, is that just a case of the ECUs that Toyota uses not having a spot in memory to hold multiple map configurations to toggle between (I believe that was how the VW tunes worked)?
  15. Apr 14, 2023 at 11:07 AM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    We are limited by what the software enables us to do at this time. For a brief period VF Tuner was developing a handheld device but abandoned it for various reasons.
    The 3rd Gen Tacomas and 2nd Gen Tundras have ECT/Tow mode buttons that we can enable some map switching there with current tunes. Unfortunately there isn’t anything like that on the 4Runner currently.
    soze[QUOTED] likes this.
  16. Apr 14, 2023 at 4:16 PM
    Steve40th
    Steve40th New Member
    sTEVE
    A handheld tuner and being able to tune the transmission in my 2019 would be 2 great options.
  17. Apr 19, 2023 at 5:21 AM
    mmike87
    mmike87 New Member
    I tried this again yesterday, and at 62 mph on the same gentle hill, the torque converter lock hunting still occurred. I'll try again at perhaps 55 mph and see if that makes any difference.
  18. Apr 19, 2023 at 5:23 AM
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Is this only with cruise control engaged?
  19. Apr 19, 2023 at 6:46 AM
    #49
    mmike87
    mmike87 New Member
    I have only noticed it with CC engaged - manually, I am probably at least subconsciously controlling the throttle slightly differently, I suspect. I'll see if I can compile a video of the slope from my dash cam, as well as a phone video of the hunting from my phone. It may take a couple of days to put it together.
    BortisYeltzen[QUOTED] likes this.
  20. Apr 19, 2023 at 8:49 AM
    #50
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    Ok, I have not been able to replicate the issue on my 4Runner, but we also don’t have many areas where 60 mph CC would be used, it seems everything out here is 35 mph city or 70+mph highway. I can try setting CC to 60-62 on some hills here but I might get rear ended or run off the road :rofl:
  21. Apr 19, 2023 at 9:47 AM
    #51
    Steve40th
    sTEVE
    When did Toyota change transmission controls to where you can tune it on the 4tunner
  22. Apr 19, 2023 at 12:18 PM
    #52
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    On the 5th Gen, 2020+ all have TCU (transmission) access and tuning. There are a few oddball ECU’s between 2010-2019 that also have TCU access, but the vast majority of those years do not.
    It seems 4th Gens that can be tuned (2005-2009) also have TCU access. Pre-2005 is a different ECU, K-line, and access just coming online for that.
    VF Tuner has stated they have recently gained access to all 2010-2019 TCU’s but doesn’t currently have a means of writing to them via the OBD2 port, but is working it. So there is hope.
    Steve40th[QUOTED] likes this.
  23. May 30, 2023 at 11:10 AM
    #53
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    Where could someone in N. Florida get this tune?
  24. May 30, 2023 at 11:25 AM
    #54
    Nubes
    Nubes Toyota Addict
  25. May 30, 2023 at 2:03 PM
    #55
    2016Pro
    You should probably go to the first post and reach out to them directly rather than posting in here. :thumbsup:
  26. May 30, 2023 at 2:04 PM
    #56
    Cowboy59
    N. Florida
    Thanks - will do.
  27. May 30, 2023 at 2:21 PM
    #57
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    If you want to DIY, you can go buy the VF software and device here:
    https://vftuner.com/collections/vf/products/vforest-tuner-software-flash-cable
    When you order it, make sure you let VF know it’s for a 2020+ T4R, it takes 10 credits to unlock your ECU vs. the standard 4 credits for most all other vehicles.
    Once you get that, you can email Overland Tailor (info@overlandtailor.com) and purchase a tune pack. From there you have everything you need to DIY. The OTT tune pack will be locked files, so you will not be able to edit the tunes. This is typical in the industry. If you want to build your own tunes you can start from the stock file or buy VF tune packs that are editable. The VF tune packs are pretty mild compared to the 3rd party options, like OTT, in my testing.
    2016Pro, Nubes and Cowboy59[QUOTED] like this.
  28. May 30, 2023 at 2:37 PM
    #58
    Cowboy59
    N. Florida
    thanks for that info. I would be comfortable doing it myself.
  29. Jun 24, 2023 at 2:45 PM
    #59
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
  30. Jun 24, 2023 at 3:04 PM
    #60
    Trident904
    Trident904 That Guy
    Brian
    Treasure Coast, FL
    22 TRD Offroad Premium on 35’s
    King 2.5 with resis, C4 Hybrid Front, TC Uppers, Victory Rack, Smitty 12k winch, 17x9 -38 SCS F5’s with 295/70 Ridge Graps
    I love my OTT tune on my 2022 OR with 35’s and 4.88’s. RC in Melbourne was able to get the shift points perfect with my gearing. I’m a believer in OTT.
    BortisYeltzen likes this.
