Opinions On Keeping Trailer Hitch Installed
Discussion in 'General 4Runner Talk' started by Rick G., Jan 21, 2025.
  1. Jan 24, 2025 at 11:29 AM
    #91
    These guys act like they are driving a classic Ferrari. Caring about minor dings and scrapes on a mass produced 4x4 is insane.
  2. Jan 24, 2025 at 11:30 AM
    #92
    You need one of these Bumper Bullys
    icebear and Thatbassguy like this.
  3. Jan 24, 2025 at 12:04 PM
    #93
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    agreed.
    that ain’t me :p
    see:
  4. Jan 24, 2025 at 12:05 PM
    #94
    what in the world is that!
  5. Jan 24, 2025 at 12:08 PM
    #95
    It’s for city people that like to bump into stuff while parking. I’ve never understood how that hideous cover is more attractive than a few paint chips on the bumper.
  6. Jan 24, 2025 at 12:10 PM
    #96
    Ahh yeah I hear ya. Reminds me of my grandpas hood bra he had on his Accord for decades
  7. Jan 24, 2025 at 12:58 PM
    #97
    whats Thatbassguy doing in your woods or is that Turd? Lol!
  8. Jan 24, 2025 at 1:15 PM
    #98
    To me, mine is a classic. Even my 2011.
  9. Jan 24, 2025 at 2:49 PM
    #99
    yeah, but you’re doing the damage to your own vehicle not some idiot playing bumper cars because they think it’s ok.
  10. Jan 24, 2025 at 2:49 PM
    #100
    yo, I had one of those on my 89 Pontiac Firebird don’t laugh!!
  11. Jan 24, 2025 at 4:17 PM
    #101
    If I bumped your car, you'd never know.
    But, I do agree that trail damage is different. I have a ton of pinstripes. They don't bug me. But, door dings piss me off. Some people have no respect for other people's vehicles.
    2ndGen22re and icebear like this.
  12. Jan 24, 2025 at 4:22 PM
    #102
    For some people, these are show cars. I take mine to shows occasionally, but I wear my trail scars with pride. My car guy buddies don't get it.
  13. Jan 24, 2025 at 4:42 PM
    #103
    Tama1968
    Tama1968 New Member
    Florida
    You're in law enforcement, I'm in health care. If people had common sense and situational awareness, we'd both be out of work.
  14. Jan 24, 2025 at 4:47 PM
    #104
    Youre right, I wouldnt because you’d hit my steel front bumper or my rear hitch hook. Thus the reason I have them.
    Bumping into someones car regardless if it causes damge or not is also disrespectful. I dont touch your car, so dont touch mine. Its a universal rule.
  15. Jan 24, 2025 at 4:49 PM
    #105
    true, true
  16. Jan 24, 2025 at 5:12 PM
    #106
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
  17. Jan 24, 2025 at 5:18 PM
    #107
    Lol. Getting upset about a bumper to bumper tap is like being upset about someone touching a doorknob. Don't park anywhere public if this upsets you.
    The funny thing is that I totally exaggerated in my initial post. I've probably made contact with a total of 10 vehicles in my lifetime while parking. But, you got so upset about it that I just couldn't leave it alone.
  18. Jan 24, 2025 at 5:20 PM
    #108
    Not true. People have health issues regardless of how they take care of themselves.
  19. Jan 24, 2025 at 5:32 PM
    #109
    its all good. Im just glad youre in Wisconsin because id door ding the shit out your car if you were in Pa. Cheers!
  20. Jan 24, 2025 at 5:40 PM
    #110
    Door dings are a whole different subject! metal to metal is a no-no.
    :cheers:
    2ndGen22re likes this.
  21. Jan 24, 2025 at 5:50 PM
    #111
    “I've done this about a thousand times while parking in tight spots. Tapping a door is never going to hurt anything.” :D
  22. Jan 24, 2025 at 5:55 PM
    #112
    Will you two old ladies quit' yer' bitchin'?
  23. Jan 24, 2025 at 6:05 PM
    #113
    Get off my lawn!
  24. Jan 24, 2025 at 6:05 PM
    #114
    haha! Never!!
  25. Jan 24, 2025 at 6:17 PM
    #115
    Lost Woods
    Lost Woods New Member
    You're supposed to just flip it out when you park but people are lazy.
  26. Jan 24, 2025 at 6:30 PM
    #116
    Lost Woods
    Yeah but when someone does just barely tap it, that totally vindicates you for being a fuckstick who leaves the Shinbasher 9000 in your hitch all the time. So much so it deserves a thread displaying your vindication for everyone to see.
    TrailSpecial22 and Thatbassguy like this.
  27. Jan 25, 2025 at 5:28 AM
    #117
    vthoky New Member
    Cool! I could use up four different posts, showing pics of all our vehicles with "prominent" hitches... and the hitch on the riding mower, too!
    Maybe title the thread, "Show your hitches, b*tches!"
  28. Jan 25, 2025 at 5:35 AM
    #118
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    This is what you need...The Dinosaur Penis, as this has been affectionately dubbed on this forum!
  29. Jan 25, 2025 at 6:36 AM
    #119
    ALL HAIL TO THE “GDP”!!!
  30. Jan 25, 2025 at 9:13 AM
    #120
    Tama1968
    Tama1968 New Member
    Florida
    Ok, fine. We'd have a lot less work. Better?
