Opinions On Keeping Trailer Hitch Installed
Discussion in 'General 4Runner Talk' started by Rick G., Jan 21, 2025.
  1. Jan 23, 2025 at 5:46 PM
    #61
    vthoky New Member
    (snicker!) :D
  2. Jan 23, 2025 at 5:46 PM
    #62
    scuffs, scratches and gouges. Doesnt take much to do that to plastic including our 4runner bumpers.
  3. Jan 23, 2025 at 5:49 PM
    #63
    If you're hitting hard enough to cause scuffs, scratches and gouges, you're not doing it right. It is entirely possible to tap another car without damaging it if you have a little finesse.
    rockdoc4x and icebear like this.
  4. Jan 23, 2025 at 6:00 PM
    #64
    Sounds like you’ve mastered it!
  5. Jan 23, 2025 at 6:50 PM
    #65
    You are more likely to have someone hit you with a hitch sticking out that they aren’t expecting/didn’t see.
    Lost Woods likes this.
  6. Jan 23, 2025 at 6:57 PM
    #66
    what about the giant SUV in front of them, didnt see that as well? Come on now…
    if youre parking 6 inches away from the rear of my bumper, It’s not the trailer hitch sticking out that’s the problem
  7. Jan 23, 2025 at 7:03 PM
    #67
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I feel naked without the hitch, it worries me.
  8. Jan 23, 2025 at 7:07 PM
    #68
    Awe youre dead meat now! Lol
  9. Jan 23, 2025 at 7:19 PM
    #69
    Huh? You should be about 6” or less away from the person in front of you in a parking lot. Do you leave your vehicle hanging out in the aisle?
  10. Jan 23, 2025 at 7:40 PM
    #70
    6” or less? Thats silly, how the hell is anyone going to get to the rear of the car to load groceries or anything else when youre that close to someone bumper. What if you have a stroller for your infant in the back area? I guess you just climb on their hood and drag it out across persons hood that didnt give you any room to maneuver..
  11. Jan 23, 2025 at 7:45 PM
    #71
    I think he is assuming that both people are parking nose to nose. Like in most grocery store parking lots. I agree with this. I don't want the ass end of my SUV hanging out, so I pull in as close to the line as possible (without going over).
    There are some cases where people back into a parking stall. I do this when I park at work in the parking garage. The car behind me is always VERY close to my bumper. But I get it. I'm backed up to the line, and they pull in close to the line also. I don't want the front end of my ride sticking out and they don't want the ass end of their car sticking out.
    I only back in at work, never at a grocery store or in a shopping center type area. I want full access to open up the liftgate on my 4Runner. If I back in, I cannot do that.
  12. Jan 23, 2025 at 7:52 PM
    #72
    i hear you, but a lot of people including myself like to back into a spot so its easier to see and pull out of the spot.
    being a former FF and LEO, we always backed our vehicles in so we can get out quickly when needed and it just stuck with me. I also park that way in my garage.
    if I ever pull into a spot and the car in front of me has its rear end there, Im always courteous and give them some space
    Guppy1301 likes this.
  13. Jan 23, 2025 at 7:53 PM
    #73
    I back in almost everywhere. But, I'll pull in forward if I know I'm going to be loading a bunch of stuff in the back.
  14. Jan 23, 2025 at 8:12 PM
    #74
    How about you just don’t back into a space if you need to get into the back of the vehicle? That seems like common sense. o_O
  15. Jan 23, 2025 at 8:18 PM
    #75
    How about you don’t park 6 inches or less from the front or rear of my bumper. Seems like common sense as well as common courtesy. But then again many drivers lack courtesy wherever they go….
  16. Jan 23, 2025 at 8:35 PM
    #76
    A typical parking space is only 18’ long. In a double loaded parking lot both vehicles should be pulled up right to the center line. Maybe it’s time for you to go back to drivers Ed?
  17. Jan 23, 2025 at 8:52 PM
    #77
    Up, down and all around!
    I should really post this in the 'peeves' thread but its somewhat fitting here...only in reverse.
    Beautiful day, parked my truck and tended to business. Came out to leave and noticed this El Camino parked unnaturally close to my rig. No note, nothing. Tell me you couldn't tell you backed into someone. Sent these pics off to my insurance agent, he handled my claim, pretty certain whoever this perp was had an adjustment to their insurance premium.
    Thatbassguy and icebear like this.
  18. Jan 23, 2025 at 8:53 PM
    #78
    Oh turd you’re the best! thanks for educating me. I never knew that in my 50 years on this planet. How did I make it this far without your plethora of knowledge.
    Drivers Ed? Based on what I’ve experienced, I don’t even think they even teach that in Massachusetts… lol
  19. Jan 23, 2025 at 8:56 PM
    #79
    he needs a parking lesson from thatBassguy. Hit you 1000 times and never leave a mark lol!
  20. Jan 24, 2025 at 6:10 AM
    #80
    Seems like you may need a refresher course if parking is this stressful. :D
  21. Jan 24, 2025 at 6:52 AM
    #81
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    If you guys are worried about parking dings just weld this up. Good to go.
  22. Jan 24, 2025 at 6:58 AM
    #82
    1SilverRunner
    Tejas
    ^All in good fun.
    I will say I think @Thatbassguy is right. Very slow impacts are unlikely to cause serious damage.
    Isn't that why insurance companies mandated vehicle manufactures to create bumpers that can "absorb" slow impacts? They were spending a lot of money on small fender benders when everything had steel and chrome bumpers.
    Nowadays, most bumper covers are plastic backed by foam. They flex quite a bit before doing serious damage.
  23. Jan 24, 2025 at 7:17 AM
    #83
    Oh yep, I’m a little disappointed they got rid of the 5 mph no-damage bumper requirement though.
    Thatbassguy and 1SilverRunner like this.
  24. Jan 24, 2025 at 8:03 AM
    #84
    vthoky New Member
    Looks like that dude still has a dent in the left rear door. :p
    icebear and Thatbassguy like this.
  25. Jan 24, 2025 at 8:06 AM
    #85
    This is exactly why you don't drive around with a trailer hitch installed. :D
    Yup. Because I wouldn't have a hitch in my bumper for no reason. ;)
  26. Jan 24, 2025 at 8:34 AM
    #86
    im good. Im easy like Sunday morning man!
  27. Jan 24, 2025 at 9:40 AM
    #87
    Yeah, I get the picture that you go around giving love taps…
  28. Jan 24, 2025 at 9:46 AM
    #88
    You jinxed me! So I let the wife park her car in the garage so she can load children easy…
    Just checked on the 4R look how close this dude’s car is my precious!
  29. Jan 24, 2025 at 10:47 AM
    #89
    Actually, I haven't hung out in that neighborhood in about 20 years. I'm just trying to point out that someone tapping your car in a parking lot isn't a big deal.
  30. Jan 24, 2025 at 11:01 AM
    #90
    I guess for some I could see it being a big deal tho, like if you have a ‘24 and not a beat up ‘16 lol…don’t live in New York that’s for sure, it’s like bumper cars I hear
