On the fence between a Westcott Design lift and Eibach spring lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Juan2022, Nov 2, 2022.
  1. Nov 8, 2022 at 3:54 PM
    Oz57
    Oz57 New Member
    Glenn
    2021 4runner
    2021
    Eibach Stage 2
    kolter45 and Pentangler like this.
  2. Nov 9, 2022 at 12:59 AM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    Have had the Eibach springs in my 2021 pro since they dropped in March with no issues. 7500 miles and some hard trail runs with 0 problems. Some people were reporting issues with clunking so Eibach pulled them off their site, which is why they are no longer available.
  3. Nov 9, 2022 at 2:52 AM
    Juan2022
    Juan2022 [OP] New Member
    Juan
    RGV
    2022 4 Runner TRD Pro
    None
    ACB55154-B76F-4092-90AD-7F072445C8CA.jpg This kit?
    Oz57 likes this.
  4. Nov 9, 2022 at 8:55 AM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    So you are just going to completely swap out the entires suspension, as opposed to tweaking the fox suspension already in the pro?
  5. Nov 9, 2022 at 9:17 AM
    Juan2022
    Juan
    RGV
    None
    Was asking if that’s what he used. No, want to get some use out of the fox suspension. Prob go with WD.
  6. Nov 9, 2022 at 9:18 AM
    Juan2022
    Juan
    RGV
    None
    I believe corn fed spacers will work also, haven’t done much research on them.
  7. Nov 9, 2022 at 9:21 AM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    If you want it timely, yeah. You could always try springs in the back and the wescott kit up front. I know some have done that.
    I used these: https://eibach.com/us/2821/e30-82-071-03-02-Toyota-4Runner-pro-lift-kit
    At the time there were springs for the new fronts as well, those have since been pulled and last I heard they are redesigning them. Still not sure what that means for those of us that have them and have none of the issues people have described though…
  8. Nov 9, 2022 at 10:12 AM
    PC836
    PC836 New Member
    Fresno, Ca
    2022 White 4Runner PRO
    Spoke to Eibach 2 weeks ago, they are revising the Pro lift springs for 21-22 due to prior complaints of noise, that is why it was pulled out of stock. I will be going with Eibach as soon as the springs are released. No way will I do with Westcott. Westcott and others will continue to say it is not a spacer but it actually is. I think Eibach has put alot of time and engineering into the spring that it will be a good fit and give a right height to fit 285 while still maintaining the performance of the FOX shocks.
    blackcloud08 likes this.
  9. Nov 9, 2022 at 10:33 AM
    Juan2022
    Juan
    RGV
    None
    So it would be just swapping out front and rear springs ? 2/1 of a lift?
  10. Nov 9, 2022 at 10:39 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    Doh!
  11. Nov 9, 2022 at 10:40 AM
    MeefZah
    Lexington, Ohio
    GX460
    Save on fuel lol. This guy!
    whippersnapper02 likes this.
  12. Nov 9, 2022 at 11:05 AM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    as someone with the Eibach springs, who does push their rig off-road, I am still wondering how people are getting noise. I have have had no issue with mine….
  13. Nov 9, 2022 at 11:33 AM
    Juan2022
    Juan
    RGV
    None
    i doubt I’ll get 19-20 mpg on 33”, what’s so hard to comprehend.
  14. Nov 9, 2022 at 4:23 PM
    blackcloud08
    blackcloud08 They're Watching Us....
    Sent you a PM. Is the 2021+ issue just on Pro models or all trims? I have the Eibach Stage 2 kit on my 2022 ORP and so far they're horrible. They were installed in May at their preset position and it's like they're rebounding hard and topping out ALL the time. I've been going round and round with them about this and man do they have a list of excuses... The rear setup is fine and rides very good but in my experience the coilovers are way worse than a spacer lift in terms of ride quality.
    If anyone has any insight from speaking with Eibach about this, PM me(to not hijack thread) as I'd love to know.
  15. Nov 9, 2022 at 8:08 PM
    PC836
    PC836 New Member
    Fresno, Ca
    For PRO 21-22, Eibach Pro Lift Springs will only give you 1.4 front and 1 inch rear.
  16. Nov 10, 2022 at 4:51 AM
    Juan2022
    Juan
    RGV
    None
  17. Nov 10, 2022 at 5:31 AM
    Kilo Papa
    Kilo Papa New Member
    TX & NM
    2021 TRD Pro
    My understanding after research and speaking with Eibach and others on this forum, is that the spring problem relates to front springs on ‘21 and later Pro models with Fox suspensions.
  18. Nov 10, 2022 at 7:33 AM
    slixx1320
    slixx1320 New Member
    Truth! And on top of that, $400 for spacers?? Yah, thanks but no thanks!
    The Toytec kit seems to be a better option and at the same price point as the WD kits, it comes with actual springs to achieve the lift.
    PC836[QUOTED] likes this.
  19. Nov 10, 2022 at 7:40 AM
    #49
    Kilo Papa
    TX & NM
    2021 TRD Pro
    For the Pro? If so, which Toytec “kit” are you referring to for the ‘21 and later Pro?
  20. Nov 10, 2022 at 7:41 AM
    #50
    slixx1320
  21. Nov 10, 2022 at 8:14 AM
    #51
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Thanks! I’ll take a closer look.
    Are those spacers/pucks that they’re using for the rear springs?
  22. Nov 10, 2022 at 8:18 AM
    #52
    slixx1320
    They are, looks to be similar design if not actual daystar rear spacer.
    kolter45 likes this.
  23. Nov 10, 2022 at 8:35 AM
    #53
    blackcloud08
    Thank you.
  24. Nov 10, 2022 at 8:42 AM
    #54
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Thanks for the link. And, are you using this kit on a ‘21 or newer TRD Pro with OEM Fox suspension?
  25. Nov 10, 2022 at 8:49 AM
    #55
    Juan2022
    Juan
    RGV
    None
    2-2.5 of lift on top of the stock trd pro 1”?
  26. Nov 10, 2022 at 8:51 AM
    #56
    slixx1320
    I am not.
  27. Nov 10, 2022 at 5:35 PM
    #57
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Toytec has a video of them installing the pro kit. Seems close to WD. I’d like to buy toytec cause they’re local to me & I save on shipping. I have a 2015 so I may go Eibach instead. Before you buy an Eibach set off another site, just buy it directly from them because they’re not all in stock!!!
    https://youtu.be/Ztjp5hbcMEE
    Stage 2.5 (2R) looks awesome & very tempting
    https://eibach.com/us/c-56-car-truck-suv.html
  28. Nov 10, 2022 at 6:41 PM
    #58
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    My 2020 AG Pro with Eibach springs and 285’s. It made my Pro higher and better with there springs.
    PC836 likes this.
  29. Dec 18, 2022 at 9:39 AM
    #59
    trdrunner2020
    trdrunner2020 @trdrunner2020
    2020 Black 4Runner TRD Pro
    thinking about the springs myself for my 2020 pro. How do they compare to stock? You push it off road?
  30. Dec 18, 2022 at 10:29 PM
    #60
