Old Man Tan
Discussion in '4th Gen Builds (2003-2009)' started by thefatkid, Feb 15, 2018.
  1. Feb 10, 2019 at 5:00 PM
    thefatkid
    thefatkid [OP] New Member
    OldManTan
    4th Gen 4Runner life
    Not really. I'm still in the air on the swing out. I just happened to slide into a tree this weekend snow wheeling. Bumper did its job protecting the 4runner but took some damage. I might order a 2nd bumper and try again from the beginning.
    Watt maker likes this.
  2. Feb 10, 2019 at 5:03 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    S
    That sucks man! We’ll keep us posted best of luck to you.
    jgcaps and thefatkid[QUOTED][OP] like this.
  3. Feb 10, 2019 at 10:26 PM
    thefatkid
    OldManTan
    On stock 5th gen wheels I need spacers. I could likely do without if I didn't have to worry about the reservoir hose in the rear. The front just touches the frame at steering lock.
  4. Apr 1, 2019 at 8:55 PM
    thefatkid
    OldManTan
    Much needed wiring cleanup. You never look into your wiring future when starting a mild off road build. Couple wires added here or there and all the sudden it is spaghetti. Now looking at my build and where I plan on taking it it is easy to see the wiring I need and have a little left for the future. Using Power Trays, Blue Sea circuit breakers, S-Tech universal 6 switch system and some patience I now have this.
    I'm also adding a v8 transmission cooler
  5. Sep 15, 2019 at 1:11 PM
    1grfe4x2
    1grfe4x2 New Member
    4runner 4x2 sr5 2008
    Dear Fellows, someone know if the rear diff of a 2008 4x2 sr5 4.0L is a limited slip or is a normal diff? the question is because I heard if I put a non LS type into a LS diff type this will broke my diff.
    Looking forward to hearing from you, also thank's in advance. (sorry for my english, is not my native language)
