Oil viscosity
Discussion in '5th Gen 4Runners (2010-2024)' started by Sailormilan2, Jun 28, 2022.
  1. Jul 7, 2022 at 10:46 AM
    #61
    auspilot
    auspilot Old Member
    2020 TRD OR
    Dobs IMS, lots of small stuff
    I tried to pin down Toyota about this and didn't get much satisfaction. Here's what I asked:
    I own a 2020 4Runner TRD Offroad. I am wondering about the oil viscosity for this vehicle.
    The owners manual specifies 0W20 but the manual also contains the phrase "The 20 in 0W-20 indicates the viscosity characteristic of the oil when the oil is at high temperature. An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions."
    I live in Texas where we often drive long distances at 80mph in very hot weather. Does the manual phrasing imply that I might use 5W30 in these conditions? If I use 5W30 will it void my warranty?
    Here's what they replied:
    ElectroBoy and Thatbassguy like this.
  2. Jul 7, 2022 at 10:49 AM
    #62
    Sounds like a pretty generic response.
    engineer90 and banjos-n-beer like this.
  3. Jul 7, 2022 at 10:54 AM
    #63
    Daddykool
    They won't respond with an answer that varies from the owner's manual. Nobody would do that.
    icebear, 2Toys, 7Runner and 2 others like this.
  4. Jul 7, 2022 at 11:47 AM
    #64
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Once again they are hedging to keep their agreements with EPA. And to keep the public guessing to scare them into using 0W-20.
    hedging:
    1. an intentionally noncommittal or ambiguous statement
    2Toys likes this.
  5. Jul 7, 2022 at 11:56 AM
    #65
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    right. reminds me of the time i contacted infiniti, asking about their transmission that came with "lifetime" fluid. so i asked them how long this transmission was supposed to last? got a very generic type of answer that prevented them from being held accountable for transmission failure.
    long story short i decided to start doing drain and fills despite the "lifetime" claim.
    2Toys likes this.
  6. Jul 7, 2022 at 12:07 PM
    #66
    Steve40th
    Steve40th New Member
    sTEVE
    kinematic viscosity at 212 degrees. Why use weird numbers nobody is used to.
    Like octane, you want research octane or motor Octane?
    Marketing..
  7. Jul 7, 2022 at 12:50 PM
    #67
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    20 and 30 weight are just names for different grades of motor oil.
    The numbers 9 and 11 are actual kinematic viscosity measurements reported in units called centistokes (cSt). There’s more to viscosity testing. You can read about it here:
    https://www.machinerylubrication.com/Read/411/oil-viscosity
    engineer90, 2Toys and Thatbassguy like this.
  8. Jul 13, 2022 at 3:18 PM
    #68
    blackcloud08
    blackcloud08 They're Watching Us....
    It's all about looking good for CAFE numbers as several have already stated. I've used 5w-30 in the following with no issues:
    2022 4Runner
    2018 4Runner
    2017 Tacoma
    2017 Camry
    For inquiring minds, I used Amsoil Signature Series 5w-30 with TRD or Amsoil oil filters.
    To the ones mentioning lifetime transmission fluids, my theory is that it's so they can advertise almost zero maintenance cost as most customers won't keep a vehicle past 60k-100k miles or so. I myself would never trust a lifetime fluid as they don't exist. I drain & refill every 30k miles with Amsoil Signature Series transmission fluid.
  9. Jul 13, 2022 at 7:41 PM
    #69
    Loco x Toyota
    Loco x Toyota New Member
    Cedar Park, TX
    TRD Pro Solar Octane
    Looks like you won't have to buy another car or truck for the next 30 years or 1 million miles.
    Out of all the 4 vehicles you mentioned, the only weak link is the Tacoma if it's the V6, which is more complicated design.
    engineer90 and Thatbassguy like this.
  10. Jul 14, 2022 at 3:35 AM
    #70
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    yup. i concur. its mostly to cover their butts during the original warranty period. the oil will break down, and heat is probably a transmission's worst enemy.
  11. Jul 14, 2022 at 8:18 AM
    #71
    blackcloud08
    The Atkinson isn't bad IMO, the transmission hunting gears for days is the worst part of it.
    Sprouty115 likes this.
  12. Jul 14, 2022 at 8:19 AM
    #72
    blackcloud08
    Correct, once the fluid looses the ability to pull heat and lubricate, end of story.
  13. Jul 19, 2022 at 5:38 AM
    #73
    nickrick78
    nickrick78 New Member
    Use the oil viscosity, type, and capacity recommended by Toyota. If you're nervous about it, send an oil sample to Blackstone for analysis, it's like $20.
  14. Jul 19, 2022 at 7:35 AM
    #74
    Steve40th
    sTEVE
    Blackstone is very good. I mentioned them in post 68. Its worth it, especially if nervous or you do extreme use in your vehicle, ie towing, racing, etc
  15. Mar 25, 2024 at 3:40 PM
    #75
    engineer90
    engineer90 New Member
    NJ
    Alrighty guys, I'm bumping this thread. So yes, I read on page 527 of the manual for my 23 ORP.
    It does state that higher viscosity is for higher speeds and heavy loads. I live in NJ and travel to upstate NY and PA quite often which means a lot of interstate travel with a lot of weight in the truck... and in the summer I plan to get a utility trailer to carry kayaks/canoes. I might get Wildpeaks AT4W but they're way too heavy imo so I might do Terra Grappler G2 since they should be more than enough. I will also get rock sliders which should add approximately 100 lbs to my 4R. So in theory, it will have more load. Over here the temps vary from low 20s to upper 90s with humidity (in the summer)... colder in PA and even colder in upstate NY. I am heavily considering switching to 5W-30 or 0W-30.
  16. Mar 25, 2024 at 3:57 PM
    #76
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    I've been running M1 FS 0w40 in mine and will continue to do so. Great oil. And I don't haul anything.
    engineer90[QUOTED] likes this.
  17. Mar 25, 2024 at 4:14 PM
    #77
    engineer90
    NJ
    Any less performance on highway since it's thicker?
  18. Mar 25, 2024 at 5:12 PM
    #78
    Sailormilan2
    Sailormilan2 [OP] New Member
    Dale
    2020 4Runner TRD Premium
    OP here. After my original post, I did some online research. The following is from different sources.
    0W-20 is optimal at abou67* “ambient temperature”, and works well up to about 87* “ambient temps”.
    According to oil temperature charts, which Toyota no longer publishes in their manual, for each 10 weight of oil increase, optimal temps go up about 10*.
    Some Toyota publications suggest going to a heavier oil for “severe duty”. Some sources use the term, “severe duty”, for certain Toyota engines, though the 4Runner engine is not listed. Severe duty is defined as 80% of the max speed, for extended periods, in extreme heat. 80% of the max speed of a 4Runner is about 90mph.
    While Toyota may say that under certain conditions one may need a different oil, they don’t really say what those conditions are, or what oil can be used.
    So, if you live in a region with very high summer temperatures, as I do, and drive fast on the freeway, 0W-20 is probably not a good choice.
  19. Mar 25, 2024 at 5:17 PM
    #79
    Steve40th
    sTEVE
    I use 5w 30 in an engine that runs up to 225 degree oil temp.. I am not sure what the 4runner temps are here in the summer, South Carolina.
    But a 5000 pound truck, v6, stop and go, and only a mechanical fan, I am sure its pretty much around 220 to 230 in town.
    Anyone ever check temp?
    engineer90 likes this.
  20. Mar 25, 2024 at 5:17 PM
    #80
    engineer90
    NJ
    Yeah I think I'll definitely do 0W-30 or 5W-30 next oil change. Thanks for this.
    We do a lot of long drives and very loaded too with outdoor gear and cameras and my dog and such. So I wanna make sure the 1GR-FE is safe in all conditions. My Hyundai Tucson burns 5W-20 in long distance drives like there's no tomorrow... although that is a theta II engine issue and it doesn't like being driven hard.
  21. Mar 25, 2024 at 5:34 PM
    #81
    FYI the single-VVTi 1GR in the 4th gen 4R and 2nd gen Tacoma runs too hot for 0W20, so it's always been spec'd with 5W30. The dual-VVTi 1GR in the 5th gen was able to use 0W20 because of changes in the water jacket that resulted in more uniform temps around the cylinders: https://australiancar.reviews/1GR-FE-engine.php
  22. Mar 25, 2024 at 6:26 PM
    #82
    ^You're just a shill for big oil!
  23. Mar 25, 2024 at 6:31 PM
    #83
    MKIVBB
    MKIVBB New Member
    2017 Super White 4Runner 4x4 SR5
    Volk TE37 Bronze Replicas, TrailFinder A/T Tires, Custom AV System, Etc
    Believe it or not, the Kirkland full synthetic I've been using in my 4Runner and Tundra have been getting great reports from Blackstone.
  24. Mar 25, 2024 at 7:55 PM
    #84
    I have yet to see a bad report from BlackStone if the correct sae and weight is used.
  25. Mar 25, 2024 at 8:25 PM
    #85
    I used it for two intervals without issues.
  26. Mar 25, 2024 at 9:11 PM
    #86
    2016Pro
    Just use what the manual recommends it's not that difficult lol
  27. Mar 26, 2024 at 5:03 AM
    #87
    7Runner
    2018 Silver SR5P
    No negative impacts at all. Just smoother and quieter engine. And more protected.
    That said, I may go back to M1 EP 5w30 or Valvoline EP 5w30 just because they're easier to get in my area.
  28. Mar 26, 2024 at 5:59 AM
    #88
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    This is very good info. Thanks!
    In Texas I see temps above 105-110f every year. I will be swapping to 5w-30 before summer. Might consider a 5w-40 oil better suited based on this graph. Especially considering the fact that I commonly load up a ton of gear and drive 80+ mph for 5-6 hours...
    This graph makes me regret running 0W-20 for so long!
    Braced for the :crapstorm: this comment stirs up.
    Old Tanker and engineer90 like this.
  29. Mar 26, 2024 at 11:38 AM
    #89
    ^I'm hesitant to use 0W40 because it's two viscosity grades higher than the 0W20 specified in our engines at operating temperature. This may cause higher oil pressure and force the oil filter bypass valve to open more often in high rpm conditions. I buy 0W30 when on sale and use them in everything (5th gen 4R, 3rd gen Tacoma, father's Subaru, lawn mower), going through ~34 qts or 7 jugs per year. So far so good.
    engineer90 and SlvrSlug like this.
  30. Mar 26, 2024 at 12:41 PM
    #90
    I think all of the generic oils are made by major oil distributors. I've used Super-tech for years and it's been good.
    Kirkland is made by Warren. They also make Amazon oil, and Meijer store brand among many others.
    https://engineoil.api.org/Directory/EolcsResultsDetail?accountId=-1&companyId=10297
    True! But, the manual recommends higher viscosity in some circumstances. For regular use, 0W-20 is certainly fine.
    1SilverRunner likes this.
