Oil filter
Discussion in '5th Gen 4Runners (2010-2024)' started by 2016Pro, Mar 5, 2019.
  1. Aug 23, 2021 at 7:24 PM
    #61
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    Hard to remove filter housings are one of the draw backs of long term oil change intervals.
    Going 10k miles on a housing that might have been over tightened by a dealer monkey has a definite chance for being seized.
    I'm one of those fools that does a 3k mile interval w OEM filters, still never had a problem with the plastic housing.
  2. Aug 23, 2021 at 7:29 PM
    #62
    You guys getting the metal housing from the dealership?
    Or is it an Amazon thing?
    Looks like a good upgrade. Next we just need to find an aluminum thermostat/radiator hose coupler.
    A&P likes this.
  3. Aug 24, 2021 at 11:24 AM
    #63
    2016Pro
    2016Pro [OP] Why all of the Pro hate?
    Never had an issue with my 10k changes
    A&P and nimby like this.
  4. Aug 24, 2021 at 7:08 PM
    #64
    HornedOwl
    HornedOwl New Member
    Washington State
    A&P and Slopemaster[QUOTED] like this.
  5. Aug 25, 2021 at 2:57 AM
    #65
    MI-FL off roader
    Brett
    Merritt Island, FL
    Yes Sir, and you've saved a lot more money too.
    A&P likes this.
  6. Aug 25, 2021 at 6:53 AM
    #66
    4wheelforlife
    4wheelforlife New Member
    T
    2021 4Runner
    My uncle has owned Toyota for over 40 years. He has hit 300k plus on all of them. He told me always go with factory Toyota oil filter as it fits better versus other brands. I don’t know personally just going to take his advice due to his experience.
    Slopemaster and Ironguy like this.
  7. Aug 25, 2021 at 6:55 AM
    #67
    Thank you,
    I'm getting ready to do my first oil change on the 4Runner.
    I think I may pull the skid plate the night before, so all I have to do is drive it around a bit to warm it up without having to fight the skids on a warm vehicle.
  8. Aug 25, 2021 at 11:05 AM
    #68
    2016Pro
    I don't think I matters , my Tacoma has 200k plus I use other brands
    A&P likes this.
  9. Aug 25, 2021 at 3:59 PM
    #69
    HornedOwl
    Washington State
  10. Aug 26, 2021 at 6:59 AM
    #70
    iamincrediboy
    iamincrediboy New Member
    South FL
  11. Aug 26, 2021 at 7:44 AM
    #71
  12. Aug 28, 2021 at 12:19 PM
    #72
    LA260
    LA260 New Member
    Well after they told me last week that the trd oil filters won't be shipped for few months they were delivered today.Ordered Aug 16th
    HornedOwl likes this.
  13. Sep 22, 2021 at 8:42 PM
    #73
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    I just did my first oil change today on my 21 TRDORP and used a TRD filter p/n PTR43-00079.
    The filter installed into the housing a little wobbly. I am guessing this is because the rubber gasket is the only thing making contact on the bottom of the filter housing. The filter housing screwed into the vehicle smoothly with no issues.
    Just wanted to check with those that have used the TRD filter that it seems a little loose compared to the non TRD filter when you put it in the holder before you install it.
  14. Sep 23, 2021 at 6:28 AM
    #74
    Yeah, you're fine. There's a little spring mechanism thingy under the filter that will make it a little cattywompus before installation.
    A&P likes this.
  15. Sep 23, 2021 at 7:54 AM
    #75
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
    As an FYI the Toyota TRD oil filters and the AMSOIL Oil Filter EA15K49 are identical with the standard 25% as a preferred customer AMSOIL filters cost $22.65. I use both interchangeably.
  16. Sep 23, 2021 at 8:41 AM
    #76
    Chucklehead
    Chucklehead Enjoy the ride! You only get one trip
    Fort Wayne, IN
    2021 4Runner Black TRD ORP
    Stock AF, with subtle personality tweaks
    I assume the TRD version is 'better' in some way - true / false??
    If true - what advantages does it have?
    All for the absolute best filter possible as that is THE main component that's catchin the crap from recirc for however many miles a person's preference it is to go between oil changes...
  17. Sep 23, 2021 at 8:47 AM
    #77
    TrueTexas
    The Woodlands, TX
    @nimby . Thanks. Yes, "cattywompus". That is exactly the word to describe it. Seems like the rubber gasket is the reason. But it screwed in without any fuss so I'm sure it found it's home when it contacts the top and bottom.
    That being said, I like the design of the TRD filter. The rubber gaskets look like they will force oil thru the filter whereas the stock filter looks like some of it may bypass the filter at the top and bottom. I'm sure it's not much (and may not be worth the extra money) but I don't mind spending the $9 extra on a filter. Plus, it says TRD on it - even though no one will ever see that.
    @josephp732 my dealer sells me the TRD filters for $14.08 (online price match). But good to know there is an amsoil option in a pinch
  18. Sep 23, 2021 at 8:56 AM
    #78
    josephp732
  19. Sep 23, 2021 at 1:28 PM
    #79
    Make sure you're using the correct filter and it's long enough to cover all the perforations the filter slides on to. Sometimes mistakes are made where people get a corolla filter (or whatever it is) and it ends up being too short. The proper filter should cover all those perforations.
    ElectroBoy and A&P like this.
  20. Sep 23, 2021 at 1:41 PM
    #80
    TrueTexas
    The Woodlands, TX
    I have p/n PTR43-00079.
    And yes, it covered all the perforations. Was actually a tiny bit taller - assuming that allows the rubber gaskets to seal on the top and bottom of the housing
    A&P and nimby[QUOTED] like this.
  21. Sep 23, 2021 at 6:31 PM
    #81
    MI-FL off roader
    Brett
    Merritt Island, FL
    This was one of the reasons I passed on most of my free oil changes at the dealer. After reading some of the horror stories on the forum, I decided to change it myself and found one of these short filters w some stripped out skid plate bolts and I vowed never again.
    Phuqing pitiful this type of incompetence is allowed to get near a 35 - 60k dollar vehicle.
    2Toys likes this.
  22. Sep 23, 2021 at 8:14 PM
    #82
    TrueTexas
    The Woodlands, TX
    I think I actually laughed out loud when the dealership was telling me about the free oil changes. Told them I would be doing them myself for exactly the reasons mentioned above.
    This was my break in oil change with a little under 2k miles on the clock. Will do 5k intervals from here on out.
    My previous vehicle (Chevy Silverado) came with free oil changes for 24k miles. The first one was fine. On the second one, they didn't even change the oil or filter. That was it for me, went back to changing it myself and never looked back. Plus I can change my oil in 1/10 the time it takes to drive to the dealership, wait for them to change it and drive home. The whole time wondering if they put the skid plate bolts in with an impact gun.
    A&P, thirdyota and MI-FL off roader like this.
  23. Sep 24, 2021 at 12:23 AM
    #83
    MI-FL off roader
    Brett
    Merritt Island, FL
    Yea, I really dont mention this when someone is looking at a used vehicle that the ad claims all maintenance documented by the dealer. Dont want to bust their bubble. There are still good dealer service depts out their, but you really have to stay on top of them. You cant just take their word for it imho. Unless you know cars and do your research? Seeking out a competent and honest independent mechanic is always a good idea.
  24. Sep 25, 2021 at 10:31 AM
    #84
    josephp732
  25. Sep 26, 2021 at 5:49 AM
    #85
  26. Sep 27, 2021 at 2:32 PM
    #86
    josephp732
    Amsoil and TRD filters:
  27. Oct 17, 2021 at 8:02 PM
    #87
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Anyone know if the TRD oil filters are no longer made? A lot of Toyota sites are saying they are no longer available.
  28. Oct 17, 2021 at 8:31 PM
    #88
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  29. Oct 18, 2021 at 3:43 AM
    #89
    Matt83
    Matt83 New Member
    Northeast
    What a waste of money.
    Xombie2000, A&P and 2016Pro[OP] like this.
  30. Oct 29, 2021 at 1:04 PM
    #90
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    TRD filters are supposed to have a higher flow rate. The cheaper OEM is just fine. Stick with OEM while under warranty. Using aftermarket filters can see a dealer void a powertrain warranty if you have issues.
    spyder918 likes this.
