Oil changes
Discussion in '5th Gen 4Runners (2010-2024)' started by ChrisB, Oct 25, 2024.
  1. Nov 3, 2024 at 7:34 PM
    #121
    thomason84
    thomason84 New Member
    2022 supercharged and lifted 4Runner
    Bilstein 8112 lift Magnuson Supercharger YotaWerx Stryker+ tune Sherpa Crestone rack Lots of other small stuff
    and it will likely be fine. But when it’s torn apart it will have more sludge and darker color. You will need to replace your pcv more often (if you haven’t please do so). But overall oil doesn’t kill engines unless you neglect them and use the cheapest oil and go way over in intervals
  2. Nov 4, 2024 at 6:20 AM
    #122
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I rebuild engines for a living and see a lot of engines with sludge that seizes lifters and clogs oil galleries.
    IF you want to keep the vehicle past 300k miles stay on top of your service. For hard use, cut all service intervals in half. :crapstorm:I know it's controversial but that's my opinion. However, I share that opinion with many people in the industry.
    Car care nut is a Toyota master tech. Catchy title, but he says here that he doesn't believe Toyota quality overall has gone down, but peoples willingness to do maintenance has. I'd agree with this assessment if you look past the Tundra engine issue, which is an isolated issue regarding one type of engine.
    He too believes that oil change intervals should be at 5k miles. Full stop.
    https://www.youtube.com/watch?v=qsFPk6-igBg
    Sin4R, icebear, San Angelo and 3 others like this.
  3. Nov 4, 2024 at 11:11 AM
    #123
    2016Pro
    That guy doesn't impress me I've watched his videos. He has quite a few errors in the ones I've seen.
  4. Nov 5, 2024 at 8:02 AM
    #124
    Is there any science behind a darker color having any effect on performance or longevity? I would argue that any additives or detergents in some of these specialty oils may be worse for bearings than a “dirty looking” oil.
    2016Pro likes this.
