Oil change on 2018 4runner
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runnah808, Mar 26, 2019.
  1. Apr 1, 2022 at 1:38 PM
    Rdesouza74
    Rdesouza74 New Member
    Ricardo
    07 4runner
    Nomods
    I just my new to me 2018 4Runner TRD off road, is there a place in the truck to adjust the miles interval from IE: 6k to 10k miles oil change? thanks for any info provided
  2. Apr 3, 2022 at 4:33 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    the oil is synthetic 0-20wt SN PLUS .........change the oil around 10k miles change the oil filter media and grease the drive shafts .rotate the tires and inspect the brake pads. look the rear diff gear oil if it clean good .. if its dark cloudy change it ..75-85 gear oil ..inspect the air filter .
  3. Apr 3, 2022 at 4:48 PM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    What's sn plus oil?
  4. Apr 4, 2022 at 10:58 AM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Anyone know if this is acceptable for greasing the driveshaft? Manual says it has to be lithium based nlgi no.2 Valvoline Crimson.
    sorry if this is a dumb repetitive question
    D1D9BD28-128B-407E-B209-14B26A47DAE7.jpg 3890ABD3-105D-4FF4-9356-AA1BB2DAFD0B.jpg
  5. Apr 4, 2022 at 3:17 PM
    lrizzo
    lrizzo New Member
    Northern New Jersey
    Yes it matches the spec you mentioned above. NLGI 2. It the packaging had NLGI 1 then it would be a no. You can even use it for the prop shaft. They do recommend one with moly for the prop shaft but the one you have will work too and acceptable.
  6. Apr 4, 2022 at 4:06 PM
    GrantA
    North Carolina
    Thank you… I have molly as well for my tractor
  7. Apr 4, 2022 at 4:34 PM
    j cat
    j cat New Member
    massachusetts
    toyota 0-20wt engine oil and Mobil 0-20wt sn plus ...
    they changed the additive 4 yrs ago ... GM dexos 2 ...
  8. Apr 6, 2022 at 3:07 PM
    2012T4R
    2012T4R New Member
    Aaron
    2012 SR5 4WD 4RUNNER
    Roof rack, intake, muffler, Kings and springs, sound system, etc.
    Mobil 1 full synthetic every 5k or so. That motor will go forever!
  9. Apr 6, 2022 at 7:29 PM
    2016Pro
    Or any brand of synthetic every 10k miles...my tacoma has 210k trouble free miles!
    nimby and j cat like this.
