Oil Change Interval: 5,000 miles or 10,000 miles?
Discussion in '5th Gen 4Runners (2010-2024)' started by Lou, Aug 24, 2023.
What is your oil change interval?
  1. Every 5,000 miles
    130 vote(s)
    74.3%
  2. Every 10,000 miles
    30 vote(s)
    17.1%
  3. Other (please explain in the thread)
    15 vote(s)
    8.6%
  1. Sep 22, 2023 at 10:23 AM
    #181
    I've really only heard of issues developing from ethanol being used in engines that sit unused a lot, like boats and recreational vehicles. I've actually been using E15 in the 4Runner whenever it's available (and cheaper than regular) and so far I don't have any issues.
    I have a gas station 5 minutes from me that sells ethanol free premium, but it's really not worth the cost. However, I would use it if I still had a fishing boat, or if I got an ATV or something like that.
    I also have been using the pre-mixed Husqvarna fuel in my chainsaw, and I don't believe I'll ever switch.
    2Toys and 2016Pro like this.
  2. Sep 22, 2023 at 11:03 AM
    #182
    We can't get synthetic oil. Unless you're thinking about running a different viscosity than stock, in which case be prepared for 7 more pages of bickering. :goingcrazy:
    I was just saying that I don't think it's harmful in vehicles that get used regularly. Although, I have also heard of it being hard on seals in older vehicles. :notsure:
  3. Sep 22, 2023 at 11:04 AM
    #183
    2016Pro
    Lol
  4. Sep 22, 2023 at 1:24 PM
    #184
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 265K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    What hasn't been asked here is how mileage is being determined. Distance traveled divided by gallons to fill is the only accurate method. I've seen people talking MPG numbers and gains then they say, "Well, that's what the dash display says." One person was claiming to average 23 MPG in a 4th Gen V6 because that's what the truck's computer said. Nope. I have a 4th Gen and have tracked my mileage using Fuelly for almost 30K miles. Lowest was ~13 (offroading all day), highest was ~22 (interstate all day with a tailwind), and the average is ~17. The dash display typically shows 2+ MPG more than actual.
    Your observation supports the theory that midgrade only exists because marketing studies showed that people presented with two choices usually take the less expensive, but will take the middle option when three are offered. Add the people who think 93 does some good in an engine designed for 87 and the oil companies have a nice additional revenue stream.
    Muggsy71 and Thatbassguy like this.
  5. Sep 28, 2023 at 12:06 PM
    #185
    Lou
    Lou [OP] New Member
    2021 TRD Off Road Premium
    Commuting a ton of miles every day is not one of the criteria for severe driving according to the manual. It relates to lots of stop-and-go, idling, dirt roads, towing and low temps.
  6. Sep 28, 2023 at 12:26 PM
    #186
    joshdub
    joshdub New Member
    2020 TRD ORP
    I've seen at most a 1mpg increase and I'm not convinced that it's a real increase. The 4runner has regularly used about 15.7 mpg over the past 30k. The past 3k I've been running 91 octane and have seen mid 16s. Could be seasons, could be tire pressure, could be the fuel. I do see about a 4-5mpg gain when driving in Oregon where most speed limits are 55-60mph (where I drive) as opposed to the 65-70mph here in Washington. I have found a big drop in efficiency when averaging over 60mph as opposed to under it
    2016Pro likes this.
  7. Sep 28, 2023 at 12:31 PM
    #187
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    It’s per tank I misspoke,but I do get a big drop as well over 75MPH
  8. Sep 28, 2023 at 2:24 PM
    #188
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I once ran 93 octane as it was all the gas station had. Did not notice a single difference in fuel economy which I always monitor.
    2016Pro and gomiami like this.
  9. Sep 28, 2023 at 5:43 PM
    #189
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I've seen arguments that it takes several tanks for the computer to make, and stick with, adjustments based on knock sensors. I don't know if those claims are accurate or not.
    I don't run 91 because it's about $1 more per gallon here than 87. I've always run 87 and was getting damn good mileage at first, avg 20+ with all highway driving. Now my driving is more back roads and around town so I expected it to go down but the weight and tires I added probably made the biggest difference. It's dropped at the rate I expected based on mods and driving type.
    You may get better mileage out of 91 but at over $20 extra per tank for that (at least here), I seriously doubt it drives any type of fuel savings. Unless you're purely concerned about how much you're burning, and if that's the case, buy a tesla
    2016Pro, Thatbassguy and gomiami like this.
  10. Sep 28, 2023 at 6:18 PM
    #190
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    So we're at 7,500?
  11. Sep 28, 2023 at 6:19 PM
    #191
    FN2187
    FN2187 Stormtrooper
    Earth
    Life is a compromise...
  12. Sep 28, 2023 at 6:21 PM
    #192
    I'm still at 1K or every month.
  13. Sep 28, 2023 at 6:33 PM
    #193
    FN2187
    FN2187 Stormtrooper
    Earth
  14. Sep 28, 2023 at 6:52 PM
    #194
    Lol!
    You could replace the bottom one with "adding oil every 300 miles because it's a Honda and it burns oil like a 2-stroke."
    Ironguy, gomiami and 2Toys like this.
  15. Sep 29, 2023 at 2:14 AM
    #195
    I thought it was their older VTEC motors that burned oil. All I know is that a friend of mine has a CRX and I did not enjoy following him around on a road trip a few years ago.
    What kind of Honda did you have?
    Steely123 likes this.
  16. Sep 29, 2023 at 3:31 AM
    #196
    My 95 vtec civic burned oil like crazy. Mainly because it blew valve cover gaskets like an Olympic sport.
  17. Oct 1, 2023 at 11:33 AM
    #197
    2016Pro
    Lol
  18. Oct 1, 2023 at 11:33 AM
    #198
    2016Pro
    Every 100 miles
  19. Oct 28, 2023 at 5:58 PM
    #199
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Super Ice Cap White
    Humm... Joe Gibbs Racing oil guy says...
    https://youtu.be/_6nWCQ_70J0
    T in Texas, Old Tanker and Tank010 like this.
  20. Jul 8, 2024 at 6:48 PM
    #200
    Hightide
    Hightide New Member
    1999-2005-2018 4runners
    My 3rd gen, v6, 4runner purchased new in 1999 was just retired with 396K (70/30 highway/street) miles. Minimal towing or off-road activities during the vehicle life.
    Conventional oil changed at the first 3K miles, Amsoil synthetic installed every 10K miles up to 140K miles followed by Mobil 1 extended performance 10W-30 over the remaining miles. Engine compression test at approximately 330K miles was well within the spec range and replaced the 1st bad fuel injector at 394K miles. Only remember using Fram ultra synthetic oil filters with high mileage rating.
    Very few issues with engine performance outside normal tune-up activities and I'm confident this vehicle would have operated more than 500K miles following proper transmission fluid and frame maintenance (8 years of road salt exposure).
    I will continue following the 10K mile oil change intervals on my 2005 and 2018 4runners when mileage exceeds the time intervals specified in the owner's manuals.
    The Toyota forums are truly best in class, and I'm grateful to all the contributors who have provided recommendations and technical information that helped me resolve vehicle problems over the years. Cheers!
