Offroad Setup - Use Spacers or Offset Rims.
Discussion in '5th Gen 4Runners (2010-2024)' started by SeaHound1, May 12, 2023.
  1. May 14, 2023 at 11:24 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Literally. It epitomizes adding insult to injury.
    Spare Parts[QUOTED] likes this.
  2. May 14, 2023 at 11:31 AM
    Yes, rubbing is taboo. Nothing says “half-assed” like tires rubbing on things that they shouldn’t. Even in those situations where practically speaking the setup works in spite of the rubbing, it’s got no class. But you do you.
    Increasing the scrub radius is bad. Long travel suspension let’s you widen the track without affecting the scrub radius.
  3. May 14, 2023 at 5:21 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i guess mentioning the notion of fixing rubs would have added context. i’ll go ahead and keep my peasant build and rub fixes out of the way around here.
    fyi - long travel changes the knuckle location effectively changing wheel center line and it’s scrub radius.
  4. May 14, 2023 at 6:42 PM
    Please explain.
  5. May 14, 2023 at 7:14 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    LT control arms are longer which naturally moves the steering knuckle outward.
  6. May 14, 2023 at 7:25 PM
    Naturally. But as the steering knuckle moves outward the wheel moves with it. The relationship of the steering knuckle to the centerline of the wheel is unchanged, and so the scrub radius is unchanged.
    For visual reference:
    djwantke likes this.
  7. May 14, 2023 at 7:44 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    when dealing with wheel off set you change the radius length.
    when moving the steering knuckle you’re dealing with the position of the radius point. though you’re not lengthening the radius you are repositioning it to a point where the sweep or scrub if you will - occupies the same area as a lengthened radius.
  8. May 14, 2023 at 8:16 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  9. May 14, 2023 at 10:45 PM
    Maybe I’m misunderstanding you. Referring again to the drawing, the vertical dashed line is the centerline of the wheel. The other dashed line, the one that runs diagonally through the upper and lower ball joints, represents the steering axis. Where the diagonal dashed line meets the ground is the point around which the wheel rotates with steering input. The distance at the ground between the centerline and the steering axis is the scrub radius. Do you mean in the quote above that when you change to long travel suspension that the scrub radius distance is changed?
  10. May 15, 2023 at 8:05 AM
    With a LT scenario, the wheel/tire position has moved outward relative to where it sat before in the wheel well.
    I think that more outward positioning alone would increase the chances of rub whether it's technically changed the scrub radius or not.
  11. May 15, 2023 at 12:26 PM
    When you widen the track of your vehicle with wheel spacers or changes in offset you increase the scrub radius. If you widen the track with long travel suspension, you leave the scrub radius unchanged. Increasing the scrub radius contributes to an increased arc prescribed by the wheel as it turns, and it’s the increased arc, primarily, that causes the rubbing.
    Here’s the same drawing as posted above. As the label denotes, it shows a stock 265/70r17 tire on a 7½x17 rim with a +15mm offset:
    What if we replace the stock wheel with the very popular 285 tire on the 7x17 rim with the +4mm offset?
    Comparing the two drawings, notice in the second drawing that the offset is decreased and the scrub radius has increased.
    Looking down from the top, we still see the dashed line prescribing the steering axis. From this view it is apparent that not only is the point of the tire’s rotation on the ground not centered on the tire laterally, it’s not centered front to back either. An effect of this is that as the tire is turned left and right, the leading outboard corner and the trailing outboard corner of the tire prescribe 2 different arcs, drawn in orange.
    Now let’s swap out the 265 wheel for the 285.
    The arc of the 285 wheel is purple. The arc of the 265 wheel is orange. The 285 wheel fits in the wheel well just fine. So why does it rub? Because the 4Runner is not very tolerant to changes in the diameter of this arc. It’s so intolerant, in fact that just pushing the wheel outboard of the steering axis a scant 4 tenths of an inch, (as occurs when the TRD Pro rims are fitted) causes Toyota to cut the fender at the port. It’s not merely the wheel being pushed outboard that causes the rubbing. It’s the wheel being pushed away from the steering axis that causes the trouble.
    nimby[QUOTED] and auspilot like this.
  12. May 15, 2023 at 1:20 PM
    backpacker
    2023 TRD ORP
    3D geometry wins every time.
  13. May 15, 2023 at 3:51 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i mispoke and didn't articulate my point properly.
    what happens to scrub radius aside when changing the length of the control arms, the noted arc radius will be affected since the wheel will be positioned differently. this may not result in the typical rub points on the body, but will definitely rub.
    nimby likes this.
