OEM LED headlights conversion adapters for 14-20 halogen 4Runners!
Discussion in 'Lighting' started by mynameistory, May 1, 2022.
  1. May 19, 2023 at 9:38 PM
    #151
    WANGSTA
    WANGSTA New Member
    And both are now plug and play solutions right? I’ll browse around a bit more and order from ya today or tomorrow! [leaning quad]
    Naive questions have been answered previously already. Going with the quad!
  2. May 20, 2023 at 7:57 AM
    #152
    replica9000
    replica9000 New Member
    Jason
    New Vertiform City
    2019 TRD OR Premium
    Did anyone determine how much different the new DRL only pattern is compared to the original high beam pattern?
  3. May 22, 2023 at 10:33 AM
    #153
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Go back and read starting at post 33. I made some close up photos but did not do a distance comparison. The new DRL pattern is a wider spread and I find that it illuminates wider and higher. I like it.
  4. May 27, 2023 at 10:11 AM
    #154
    WANGSTA
    WANGSTA New Member
    Curious are those dark rectangles vertically aligned to each LED at that 3ft ish distance?
  5. May 27, 2023 at 10:15 AM
    #155
    WANGSTA
    WANGSTA New Member
    Quick and easy install!
    Ordered 5/20, arrived 5/22 and installed quad plugs yesterday with no issues. 2021 Pro on 2017 Limited
  6. May 28, 2023 at 7:56 AM
    #156
    mynameistory
    mynameistory [OP] New Member
    Tory
    The same 4Runner everyone has
    I like my KDSS. If I were to get a pro it would be an 18 in cavalry blue though.
    Whatever they are, they're hard to see inside the projector bulb. But yes they're fixed vertically. They seem to have a kind of horizontal gradient though, they change shape from left to right as you get closer/further to a wall. They're unobtrusive during regular driving.
    daveeasa[QUOTED] likes this.
  7. May 30, 2023 at 1:12 AM
    #157
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    So you purchased the $40 option with no shutter and this is the only adapter needed to install 2021 led low/ halogen high headlight housing swap?
    I just found a set on fb marketplace and am slightly confused about what I should be buying. I don’t have drl hooked up at the moment because I have a few amber backlights going on.
  8. May 30, 2023 at 3:54 AM
    #158
    mynameistory
    Tory
    If you buy the LED low/halogen high harness but do not hook up the DRL/high-beam bulbs, you will not have DRL or high-beams. Come to think of it, you don't have high-beams right now.
  9. May 30, 2023 at 7:29 AM
    #159
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    +1 on these. On the 2022 replaced the factory DRL 9005 with a Nokia All Weather 9005. The DRL projects almost like a high beam. Can see overhead road signs from far. Without blinding anyone.
  10. May 30, 2023 at 8:54 AM
    #160
    donnermel
    dita.yota
    Truckee/Tahoe
    Hi, I’m definitely connecting everything on the actual headlight housing, I just have other lights connected to my fuse for drl. I sent you a dm.
  11. May 31, 2023 at 8:37 AM
    #161
    mynameistory
    Tory
    Responded to your DM. Yes for LED low only, purchase the $40 adapter. If your high beams are still hooked up to the truck, you still have factory DRL as they are the same bulb.
    donnermel[QUOTED] likes this.
  12. May 31, 2023 at 8:45 AM
    #162
    daveeasa
    daveeasa New Member
    David
    '02 Tundra, '05 Tacoma, '16 Tacoma
    I think I’ll change the price on the no shutter option to $35. I’ve gotten more efficient with that one with all the practice.
    mynameistory[OP] and donnermel like this.
  13. May 31, 2023 at 9:02 AM
    #163
    donnermel
    dita.yota
    Truckee/Tahoe
    Thank you! Super helpful can’t wait to try out the adapter and the new headlights
  14. May 31, 2023 at 9:31 AM
    #164
    Can 2021 TRD Pro /Limited and 2022+ owners have a module like this?
    Please note I don't think this VLED module work this way, I just used that pic to show what I'm looking for.
  15. Jun 4, 2023 at 5:43 PM
    #165
    romad86
    romad86 New Member
    Sorry for the delay. Looks like you got your answer, but yes, I got the one with no shutter. Instal couldn’t be easier. I’m pretty happy with the setup. Hopefully you got a good deal on the used ones you found.
  16. Jul 11, 2023 at 7:42 PM
    #166
    Yossarian
    Yossarian New Member
    2014 Forester, 2023 4Runner SR5P
    Forester: Diode Dynamics fogs, light bar, and aux reverse lights 4Runner: DD Fogs
    I have a 2023 and I just don't use the DRLs. Do you think the beam pattern would be good for slow speed off road driving? Either with the low beams, with the high beams, or by itself. I'd make a harness to power them independently just like I would a light bar. I'm not super interested in the quad high beam option since I'm planning on a pair of aux high beams.
    I'd probably use the DRLs more if they were amber or 5000K white or selective yellow - some light color that's already on the truck, but I don't love the halogen in this application.
  17. Jul 11, 2023 at 9:29 PM
    #167
    daveeasa
    daveeasa New Member
    David
    If you’ve never run a 9011 HIR, you don’t know what you are missing.
  18. Jul 11, 2023 at 9:45 PM
    #168
    Yossarian
    I'd prefer a more yellow light for foreground lighting, which is what I'm hoping to achieve with swapping the bulb and harness for my DRL reflector. I'm open to the 9011 though, if that's a better option than say, the DD SLF 9005 bulb.
  19. Jul 11, 2023 at 10:06 PM
    #169
    My grill lights/ raptor lights doing the job of DRLs. I used to have amber and recently changed to white.
    The bulb on reflector housing is used as an auxiliary lights or you can say quad highbeams. Not putting too much info as I'm not sure if that's what you are looking for. But if needed its on my YouTube.
    LuLu likes this.
  20. Jul 12, 2023 at 5:24 AM
    #170
    Yossarian
    https://m.youtube.com/watch?v=Gx2w4QhLWM4
    Is this the video you're referring to? If that's the case, I think swapping a selective yellow bulb in would work great for a low speed trail light.
  21. Jul 12, 2023 at 5:34 AM
    #171
    This video is just low beams in my Limited.
    This is the additional highbeam one-
    https://youtu.be/vesGHtosIHk
    There's another adding Diode Dynamic light bars in to front lighting.
    There's another will post in future to show how I added the 2 spot lights. So for front lighting I have 6 additional lights.
  22. Sep 8, 2023 at 8:58 PM
    #172
    TRDGrey2021
    TRDGrey2021 Guy in a truck
    2021 TRD Venture MGM
    Buncha Stuff
    OY! So much info here!
    Link from another thread in these forums said grab a drink and have a read for the good learnings.
    No kidding...may be the drink, but my head is spinning.
    Simple issue.
    have a 2021 TRD Venture with projector low beams and the hideous yellowish high beams.
    I am not looking to spend piles on new housings, I just want to have a high beam close to the color temp of the projectors.
    What is the quickest/simplest route?
    These guys....
    LA Plus Series 9005 HB3 LED bulbs 60W 6000LM 6000K Amplified Flux Beam
    Theses guys...
    https://www.headlightrevolution.com...high-beam-1418T4RUNNERLEDHIGH.V4_2?quantity=1
    Maybe these....
    https://www.diodedynamics.com/high-beam-led-headlight-bulbs-for-2003-2023-toyota-4runner-pair.html
    Thanks!
  23. Sep 8, 2023 at 9:56 PM
    #173
    With my experience I can say those 3 options would be nice in highbeam mode but would be little bright in DRL mode. LA plus series would be a decent option imo. The beat DRL I've seen is Xenon Depot LED Pro with (free) DRL driver. But they are not bright as the 3 bulbs you mentioned.
    If you are looking for even more brighter bulbs check for Hikari Titanova. (First hand experience with low beams)
    https://amzn.to/3R9AdXr
    Haven't tested personally but might try in future a bulb called Novsight should be brighter too.
    https://amzn.to/3sNUKGZ
  24. Sep 9, 2023 at 7:59 AM
    #174
    TRDGrey2021
    Buncha Stuff
    Thanks for the reply. May try the ones you linked.
    I never turn my drls on anyways so not worried about them being too bright.
  25. Sep 10, 2023 at 8:40 PM
    #175
    TRDGrey2021
    Buncha Stuff
    novasights went in easy and so far so good, though no DRL...but then I never used the drl anyways
    kmeeg[QUOTED] likes this.
  26. Oct 24, 2023 at 8:05 PM
    #176
    daveeasa
    daveeasa New Member
    David
    JETSPD1477 and mynameistory[OP] like this.
  27. Oct 25, 2023 at 9:06 AM
    #177
    mynameistory
    Tory
    JETSPD1477 likes this.
  28. Oct 25, 2023 at 12:00 PM
    #178
    ljerr2
    ljerr2 New Member
    IOWA
    2023 T4R Pro
  29. Oct 25, 2023 at 12:46 PM
    #179
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    these are perfect if you aren't dealing with 9005s on a PWM circuit.
  30. Dec 8, 2023 at 4:19 PM
    #180
    rracraa
    rracraa New Member
    2008 and 2018 SR5 T4R
    Before I place the order... are these the right part numbers for low beam led/ high beam halogens for a 2018 SR5? thanks!
