OEM LED headlights conversion adapters for 14-20 halogen 4Runners!
Discussion in 'Lighting' started by mynameistory, May 1, 2022.
  1. Jan 17, 2025 at 3:22 PM
    #361
    daveeasa
    daveeasa New Member
    David
    '02 Tundra, '05 Tacoma, '16 Tacoma
    I didn’t see where you spelled out your 6V source. That’s a key part of the challenge. The 9005 doesn’t care about polarity though so you could get creative on that aspect.
    Passenger side gets fused 12V DRL signal. Driver gets a wire initially from passenger 9005 ground pole.
    Also remember you have 3 modes. DRL off, DRL on, high beams on. Represented by 0V on passenger 9005, 12v on passenger 9005 and 12v on either side shutter wire. Presumably corresponding to 0, 6 and 12v per ideal design.
  2. Jan 17, 2025 at 3:28 PM
    #362
    Puppypunter
    Puppypunter New Member
    Johnny
    2019 SR Tacoma
    Some light electrical work
    Aren’t the 9005s right now receiving 0V (off) or 6V (on DRL)? So the goal would be to make them have 12V when the shutter wire activates? The 9005 is wired in series with common grounds, no?
  3. Jan 17, 2025 at 4:18 PM
    #363
    daveeasa
    daveeasa New Member
    David
    9005 wiring on 2022+ is passenger 12v on one side, other side to driver side, driver other side to ground. No 6v source exists other than running two bulbs in series. I'm not sure what you mean by "common grounds" as there is only one OEM ground in this circuit.
    Switching two bulbs between series wiring and parallel wiring with two relays seems likely to short. With a SPDT relay, maybe it's doable but it still doesn't make me feel all that good. It is possible to convert both to 12V though and PWM or resistive-load the grounds for DRL use somehow as that has no chance of shorting. But the possibility of sending 12V DRL directly to ground if switching isn't instantaneous makes me think this is not really worth playing around with.
  4. Jan 17, 2025 at 4:58 PM
    #364
    Puppypunter
    Johnny
    2019 SR Tacoma
    … Hold my beer! :p
    Common ground meaning the 6V is measured against the same ground as the 12V. It can get weird if they use transformers, but this sounds straight forward. So the 12V is on the passengers side? And the ground to chassis is on the drivers? No PMW, just old school simple wiring. That’s good. So switch ground on the passengers side and positive on the drivers. That even eliminates needing to run a 12V+ to the passengers side. Is there a convenient chassis ground on the passengers?
  5. Jan 17, 2025 at 5:26 PM
    #365
    mynameistory
    mynameistory [OP] New Member
    Tory
    The same 4Runner everyone has
    Not sure how much I can contribute at this point, it'll take me a while to parse through this :D
    scottiezilla likes this.
  6. Jan 17, 2025 at 5:26 PM
    #366
    daveeasa
    daveeasa New Member
    David
    Yes: https://fbchs.square.site/product/4...-harness/40?cp=true&sa=false&sbp=false&q=true
    So, you're thinking two relays, one for driver, one for passenger? Passenger is going to switch the "ground" leg of 9005 between chassis ground and output to driver side positive pole. Driver side is going to switch the "power" leg of 9005 between +12v (need clean fused source since drl is off when high beams are on) or output from passenger ground leg. Each is then protected "through the bulb" from shorting power to ground, and whichever switches first only matters for a short interval of potentially sending 12v before 6v or vice versa? I think I see it now. Not sure if it can be done with just one relay, as my thinking here is 2. Use 87a and 87 as inputs, 30 as output. coil off shutter and low beam ground. So 87 would be the fused clean 12v input, 87a the other wire for series. Oh, but I think you need a 3rd relay to switch power for passenger side from DRL 12v (only on w drl) or fused 12v constant (only on with shutter). so 3 relays?
  7. Jan 17, 2025 at 5:28 PM
    #367
    daveeasa
    daveeasa New Member
    David
    To me, at 3 relays it's just too much complexity to justify the quad high beam option. Though fully PnP I'd imagine some might bite, especially if it can all be done on the passenger side which I think is possible since driver is just fed from passenger ground output and the other side is chassis ground. Just a bit of an ugly hydra, even with a GEP, very Johnny-esque, you can use all your colors...
  8. Jan 17, 2025 at 5:32 PM
    #368
    Puppypunter
    Johnny
    2019 SR Tacoma
    I do like colors…
    I didn’t think of the DRL being off when the high beam is off. That does complicate it….
    You’re probably right, at a certain level of complexity it probably isn’t worth it.
  9. Jan 17, 2025 at 5:40 PM
    #369
    Puppypunter
    Johnny
    2019 SR Tacoma
    Wait, might still be possible with 2 harnesses…. I need to draw it up.
  10. Jan 17, 2025 at 6:17 PM
    #370
    daveeasa
    daveeasa New Member
    David
    I see it possible with 3 relays. We can chat offline. If you get to a solution with just 2 that might be viable. 3 seems kinda loco but maybe some would be willing. It’s fun to bs about.
  11. Jan 19, 2025 at 7:17 AM
    #371
    scottiezilla
    scottiezilla New Member
    Like @mynameistory said, I gotta right all this down on manila graph paper…
    I was a lil confused when I saw people just replacing original headlights with oem led by depinning n possibly switching orientation of +/- wires
    Think I grasp the concept that these harnesses allowed for the full potential of newer oem led lights
    Food for thought…what if I had replaced fogs with after market on their own new switch/circuit
    N had the oem fog just dormant right now
    Could the oem fog switch trigger some part of this conundrum? Maybe activate the quad high beam?(their harnesses goto nothing as of now)
    sorry for the interruption
    let the actual intelligence continue…
  12. Jan 19, 2025 at 7:55 AM
    #372
    daveeasa
    daveeasa New Member
    David
    ECU kills fog when high beams are on. So fog switch would be useful for non high beam aux lights aka not much. Or together w fog anytime.
  13. Jan 19, 2025 at 9:51 AM
    #373
    scottiezilla
    Big reason I wired my DDs up separately…wanted to use fog anytime w/o buying the BriteBox…didn’t know if there was anyway around the high cancelling them
    Figured as much
    well I deeply appreciate all the work you guys have done n continue to do
    Fingers crossed n still looking for my moms Highlander upgrade options
    furking headlights…geeze
  14. Jan 19, 2025 at 10:00 AM
    #374
    daveeasa
    daveeasa New Member
    David
  15. Jan 20, 2025 at 4:02 AM
    #375
    memario1214
    memario1214 Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    PJSnow and daveeasa[QUOTED] like this.
  16. Jan 22, 2025 at 7:18 AM
    #376
    SkiCityNick
    SkiCityNick New Member
    '17 4Runner TRD OR
    I know this is a long shot, but I just got a 4R where the previous owner installed some truly horrendous LED bulbs in the standard halogen housing. No throw, minimal light. It's pretty terrible. After digging around for more hours than I care to admit, it seems like the most resounding recommendation is to get an OEM LED take-off from a newer fifth generation. I had also believed that the required conversion harnesses might be near impossible to get based on the sticky on the top of this thread. That said, from the last few posts it sounds like @daveeasa and @Puppypunter may still be able to whip up one of these?
    So, two questions:
    1) Is there any feasible way to talk one of the two of you into helping me out so that I don't send my 4R off the side of a canyon due to lack of visibility?
    2) It seems like there is a difference between the 3 light LED on the TRD pros (high/low/turns) and the 1 LED (just lows) wiring/housing. Is one of these preferable/easier to create a harness for? The single LED seems like it would be easier to do, but potentially harder to find as a takeoff item (at least in good condition)?
    Thank you so much!
  17. Jan 22, 2025 at 7:26 AM
    #377
    daveeasa
    daveeasa New Member
    David
    I’ll dm you
    scottiezilla and Puppypunter like this.
  18. Jan 22, 2025 at 11:25 AM
    #378
    scottiezilla
    Feel like I found a great deal on eBay with the matching PN#s for the bi-led
    (Would love to confirm with anyone willing)
    Now these harnesses are the missing piece
    If @Puppypunter takes on this challenge please add my name to the pot
  19. Jan 22, 2025 at 12:23 PM
    #379
    Puppypunter
    Johnny
    2019 SR Tacoma
    I’ll send you a message.
  20. Jan 27, 2025 at 11:09 AM
    #380
    eatsinpdx
    eatsinpdx New Member
    Thoughts on this older 4th gen mod working on the 5th gen? https://www.top4runners.com/ja/2007/fogmod.html
  21. Jan 29, 2025 at 12:12 PM
    #381
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Autozone/Oreilly/etc sells decent bulbs under the brand Sylvania Xtravision that will be fine for the time being while you search for LED take offs.
  22. Jan 29, 2025 at 4:40 PM
    #382
    scottiezilla
    just installed my second pair…lasted longer than what some have mentioned
    side note: MUCH longer…no 3-4 months, closer to 3 years
  23. Jan 29, 2025 at 5:31 PM
    #383
    SkiCityNick
    '17 4Runner TRD OR
    Just a note that I found takeoffs relatively quickly with some scouring of the internet. I’ll circle back with an update once I try to install them.
  24. Jan 29, 2025 at 7:10 PM
    #384
    scottiezilla
    Intercepting package….
  25. Jan 30, 2025 at 7:23 PM
    #385
    mikeskinz
    mikeskinz New Member
    New to the forum, been researching upgrading my 2019 OR to the oem bi-leds for a while now.
    I got a lead on some 2024 TRD Pro headlights and looking to get those connected.
    I see that daveeasa isn’t taking anymore orders.
    Can someone advise on how I can go about doing this conversion then?
    Is Puppypunter going to be making some harnesses? Thanks all for the great information and help.
  26. Jan 30, 2025 at 7:45 PM
    #386
    Puppypunter
    Johnny
    2019 SR Tacoma
    I can make them. Shoot me a PM.
  27. Mar 11, 2025 at 9:27 AM
    #387
    MontanaMarine
    MontanaMarine New Member
    Dave
    2016 SR5
    Does this relay work on 4runners?
  28. Mar 11, 2025 at 10:45 AM
    #388
    scottiezilla
    MontanaMarine[QUOTED] likes this.
  29. Mar 11, 2025 at 12:41 PM
    #389
    MontanaMarine
    Dave
    2016 SR5
  30. Mar 11, 2025 at 4:45 PM
    #390
    scottiezilla
